Author Topic: Marvell Mystery Oil?  (Read 4369 times)
Offline john fish
« on: May 26, 2025, 07:46:17 AM »
Marvell Mystery Oil.
Techron.
Gumout.
Sea Foam.
Grandma Clampetts cure-all.
Anything else.
Anybody think any of this stuff is useful?
He lost the run of himself.
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Marvell Mystery Oil?
« Reply #1 on: May 26, 2025, 08:00:20 AM »
Lake Speed, Jr (The Motor Oil Geek on YouTube) says they *can be good for fuel systems, but bad as engine oil additive. I’ll trust the scientist / racing engineer.
« Last Edit: May 26, 2025, 08:00:55 AM by Dirk_S »
Online StuCorpe
« Reply #2 on: May 26, 2025, 08:08:35 AM »
Back in the 1950's Marvel Mystery Oil made what they called an Inverse Oiler that mounted to the fender sidewall under the hood and had an adaptor plate that mounted on the intake manifold and the carburetor to inject the oil into the intake fuel stream.  It took a quart of oil per 1,000 miles of driving.  Some previous owner had mounted one on the 52 Mercury flathead that I owned.  I don't know if it actually did anything other than consume the oil but I did keep it filled up as long as I owned the car.
Online Perazzimx14
« Reply #3 on: May 26, 2025, 09:13:34 AM »
Snake oil
« Reply #4 on: May 26, 2025, 09:19:19 AM »
Actually, MMO is quite useful...ask an old-school aircraft powerplant mechanic
Offline Turin
« Reply #5 on: May 26, 2025, 10:10:53 AM »
I can't speak to the effectiveness of the oil and fuel additives, as I can't actually see them working. Gumout is a different story. It's great for blasting off all kinds of crud.
I'm a fan of Berrymans carb cleaning products.
1985 Sidlow Guzzi
Offline Trialsman
« Reply #6 on: May 26, 2025, 10:57:34 AM »
I used to use MMO when there was a rotary engine with stuck apex seals usually due to carbon build up.  I would pour it in every orifice and let it sit for a week.  Every singe engine turned over when I came back.  As for the others, I think they may be more hype.
2010 FE570 Husaberg
2019 Alta Redshift EXR
2021 Moto Guzzi V85TT Centenario
2024 Stelvio V100
2025 Arctic Leopard Ex-800
Online Moparnut72
« Reply #7 on: May 26, 2025, 11:06:22 AM »
We used MM in the radials we overhauled on the initial breaking run. Seafoam has worked real well for me cleaning lightly gummed up carburetors. Used in the marine world since I was a little kid which was a loooong time ago as a fogging oil especially on two strokes.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online StuCorpe
« Reply #8 on: May 26, 2025, 11:44:27 AM »
Here is what their inverse oiler looked like.  If someone still wants one they can find it on Ebay for about $500.
Offline Dr. Enzo Toma
« Reply #9 on: May 26, 2025, 12:04:20 PM »
The question is, what are you using it for?
I've had good experience with it on air systems, especially after rebuilding vacuum wipers on antique cars. I know it's also popular to use on air tools. On antique motorcycles, especially those with total loss oiling systems, folks add it to the gas to help with top end lubrication similar to premix in older 2-strokes.
Things it's not good for are modern EFI engines that are stock. Burning oil like that is no good for the o2 sensor or the exhaust catalyzer.
2027 Moto Guzzi V7 Sport
MGNOC Member
« Reply #10 on: May 26, 2025, 01:51:49 PM »
My late father was a B-17 mechanic stationed in England, and told me they used MMO often and successfully in rebuilding and repairing B-17 engines...
« Reply #11 on: May 26, 2025, 03:51:49 PM »
For future reference...
Online michaell32
« Reply #12 on: May 26, 2025, 04:13:38 PM »
I have used Seafoam 10 minutes before an oil change and it removed the ticking from stuck hydraulic lifters.  Other than that I haven't tried anything else.
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Online Guzzidad
« Reply #13 on: May 26, 2025, 05:58:26 PM »
   I've used MMO to clean and lubricate the chains on a couple of Triumphs I had. Doesn't sling off and lubricates well.
Online slowmover
« Reply #14 on: May 26, 2025, 09:00:18 PM »
What about
Online Guzzidad
« Reply #15 on: May 26, 2025, 09:18:42 PM »
    I remember Slick 50. That stuff was the real deal.
Online PeteS
« Reply #16 on: May 26, 2025, 09:24:40 PM »
Any more I use MMO in air tools. I have had it so long I forgot what I bought it for??
As for STP, I understand its a Viscosity Index Improver. Turns 10-30 to 10-50 or something like that.haven’t used it in decades.
Offline ridingron
« Reply #17 on: May 27, 2025, 12:53:40 AM »
I haven't seen STP in decades! Still available? Their big splash was almost winning the Indy 500 many years ago in a turbine powered car. I think they still took home a large purse for leading laps.
I used the MMO in air tools also.
Offline kballowe
  • - Kevin the Great -
« Reply #18 on: May 27, 2025, 06:29:49 AM »
The FTC sued the Slick 50 manufacturer (and others) for false advertising.
Source:
https://www.ftc.gov/news-events/news/press-releases/1997/07/quaker-state-subsidiaries-settle-ftc-charges-against-slick-50
