Author Topic: Useful hack for blind bearing removal: Hot cross buns! V7 Swing arm bearing  (Read 5205 times)
Offline lewisham_phil
Well I didn't hold out much hope for this, but I saw it suggested by a Canadian dirt bike mechanic who often pops up on my facebook feed, and he always seems to know what he's doing. When I find out his name I'll credit him..
Anyway, I don't have a blind puller, so I gave it a try: A slice of bread, well squished up, then poked into the bearing centre, until it is filled (other bakery products would be suitable; I actually didn't have any bread, and used a hot cross bun, complete with raisins). Then take the swing arm pivot pin, and wallop it into the inner race - DON'T bottom it out; you're basically applying force against the back face of the bearing outward. Before it bottoms out, remove the pin, pack more bread paste in, and repeat. After about five top-ups, it began to move, and after half a hot-cross bun, it came out. It was quite corroded in too, as shown on the images, so I think there was quite some force going on.
Note that you do need a close fitting 'piston', like the pivot pin, (or whatever is running in the bearing centre) to get the pressure. It certainly works on sealed bearings, not sure about unsealed. The pressure deforms the inner bearing seal as well, so don't plan on re-using if that's an issue. Clearly not an issue for mine.
After this I had a nice cup of tea, and half a bun. You can see from the image the size of puck that the other half ends up.
« Last Edit: May 19, 2025, 06:55:39 PM by lewisham_phil »
Previous bikes: CB200-RD350-GS550-CBX550-DT250-FZ750-RD250LC-ZZR600-CB919-XY400-Guzzi V7I Special
Offline jrt
That's hilarious.  Long time ago, I worked with university plumbers as a student, run-around, do-all kid.  Corky (yes, that was his name) would plug copper pipe with a piece of bread if the shutoff valve didn't work well, then solder it up to repair or whatever.  The bread would dissolve and flow out through the faucet pretty easily (remove the aerator).
I guess for this to work, there has to be a space behind the bearing to 'squish' the hot cross bun into?
And what do you do with the icing????
Now I have a hankering for a hot cross bun.....
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Online SIR REAL ED
  • uh.... it's personal....
Sir, the inbred redneck in me salutes you!!!!  I come from a long line of cheap SOB's who would go to any length to avoid buying proper tools, and even I have not heard of using bread as an incompressible fluid to push out a bearing.
To put the icing on the cake, or hot cross bun in this case, please, please, please tell me that you went the final mile, to make my people proud and that you ate the smushed hot cross bun after you got the bearing out.
To not eat it would be a waste of money, and in many circles (perhaps even WildGuzzi) you would be thoroughly shamed and humiliated!!!
Hot cross buns do not grow on trees after all........
2002 MZ Skorpion
1994 DR Skorpion
Offline Oca Grassa
Used grease and a punch a time or two to remove a pilot bearing from the end of a crankshaft. Grease as the incompressible fluid and a pin punch the same diameter as the transmission input shaft.
Heard of using bread too, from some of the old head mechanics I apprenticed with back in the 80s. Same guys who taught me about Babbitt bearings and using oatmeal to stop a coolant leak….or saw dust to quiet a noisy rear diff!
One guy bought his 1st wrench from the Snap-On truck in 1948. Another was drafted towards the end of WW2 and worked on P-51s in the Army Air Corps on Okinawa. The war ended while he aboard ship headed there.
He taught me about using inert gas to displace oxygen so he could use an oxy-acetylene torch to cut open a fuel tank and repair a broken baffle. Literally used the exhaust gas from running another truck in the shop with a hose from the tail pipe to the broken tank.
Learned a great many lessons from those guys….the majority of whom passsed on a couple decades ago now.
My garage:
Online SIR REAL ED
Amen to those who grew up in hard times and passed on the secrets of "doing without" to the younger generations!!!
Additional kudos for passing on the experience of dealing with people who possessed gruff demeanors and the philosophy of  "Sticks and stones may break my bones but words shall never hurt me!"
"Old Bill" (who was born around 1900) had his welding shop in with my father's construction business.  As a kid, I always marveled at his green Snap-On toolbox!  I wrongly assumed Snap-On's corporate color was always red.
"That's the problem with you young people, you don't remember anything!"
2002 MZ Skorpion
1994 DR Skorpion
Offline John Croucher
Dreamily tool and thin cut off wheel.  5 minutes and your done.
Online Moparnut72
Using grease and an old propeller shaft or rod of the proper diameter was the only way to remove the front bearing in a vintage Mercury Quicksilver racing gear case. It was the specified method of removing it in the Mercury Marine repair manual.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline Alfetta
Long time back I worked at a service station that serviced the local police cars. Owner was a seedy guy for sure, but man did he know some tricks.  I watched him slide a package of hot dogs through the differential drain plug to get it to stop whining !  One of many questionable "repairs"...
Online SIR REAL ED
That is brilliant.  But on a Moto Guzzi, i would only recommend peperoni.....
2002 MZ Skorpion
1994 DR Skorpion
Offline wirespokes
Damn spell checker!  I'm sure you meant Dremel Tool?
Online Moparnut72
I've always heard that saw dust works well for that.  :evil:
kk
« Last Edit: May 20, 2025, 04:31:50 PM by Moparnut72 »
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online SIR REAL ED
kk
Sawdust works well as a spell checker?
I've never heard that!
2002 MZ Skorpion
1994 DR Skorpion
Offline SmithSwede
  • I don't want a pickle
That is brilliant.   Thanks for sharing that
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Offline nc43bsa
Hacks have their place in the universe, such as when something absolutely HAS to be done NOW and the proper tools are not available or prohibitively expensive.
BUUUUTTT, if the proper tool is needed repeatedly, buy the tool.   Especially if the cost to replace the item broken while using a hack exceeds the cost of the tool.
BTDT.
« Last Edit: May 21, 2025, 07:08:17 PM by nc43bsa »
1990 MilleGT
Online SIR REAL ED
I suspect hot cross buns are dirt cheap, and do no damage to aluminum or steel.  Unless of course, the hot cross bun is very, very, very stale.
At which point you could either soak it in water or microwave it......
Plus after the bearing is out, you can still eat the smushed hot cross buns.
Talk about saving the planet!!
2002 MZ Skorpion
1994 DR Skorpion
Offline wirespokes
Eating it seems like pushing the frugality card a teensy bit far, especially considering the added ingredients. However, it ought to help save on cleaning supplies.  :thumb:
Online SIR REAL ED
Overly frugal perhaps, but the bragging rights of eating a bearing puller are priceless!!!   :thumb:
2002 MZ Skorpion
1994 DR Skorpion
