Author Topic: Age on trans fluid  (Read 3518 times)
Offline slowmover
Age on trans fluid
« on: June 07, 2025, 09:30:06 AM »
On vehicle oil there’s the recommendation to change at so many miles or so much time whatever comes first.What about my bikes transmission and final drives fluid? I changed them at 12k and the next one should be at 28. My mileage is at 25k but it’s been 6 years.I think I should change it just to feel good.
« Last Edit: June 07, 2025, 09:30:56 AM by slowmover »
Online Perazzimx14
Re: Age on trans fluid
« Reply #1 on: June 07, 2025, 11:28:29 AM »
Unless the oil got contaminated its probably good for many 10's of 1000's of miles since its not perashable the calendar be damned.
The good news is Its not very expensive nor time consuming to change. If it gives you peace of mind to change it, change it!
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline red stripeguz
« Reply #2 on: June 09, 2025, 08:01:16 AM »
Time does have a detrimental effect on motor and gear oils. Mostly the additives. I would certainly change it after 6 years and being close to the mileage any way
2023 V7 Special
2007 Norge
« Reply #3 on: June 09, 2025, 12:59:07 PM »
You’re a bit early for an April fools gag aren’t you ?
Do you really need to ask if you should ? I have re read this post many times to make sure that I haven’t mis read something, just get the old crap out and put the new stuff in.
I change mine Norge/V85 very 10,000 km (6,000 miles) and have done so in the Norge from 2007. It’s done 230,000 km and shifts like a Suzuki Bandit, asking if you should change your bike’s oil is like asking if you should wipe your infant’s ass.
I still think you might be joking.
Offline pressureangle
« Reply #4 on: June 09, 2025, 01:51:11 PM »
I use Chevron Delo ESI 85w140. It services Meritor and Mack 100,000 mile intervals on heavy trucks, should basically never need changing in ours unless you get water contamination.
Offline Moparnut72
« Reply #5 on: June 09, 2025, 04:20:10 PM »
The service wrench came on Saturday at 7,000 miles. My thought was what is up with that, an odd interval. I pulled out the owners manual to check. Low and behold I did it all at 5K. I have a few vehicles at our house, I change everything at 5k intervals, easy to keep track.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline LuftGansa
« Reply #6 on: June 10, 2025, 02:02:27 PM »
How many miles or years between changes for transmission fluid for the V85 TT?
Luft
« Reply #7 on: June 10, 2025, 04:57:11 PM »
Doesn't anybody consult maintenance schedules anymore?
Offline guzziart
« Reply #8 on: June 11, 2025, 06:01:51 AM »
Luft
In my small thick multi lingual difficult to read tiny print v85 owners manual, p.279, specifies eng, gearbox & final drive oil replacement as follows:
Eng oil @ 6200 mi or once/yr
Trans oil @ 18,600mi, no time based change
Final Drive oil @ 18,600mi, no time based change
Personally, I think I'd replace the trans & diff oil at least every two years if I was nowhere meeting the mileage interval.  And, like others have mentioned, I'll do engine oil at 5k mi to keep it simple for me and a little easier on the engine that requires a little less than 2 quarts of oil to live on.
Offline JHBettsSr
« Reply #9 on: June 12, 2025, 08:38:32 PM »
I change the trans and final drive oil every other oil change. It's cheap and easy, plus I don't have to worry about it ever again.
'17 Triumph Bonneville T120
'13 BMW K1600GT
'25 Moto Guzzi V85TT
