Author Topic: Looking for Marzocchi fork manual including NTX 350/650 forks  (Read 2522 times)
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Does anyone have any leads to where I might find a service and/or parts manual for the Marzocchi forks that were used for the NTX 350/650?
Offline RinkRat II
  • Lake Powell AZ
Re: Looking for Marzocchi fork manual including NTX 350/650 forks
« Reply #1 on: May 06, 2025, 04:25:16 PM »
  Do you know which model and size they are? I may have a manual for them.
   Paul B :boozing:
Offline Dirk_S
« Reply #3 on: May 06, 2025, 05:03:46 PM »
Model— no clue. Tube diameter = 40mm; stroke = 210mm.
Note that these forks have only a 2-point mounting system for the fork brace (1 mounting hole per fork) rather than the more rigid 4-point (2 holes per fork). I ended up modifying a British Fork Co./Russell James fork brace for structural rigidity.
Here’s an exploded diagram from the NTX service manual:
« Last Edit: May 06, 2025, 06:24:46 PM by Dirk_S »
Offline Dirk_S
« Reply #4 on: May 06, 2025, 06:27:23 PM »
This any help? https://www.guzzitek.org/gb/ma_us_uk/350750NevSPTargNTXXPA_At(GB).pdf
Not really. I assume the Guzzi parts diagrams will have Guzzi-specific part numbers, and the Guzzi service instructions—just like for the Dellorto carbs—won’t be as specific. Seeing that these forks are pretty old now, I’d prefer to have a manual straight from the manufacturer.
« Reply #5 on: May 07, 2025, 09:15:45 AM »
To the best of my knowledge the same on 650TT are Marzocchi M1R internals at 40mm tubes, what I used to rebuild forks on a 650TT
The only book I could find is the one Charlie posted, I used it in the 90's for the TT rebuild before I knew computers there was only paper & house phone.
You could call MarzocchiMotor in Italy
« Last Edit: May 07, 2025, 09:38:42 AM by guzzisteve »
