Author Topic: What tire patch kit?  (Read 3453 times)
Offline john fish
« on: May 24, 2025, 04:40:34 PM »
I can't seem to find the tire patch kit that I usually carry on the bike.  I have the Dyna pump but no kit.  What patch kit do you carry with you on your bike?
He lost the run of himself.
Offline Bulldog9
Re: What tire patch kit?
« Reply #1 on: May 24, 2025, 04:47:58 PM »
StopNGo.... Have a kit in every one of my vehicles.
Permanent plug mushroom design.
MGNOC#23231
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #2 on: May 24, 2025, 05:32:39 PM »
I made one of these kits for each of my bikes. Came in handy in Argentina. Contents fit inside an Altoids tin:
  • A few tire strings
  • A few patches
  • Patch abrasion / sandpaper
  • Rubber cement
  • Slime reamer and puller hex bits
  • Spare tire gauge
  • Spare valve stem with valve core and core-remover style stem cap[‘li]
In my daily tool roll, I carry the Malco screwdriver handle that the reamer and puller attach to:
« Last Edit: May 24, 2025, 05:38:48 PM by Dirk_S »
Offline Perazzimx14
« Reply #3 on: May 24, 2025, 05:32:56 PM »
When you say "patch" do you really mean "plug" or do you mean internal tire patch for tubless tires. If its a "plug" for tubless Nealey tire plugs are bar none the best money can buy and fortunately it doesn't take a lot of money to buy a Nealey kit. If its an internal patch the patch brand patch is not as important as the preperation. Get any pull through type you can easily find.
I like the Nealey as it is a permenant fix and does not require any rubber cement. Push in, twist 1-1/2 times,  pull out, cut off, done.
« Last Edit: May 24, 2025, 05:34:40 PM by Perazzimx14 »
Online Dr. Enzo Toma
« Reply #4 on: May 24, 2025, 05:54:52 PM »
I carry the Dynaplug inflator and the plug kit on my tubeless tire bikes. If you need more than that, there's rope plugs sold at many gas stations or you've got tire damage that may be beyond a roadside repair. The "permanent" plugs I've seen require removing the tire to install from the inside.
2027 Moto Guzzi V7 Sport
MGNOC Member
Offline wirespokes
« Reply #5 on: May 24, 2025, 09:06:59 PM »
I'll second the Nealey kit. I used to carry the plugger with the mushroom shaped plugs. After the misery of trying to get the air to stay in and finally sealing it up with the ropey stuff, I now travel with the Nealey.
Offline john fish
« Reply #6 on: May 24, 2025, 09:56:31 PM »
Link to the Nealy kit:
https://www.nealeytirerepairkit.com/
Looks good.  I have tube and tubeless bikes so I need some tube patches, too.
Offline Dirk_S
« Reply #7 on: May 24, 2025, 10:06:19 PM »
Rema’s patches are boss. I got this bundle:
https://ebay.us/m/QIbmxQ
Offline Tkelly
« Reply #8 on: May 25, 2025, 08:58:25 AM »
Thanks for the tips.I have been carrying a gas station package for about 15 years ,so it’s Nealy for me 19$ delivered.
« Reply #10 on: May 25, 2025, 02:32:01 PM »
I use Slime in my tubed tires and can’t remember the last time a I had a flat tire.  For the tubeless, I have some typical auto rope plugs which have never failed me and the reamer/installer plus a small bicycle hand pump. Longer trips with luggage I carry a Slime air pump.
« Reply #11 on: May 25, 2025, 11:13:08 PM »
Nealy is hands down the best for tubeless tires.
I have a kit with a portable air pump and everything needed.  Goes with me no matter what I drive.
« Reply #12 on: May 30, 2025, 05:55:45 AM »
I carry a can of pressurised slime, along with a dog turd and glue kit and a small electric pump that goes up to 40psi no probs. The Breva has tubeless and no centre stand, so it will always be a "get you to the nearest shop that can do it properly" job.
Offline Perazzimx14
« Reply #13 on: May 30, 2025, 10:45:32 AM »
Just be careful with tire sealants. Some of them will render the tire unpatchable from the inside and all of them will piss off the shop working on your tire. Most shops have a huge upcharge for working on tire that have had goop injectced into them. If you ever inject this magic in a can into a tire please be a decent human and tell the shop what you did prior to them working on the tire so they can be prepared to deal with the liquid inside the tire.
« Reply #14 on: May 31, 2025, 05:48:21 PM »
Stop and Go.   Actually had it work for me.  Slime air pump.
I carry the kit from vehicle to vehicle however.  (3 bikes and 1 Corvette with run flats)  (The other cars have spares- I think).
