Author Topic: Musings about the V11  (Read 2225 times)
Offline YellowDuck
« on: May 31, 2025, 11:39:43 AM »
Just did my first valve adjustment on my 23 V7 (too easy!).  Looking at the layout, I was thinking that there was no reason why it couldn't be a 4-V design - you'd just have to move the tappet adjusters to the tops of the valve stems instead of the tops of the pushrods.
In the only 4-V Guzzi head I've read about so far (V11), they did exactly that, but they also moved the camshaft up into the head (so, two of them) and used little tiny pushrods.  Which of course then necessitated timing belts and such.
What do you think was the reason for that? More accurate timing with shorter pushrods?  Simpler to adjust timing with belts and pullies?
Was there ever a 4-V Guzzi with the camshaft in the normal spot? Has there ever been a true OHC Guzzi motor?
Just curious.  Really enjoying learning about these lovely motors.
Re: Musings about the V11
« Reply #1 on: May 31, 2025, 12:55:40 PM »
Cost
Online bad Chad
« Reply #2 on: May 31, 2025, 02:05:46 PM »
The v11 never had a 4v, your thinking of the second gen Griso and Norge mills.
Offline YellowDuck
« Reply #3 on: May 31, 2025, 03:21:05 PM »
Oops - thanks for the correction.  Learning has occurred.
Online Moparnut72
« Reply #4 on: May 31, 2025, 07:04:52 PM »
Like the LS Chevies and Mopar Hemis the cam was moved higher up in the blocks for shorter push rods allowing higher rpm. That resulted in the Chevy and Hemi tick from inadequate oiling from extended idling, cop cars etc. The 6
4 Hemis have higher flow oil pumps solving the problem,  hope so as we have one. :laugh:
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
