Author Topic: How to keep an aluminum gas tank shiny?  (Read 2383 times)
Offline Travlr
« on: May 02, 2025, 04:38:47 PM »
I've never put any finish on my Wilcox aluminum tank and bodywork.  Of course, after polishing, it immediately starts to tarnish/oxidate.  What's a quality product to put on and keep the bodywork shiny and not yellow or oxidate.
Mike
1984 LeMans 3 Cafe Racer
1977 BMW R100S
Online DoubleGuzzi
  • '19 V7III CS; '79 V50; (Triumph S400)
Re: How to keep an aluminum gas tank shiny?
« Reply #1 on: May 02, 2025, 04:45:19 PM »
To get initial shine, expensive MOTHER'S ULTIMATE MAG AND ALUMINIUM POLISH. It allegedly slows oxidation but hopefully someone else will suggest a good 'top coat'.
HTH
Nearly natural progression..
Present: V7III CS, (V50II).
Online Turin
« Reply #2 on: May 03, 2025, 01:16:22 AM »
I use mothers as well.
1985 Sidlow Guzzi
Offline majstevetrevor
« Reply #3 on: May 03, 2025, 06:19:51 AM »
That’s a beautiful bike!
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #4 on: May 03, 2025, 10:33:26 AM »
ACF-50, WD-40, Amsoil MP, etc.
2019 Beta EVO 250
Online DoubleGuzzi
« Reply #5 on: May 03, 2025, 10:44:22 AM »
I was waiting on someone mentioning these.  :wink: I don't think I'd like the resulting smeared finish and be more likely to choose a polished wax coating.
Online Gliderjohn
« Reply #6 on: May 03, 2025, 11:03:40 AM »
When I first bought my T-3 the wheels had quite a bit of oxidation. To start the polishing process I did use WD-40 along with steel wool. Did a great job of the basic work. Then finished it up with metal polish and a lot of elbow grease.
East Mountains, NM
Online Moparnut72
« Reply #7 on: May 03, 2025, 11:48:24 AM »
I would put a good coat of paste wax on it and buff it out.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online DoubleGuzzi
« Reply #8 on: May 03, 2025, 12:12:49 PM »
.. quite a bit of oxidation. To start the polishing process I did use WD-40 along with steel wool.
For wheels, my starting point would be Solvol Autosol as the cleaner, with possibly P800 Wet & Dry. I can see the advantage of steel wool though.
It's the post polishing protection that OP really wants to know, if I read right.
Online Gliderjohn
« Reply #9 on: May 03, 2025, 01:36:09 PM »
With enough manpower and polish about anything will buff out. Before and after for the B-29 Doc.
East Mountains, NM
Offline SIR REAL ED
« Reply #10 on: May 03, 2025, 03:29:40 PM »
You 're probably not using enough of it!!
Think, car wash with oil!!
 :azn:
2019 Beta EVO 250
Offline Travlr
« Reply #11 on: May 03, 2025, 04:06:44 PM »
Thank you.  It's a LeMans 3 with Evan Wilcox bodywork.
Has anybody tried this: www.alumaclear.com?
Mike
1977 BMW R100S
Online cliffrod
« Reply #12 on: May 03, 2025, 05:57:36 PM »
Polished aluminum is the gift that keeps on giving….
Aluminum surfaces oxidize, so getting them as perfectly smooth/polished as possible to reduce surface area helps them stay shiny longer.   That bodywork is probably 3003, which easily shaped because it is pretty soft.  That also means it will tend to oxidize easier/more as the surface is more easily scratched, even if the scratches are minute.  I’ve found the best long-term aluminum polish results from proper progression of polishing to a final step of at least 2000 grit wet/dry using something like kerosene as the “wet”.  water may work just as well but I haven’t tried it.  This is followed by using a paste polishing product like Simichrome.
Beyond that, anything soft like wax only lasts so long but doesn’t interfere with future polishing.  Anything durable like a clear coat in the link will need to be stripped before more polishing can be done.  On harder alloys, that stripping may be less of an issue than it can be on soft alloys like 3000 series which is commonly used for such panelwork
Online Stretch
« Reply #13 on: May 03, 2025, 06:21:20 PM »
Yep - part of your regular upper body workout routine....  :grin:
Be thankful you don't have an entire car or truck to do!
                                            -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
