Author Topic: Fuel lines and filters - Ambassador  (Read 5987 times)
Offline Ambo_bubba
« on: April 27, 2025, 04:35:35 PM »
Good evening,
I'm currently in the final stages of the restoration on my 71 ambassador and am connecting fuel lines to my fuel tank and carbs. I decided to update the petcocks to the newer type with a true reserve with adapters from MG cycle. Unfortunately, the adapters don't have a place for the small filter that goes with them.
My thought is to instead run inline fuel filters like you would see on boats and other types of vehicles. Is this necessary or common practice?
My other issue is when trying to line up the generic fuel filters I got from Advanced, there's not enough space to run the crossover for the fuel lines. I'm considering getting the dual inlet banjos for the carbs and running a line between the carbs instead of the cross over, but it got me thinking, with the updated petcocks, is the crossover even necessary?
Why couldn't I just run a line to each carb from each petcocks and not worry about interconnecting the two?
Thanks!
Re: Fuel lines and filters - Ambassador
« Reply #1 on: April 27, 2025, 05:54:41 PM »
Buy the DOUBLE banjos for each carb.  There’s a filter underneath each.  Run fuel line from left petcock to right carb, right petcock to left carb.  Then another line between each carb.  No need for the “X” setup.  Just more points to leak.
« Reply #2 on: April 27, 2025, 08:05:52 PM »
+1 on what Cam says, that's what I been doing since 77 when I changed the T I bought new year before. Less hose & clamps.
Offline Moparnut72
« Reply #3 on: April 27, 2025, 10:37:20 PM »
I ran a separate hose to each carb on one of my airheads. No problem kind of nice because the right carb ran out before the left that way the bike didn't go completely dead when the fuel started to run out. A safety feature in heavy traffic, still had some power to switch petcocks to reserve.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline Ambo_bubba
« Reply #4 on: April 28, 2025, 07:40:16 PM »
Double banjos are on order, thanks all for your input!
« Reply #5 on: April 29, 2025, 09:01:08 AM »
Good evening,
Thanks!
My 2 cents worth...
The hole in the MG Cycle adapters is too small and kinks the clear plastic standpipe. I always enlarge it to 1/4". On one set I drilled the top a bit larger, tapped it M8-1.0 and used the filters from the old petcocks.
The easiest filter to add is the small tapered cone shaped one from Visu-Filter
https://www.amazon.com/Visu-Filter-Universal-In-Line-Fuel-Filter/dp/B00J4ZAOIA
But, if you can retain the in-tank screens, the filters aren't really necessary IMO.
« Reply #6 on: April 29, 2025, 04:26:21 PM »
Gotta give credit to Charlie.  He schooled me on this setup.  I still use the braided BMW fuel line.  No clamps needed, change out every few years.
« Reply #7 on: April 29, 2025, 06:16:50 PM »
I've switched to Tygon hose, which also needs no clamps, but I use 3/8" spring clamps anyway. It's not ethanol proof, but gives plenty of warning that it needs to be changed - shrinks a bit, turns a little brown, never cracks. I change it annually, but it could go longer. https://www.mcmaster.com/5552K25/
