Author Topic: Breva 1100 Gearbox Replacement - AKA the Guzzi from hell  (Read 24504 times)
Offline Pescatore
Re: Breva 1100 Gearbox Replacement - AKA the Guzzi from hell
« Reply #30 on: June 27, 2025, 06:59:04 AM »
Impressive speed and good discipline for reading the manuals.
How's the swingarm bearing looking? Any grease in there?
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline SemperVee
  • USMC Retired
« Reply #31 on: June 27, 2025, 08:41:30 AM »
 Brilliant!  Love a story with a happy ending!  Good on ya!
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
Offline BrevaIsTheName
« Reply #32 on: June 27, 2025, 10:58:30 AM »
Thanks again y'all! It definitely isn't over yet, but good to know for sure. I'm still a little worried about that clutch rod bushing, but even if it isn't there, hopefully the input shaft is supported enough for it to be a non-issue when looking at "what connects where".
Yes, swingarm bearings looked pretty good actually! Likely because this old girl has barely been ridden. 20 years old and only 15,000 mi. I added a very generous helping of lithium grease and inspected the rollers which all looked good. Will be greasing the hell out of the CARC splines too when we get to that step-- maybe even today!
There was quite the mess of oil crud on the LH engine case, but the breather hose clamp wasn't even installed to the oil recovery tank, so I think that issue is/sorted. I will try and create a guide when all of this is said and done: the service manual is the best of any I've seen on previous bikes, but some steps need more detail. For example, unless you have very low-profile u-joints socket extensions (the kind that don't come from harbor-freight) it is virtually impossible to remove the clutch slave cylinder before the frame comes off and so working around the clutch line in an ergonomic nightmare. It's better to pull the line off from the master cylinder and thread it out of the frame-- this way you can also re-bleed the line and test the clutch before putting the whole thing together.
I have more to say but will do so later when I have pictures to provide intermission from the inarticulate word bombs I've been leaving thus far. If anyone has any insight into that bushing thing, do let me know!
« Reply #33 on: June 27, 2025, 03:37:46 PM »
If I was stuck by the roadside, I’d like to have you with me. You have an indefatigable approach and a cheery good humour.
Bravo Sir…!  :bow: :thumb:
Your Breva is fortunate to have you.
« Last Edit: June 27, 2025, 03:40:14 PM by Huzo »
Offline DoubleGuzzi
« Reply #34 on: June 27, 2025, 04:45:51 PM »
Doing all this outside, I can't decide on whether you're totally crazy!  :cheesy: :bow:
I hope that you give your Breva's smaller sibling plenty of lurve & attention - poor under-rated thing. It's not a "baby" it's a svelte small block, with mid-sized 750cc - the V35 is the baby!
Buy yerself a cheapo gazebo with zip up sides, for the bikes and it can even serve multi-purposes: beer tent, barbies etc.
 :boozing:
« Last Edit: June 27, 2025, 04:49:05 PM by DoubleGuzzi »
Nearly natural progression..
« Reply #35 on: June 30, 2025, 10:30:47 AM »
It's been done! Everything buttoned up for now. I will have to come in next week and reinstall a new swingarm pin and castle nut, since the old threads were so chewed as to prevent the nut from screwing in all the way and providing preload. It's.. rideable as it stands, but I wouldn't take it on any trips until the new one gets here Thursday.
last night I went out for a celebratory photoshoot-- while I'm still painfully anxious (and will be for the next few hundred miles), but at least "La mia Brevonna" is still a hell of a girl to look at. (see pics below)
Resident CARC experts, is there anything I should watch out for when reassembling the rear driveline? I clicked the driveshaft into the front input shaft all the way, but the rear final drive just kind of slotted into place. It doesn't have a retaining clip in the rear, does it? And is it possible for the driveshaft not to be pushed in and aligned after buttoning the whole gearbox/swingarm/FD assembly into place? Just checking all my bases here. Seeing as this is the largest job I've ever done, I will be semi-shocked to find out I did everything correctly. Currently still sweating every tiny noise that comes from the bike, but so far the actual sound from the gearbox and shaft seem to be near zero.
On a related note, how many miles would y'all need to put on a repair such as this before feeling comfortable and trusting the bike again? Everything runs perfect after about a dozen miles so far, but I don't know if that is the calm before any sort of storm!
There are a few other things I will add after this post to any would-be shadetree mechanic attempting this job themselves, but for now I will collect my thoughts and relish in the simple beauty of this Moto Guzzi.
« Last Edit: June 30, 2025, 10:36:19 AM by BrevaIsTheName »
« Reply #36 on: June 30, 2025, 12:50:02 PM »
The rear is assembled - driveshaft then swingarm then bolt on rear drive. Otherwise you can't get driveshaft clicked on to trans shaft while holding all that bulk & weight. Goes easier.
Glad you got it- from another shadetree,  ride safe.
« Reply #37 on: June 30, 2025, 12:58:29 PM »
Thank you!! This is exactly what I did. Sounds like all bases are, hopefully, covered. Ride safe indeed. I'm just glad this awesome community exists :)
« Reply #38 on: June 30, 2025, 04:53:20 PM »
Okay, since I have a bit of time today I wanted to address some points that are either not mentioned in the service manual or may catch someone off-guard, should they attempt this repair on their own.
    • When removing the clutch slave cylinder, ENSURE you have a push rod from the old gearbox or on hand, ordered as a separate part. The two rear bushings near the thrust washer stack come out, but the far (cylindrical) bushing is retained in the gearbox.
    • The gearshift linkage is awkwardly held hanging until the side cover/rearsets are reinstalled. There is no direction specified for what angle it should be installed along the gearbox splines. Make a note of where yours was installed or prepare to adjust the linkage as necessary. A linkage installed at too low of an angle will catch the frame, making it feel like 1st gear won't engage and leaving only half shifts. Addressing this early will spare you the heart attack of thinking your brand new eBay transmission is faulty!
    • The thick part of the cardan unit attaches to the input shaft of the gearbox. The yoke has a retaining clip which affixes it to the shaft. You will know it's installed correctly when you hear a click, but taking it out can be a pain. The only effective way to remove the shaft is to have a friend hit the part of the yoke closest to the gearbox with a hammer or mallet while you pull simultaneously. Make sure to grease liberally upon reinstallation.
    • Take photos and pay attention to the original routing of vacuum and fuel lines. The bike was assembled very carefully with attention to this detail, so you must do the same.
    • Since this is such a big job, I implore you to I-Mark everything. Use a paint marker to draw lines across fasteners and their mounting points. Use a torque wrench. Go slow. Write everything down. This CANNOT be done in an afternoon by your average joe, so don't count on your memory as it will fail you.
Having an organized workstation helps a lot-- stay organized, go slow and think like an engineer. Then you will be fine.
...unless this job catastrophically fails. In which case I will be back here with even more updates and a much, much more frantic warning!
[/list]
« Last Edit: June 30, 2025, 05:02:22 PM by BrevaIsTheName »
« Reply #39 on: July 01, 2025, 05:04:22 AM »
The measure of success does not lie in the gearbox, it lies in you.
A display of grit and determination whatever the outcome. I would not have had the balls.
« Reply #40 on: July 14, 2025, 12:21:14 AM »
Ciao a tutti,
apologies for reviving a somewhat dead thread, but the Guzzi from hell saga continues. I've put 250 miles on my new gearbox with no issues.. but something didn't feel right in my gut. There was a sort of clacking from the rear wheel/tire; Google told me I was hearing the power pulses from the V2. Then, there was a constant sort of roar from the tires: again, people told me the big block was louder than the SB guzzis so I shouldn't worry. Lastly, the infamous CARC "clunk" from the gear dog clearance seemed worse than ever-- almost unlivable compared to my small block 750.
This Sunday we investigated. Upon draining the CARC Final Drive oil, I was greeted by this horror:
WOW! The main bearing was T.O.A.S.T. Moving the wheel around felt okay when the mass of the tire could absorb any vibration, but once removed the bearing felt like grinding stones... I have no idea how a failure mode like this even occurs but nonetheless, I spent the afternoon swapping a new CARC unit in. I am told these things can't really be serviced, is that true? I would love to rebuild the original unit with new bearings if possible.
With the new CARC in, the bike is nothing short of revelatory. Half the driveline slop has vanished entirely, the ride has become silky smooth, and the bike is literally quieter than my 750 Breva (save for that intoxicating intake howl!). It is even possible that the "input gear noise" I was hearing from the 2nd (Norge) transmission was just the bearing, since the strange clicky/whirry noise persisted with the new GB install.
In a seemingly fitting end, the 1100 is back to being a Franken Guzzi with more Norge parts carrying her forward on her long march through time. Two things stick out to me that need to be noted:
  • My mechanic lied to me about having checked and replacing all fluids in the bike. I spent $2,000 for someone to lie and steal from me when they had been paid to check everything-- truly frightening.
  • At this point, almost the entire bike has been gone over. The CARC has been replaced, drive line inspected and greased... short of catastrophic engine failure (which I wouldn't rule out given the sort of demons which has possessed this poor bike) I can keep this bike forever now. If this was a japanese bike, there would be no way for me to have done the repairs as easily as this. Guzzis are genuinely the best bikes to learn how to wrench on, and if this clueless knob can do it so can you.
« Last Edit: July 14, 2025, 12:37:38 AM by BrevaIsTheName »
« Reply #41 on: July 14, 2025, 04:14:37 AM »
Actually Brev, good threads never die.
Speaking of which…
If you search an old thread of mine..
“Sometimes it all lines up just perfectly” and read from reply #39 onwards, you’ll be able to read the account of when my ‘07 Norge dumped it’s preload and shredded a goodly percentage of it’s internals. Pete Roper fixed an “unserviceable” CARC and I proceeded to go to Europe on it for the Guzzi 100 th…
It has now done 40,000 km on the repaired item.
Yes they can be fixed, if you live in the South East corner of Australia…
« Reply #42 on: July 14, 2025, 08:36:40 AM »
"I am told these things can't really be serviced, is that true?"
Pete Roper rebuilt one and there may be a thread somewhere about how he rebuilt it, but from memory it wasn't easy.
« Reply #43 on: July 14, 2025, 10:52:34 AM »
Speaking of which…
I DID read that thread! Originally I was worried I was having the same issue when I heard all my noise, but my FD was actually totally quiet when coasting and only made noise when accelerating. Very strange things. I will say, now that the problem (which has been ongoing likely since I bought the bike) has been cured, I have a whole new appreciation for CARC bikes. I was starting to hate them but a well-sorted CARC is a smooth, dead-quiet killer of a guzzi. The 2nd CARC I had was a Norge spare and I am a little worried as to why it was just lying around, but hopefully I have exhausted all my bad luck with parts after two failed gearboxes and a bad CARC :)
« Reply #44 on: July 14, 2025, 12:47:02 PM »
Make sure the pinion nut has a good dose of threadlock on it…
Offline Pescatore
« Reply #45 on: July 14, 2025, 09:13:00 PM »
There is a thread on guzzitech about CARC strip for bearing replacement.
They used a heavy duty press.  Maybe a good dose of heat will work.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
