Author Topic: Alternative risers for my V85 TT  (Read 3888 times)
Offline LuftGansa
« on: April 27, 2025, 10:16:16 PM »
Fellas, I don't like . the idea of high euro prices for a set of risers with the corresponding expensive shipping.  A fellow on fb mentioned that I could use +1” risers for fat bars found on Amazonfor the TT.
Any thoughts from my Guzista famiglia?
Luft
Offline Vagrant
Re: Alternative risers for my V85 TT
« Reply #1 on: April 28, 2025, 07:36:05 AM »
I bought these two weeks ago for $15. delivered with tax. As always search for a better deal from Alli. They fit perfectly and look great. All the others this size need the holes drilled a bit because Guzzi used an odd size. I have the high buck Heli bar one on my other V85 and I like this one better because you can still reach the key OK. With the Heli it's burried.
https://www.aliexpress.us/item/3256806516445892.html?spm=a2g0o.order_detail.order_detail_item.3.5347f19c67ORLt&gatewayAdapt=glo2usa
I also put on this keyless gas cap. The three mounting screws are too short, so I used the original ones. I will try to find a better match someday.
RiderJacky Motorcycle Accessories Store
Keyless Motorcycle Fuel Gas Tank cap Cover For Aprilia RS 660 RS660 2021-2022
Red no logo
The link doesn't come up but it's for an Aprilia RS660. Just check the outside dia to make sure it's the same. There are a ton of MFG's listing them. I paid $25 to my door.
Offline guzziart
« Reply #2 on: April 28, 2025, 08:33:14 AM »
I bought a pair of Rox Barback risers from another member here that had them on his v85.  The result for me was insufficient slack in clutch cable, etc. without doing some other mods (cover panels at steering head, etc.).  Maybe I could have done more by removing the tank and more thoroughly inspect cable routing to determine if there was in fact a few inches more to play with to facilitate riser installation without stressing cables & wiring but I didn't.  So, I ended up rotating the bars back to me a few degrees and so far it is acceptable.  I may try to revisit the bar riser installation if I end up removing the tank for whatever maintenance reason.
« Last Edit: April 28, 2025, 08:39:44 AM by guzziart »
Offline LuftGansa
« Reply #3 on: April 28, 2025, 02:02:53 PM »
Thanks for the insight guys, I think I'll run with what you said.   Keep sending good ideas my way.
Luft
Offline LuftGansa
« Reply #4 on: April 28, 2025, 02:04:04 PM »
Hey Vagrant, could you send me a couple of photos of those risers on your bike?
Offline Moparnut72
« Reply #5 on: April 29, 2025, 09:52:25 AM »
I put adjustable Rox risers on my V100. With those you could try different up, down, back and forth to get a position that you like. I am happy with mine, they weren't too expensive, around $80, not much considering I spent $16,000 for the bike plus more in dealer and government fees.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline Githianki
« Reply #6 on: April 29, 2025, 11:19:16 AM »
I went with the ROX non adjustable 1-1/2" risers and didn't have any issues with cables.  They have a set in their scratch and dent area right now for $60
If you can beat them, arrange to have them beaten.
Offline guzziart
« Reply #7 on: April 29, 2025, 04:06:05 PM »
Would you have a Rox part number for them?
Thanks, Art
Offline Githianki
« Reply #8 on: April 30, 2025, 05:39:24 AM »
Here you go.  It's on their clearance tab 3R-B17R-15K-BLEM
Offline guzziart
« Reply #9 on: May 01, 2025, 10:00:05 AM »
Hey G,
Thanks! I believe I have the Rox 3R-B17R-15K.  Rox indicates it doesn't fit the v85.  My experience was that the risers fit the hbar and factory riser but found insufficient clutch cable & wiring slack.  With the Rox risers I bought for my vstrom, Rox indicated that the front brake line would not be long enough, to use their riser a different brake hose would be required.  So, I'm wondering why Rox indicates their 3R-B17R-15K does not fit the v85.  Oh well, I guess I'll revisit this issue another time.  Glad they worked out for you!
Art
Offline LuftGansa
« Reply #10 on: May 03, 2025, 10:42:20 AM »
Gosling, did you install those risers on a V85 TT.
I purchased the risers according to your saying that you used them on your bike.  Was that bike a V85 ?  Then I have no problem putting them on mine.  A later poster said that he purchased them and couldn't put them on because of the brake line being to short.
It would help me immensely if I knew you put them on a V85 TT.
Luft
Online izzuG
« Reply #11 on: May 03, 2025, 11:37:35 AM »
I asked ROX about V85 fitment, their response is below.
We have not had one of those bikes in our shop to work on ourselves. I believe our 2 inch pivoting risers will bolt up on that bike, but you will need to double check the extra slack in your cables and lines. The link below are the risers I’m referring to.
https://roxspeedfx.com/collections/adv-dual-sport-dirt-bike-handlebar-risers/products/2-pivoting-bar-risers-for-1-1-8-handlebar
Regards,
Ryan Jensen
Customer Relations & Sales Director
Rox Speed FX Inc. - Est 1999
Offline Moparnut72
« Reply #12 on: May 03, 2025, 11:52:03 AM »
I put a set of those on my Mandello. I don't remember where I got them but they were a lot cheaper than that.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline LuftGansa
« Reply #13 on: May 03, 2025, 12:07:27 PM »
Thanks for all the responses .
Luft
Offline JStorm
« Reply #14 on: May 03, 2025, 09:05:54 PM »
Sure wish I'd have seen this before I bought the Helibars riser! The funky bolt spacing was the main reason why i didnt take a chance on the Aliexpress risers. My H&B handguards likely wouldnt play nice with those. Key access being buried with the Helibars piece is true. I flipped mine over and like the positioning much better, especially when standing.
Jay
Red no logo
Offline Vagrant
« Reply #15 on: May 04, 2025, 07:24:13 AM »
I wish I could reverse my Heli risers, but I got them for short arm syndrome.
Since mounting the gas cap I have filled the tank 3 times. Love it. Being too lazy to go buy new screws I just took the other allen heads out of the stock cap and used them so they all match.
Offline inditx
« Reply #16 on: May 04, 2025, 09:17:48 AM »
One other note on the Rox risers, I found that they increased helmet buffeting, go figure.
Wind management on the V85 was one reason I traded it for a different bike, YMMV
inditx
inditx
This is the day.....
Offline guzziart
« Reply #17 on: May 05, 2025, 10:47:10 AM »
inditx
Maybe because the handguards are slightly further back??!!  Between the Calsci screen, Debyls deflectors, AliEx winglets and a new helmet I think my noise & buffeting are gone. :violent1:
« Last Edit: May 05, 2025, 10:55:49 AM by guzziart »
