Author Topic: Eldovert no spark -SOLVED-  (Read 8997 times)
Offline lazlokovacs
« on: June 09, 2025, 10:07:23 AM »
hi everyone,
Was riding the late, great Mike Tiberio's fantastic eldovert today and after about 10 minutes of riding, I lost all locomotion.
Battery has plenty of juice, there is fuel, the distributor rotor looks good and the points are opening and closing as per normal. (single set of points on this bike)
But no spark on either cylinder.
I'm guessing the coil has died and will replace it in due course.
Have been riding the bike daily with zero problems for some time so might have expected the coil to give me some weirdness and warning prior to letting go though.
Any other theories, or things to check welcome in the meantime.
Ride safe out there
« Last Edit: September 04, 2025, 11:11:15 AM by lazlokovacs »
Re: Eldovert no spark
« Reply #1 on: June 09, 2025, 11:17:27 AM »
Check for power to the + side of the coil. If no power, then check the fuse (inside the headlight, if Mike didn't move the fuseblock).
The points may be opening and closing, but is the gap correct and are the contacts clean?
If a tachometer is fitted, it may be grounding out internally. Disconnect the black wire from the tach.
Condensers can fail, but usually not all of the sudden.
Offline lazlokovacs
« Reply #2 on: June 09, 2025, 02:57:04 PM »
thanks charlie
most of mike's modifications were made with ease of maintenance in mind
eg no fuse block and no tachometer
Just removed the coil and it's getting 12v allright. Also tried grounding the main HT lead from the coil to see if there was a spark so I think that rules out the distributor, but ready to stand corrected.
Looks like I'm just waiting on the postman now.
I'm betting a new coil and she'll fire right up.
Bike is currently my only vehicle, feels like being 15 again having no transport.
Well, I have my pushbike
Thanks again.  :thumb:
Offline Moparnut72
« Reply #3 on: June 09, 2025, 04:48:32 PM »
Even though I have a PU this is the main reason I have two bikes. No telling how long I may have to wait for a part especially in August. :wink:
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online nc43bsa
« Reply #4 on: June 09, 2025, 08:41:06 PM »
I had a GM HEI coil fail suddenly with no prior symptoms.  I left the car running while I went back into the house for something and it quit while I was inside.
Coil failures happen.  Infrequently, fortunately.
1990 MilleGT
« Reply #5 on: June 09, 2025, 09:38:10 PM »
An Eldovert, I can't see that in the wiring diagrams.
Eldorado?
Convert?
Roy
« Last Edit: June 09, 2025, 09:41:14 PM by Kiwi_Roy »
« Reply #6 on: June 09, 2025, 09:44:32 PM »
Eldorado?
Convert?
Roy
Convert drivetrain in an Eldorado chassis. Built by the late Mike Tiberio.
« Reply #7 on: June 10, 2025, 06:10:01 AM »
Thanks Charlie Ill pick the Convert wiring then
http://www.thisoldtractor.com/guzzi007/schematics/1975_Convert_USA_police.gif
This schematic shows 2 sets of points but could easily be a single set with distributor.
A small lamp say 5 watt should light when connected between one of the points terminals and chassis as the motor is turned over slowly past TDC
I had to replace both coils on my 76 Convert with a pair of Harley coils.
« Last Edit: June 10, 2025, 06:29:01 AM by Kiwi_Roy »
« Reply #8 on: June 10, 2025, 08:49:43 AM »
Wiring is Eldorado, with modifications made by Mike.
Offline lazlokovacs
« Reply #9 on: June 10, 2025, 01:16:52 PM »
Mike's wiring is absolutely minimal, kind of like an old 60s brit bike.
If I ever get to drawing it out I'll be sure to post it here, probably the most pared back wiring loom on any guzzi out there
Anyway,
New coil and she fired right up, then ran rough and died further down the road.
As much as I mistrust the new ones, a condensor is on it's way
(and a new set of points)
Will keep you all in the loop
Offline DoubleGuzzi
« Reply #10 on: June 10, 2025, 04:21:57 PM »
No pun intended?  :cheesy:
Nearly natural progression..
Offline Frenchfrog
« Reply #11 on: June 11, 2025, 11:41:46 AM »
Anyway,
over on our side of the pond the condensor issue has only been sorted out by these devices....several variations on it from different manufacturers but I think they are all essentially the same. https://hmb-moto.de/Capacitor-module-V7-models-V7-Special-850-GT-etc
Offline lazlokovacs
« Reply #12 on: June 15, 2025, 05:20:02 PM »
update
tried 3 condensers, made no difference. Made my own condenser, made no difference.
have replaced rotor and distributor cap and points and plugs and plug caps and HT leads.
The really really strange thing is, the left cylinder is running PERFECTLY. The plug looks good enough to show off to your buddies. But the right side is missing at low throttle openings. Plug is perfect on the left side and sooty and black on the right side. I've tried swapping the plugs around and I get the same result.
There is a decent spark on both sides and the bike fires straight away every time.
Bear in mind that I'm running with a single coil and a single set of points AND that the bike was running perfectly before the 'no spark' episode.
So.... I'm finding it hard to keep believing that this is an ignition issue. Seeing as the left side is running perfectly, the only things left in the ignition system would be the RHS HT lead, plug and plug cap.
It absolutely feels like if I turned the mixture screw a touch leaner on the RHS carb the bike would run perfectly. Why haven't I tried that yet? Because 99 percent of carb issues are ignition based and I can't for the life of me figure out how the carburation could have changed so dramatically just from swapping out a dead coil.
I want to be sure that I haven't overlooked anything ignition based before I start tuning the carbs. (Which are untouched since the bike was running perfectly)
Any thoughts?? This one has got me for now....
Ps I've tried cheating the points a bit in various directions to get more dwell, more/less advance etc. No matter what I do in that regard, the left side runs perfectly and the right stays sooty.
« Reply #13 on: June 15, 2025, 08:32:56 PM »
So.... I'm finding it hard to keep believing that this is an ignition issue. Seeing as the left side is running perfectly, the only things left in the ignition system would be the RHS HT lead, plug and plug cap.[/b
Guzzi used to use crappy carbon core HT leads, throw that as far as you can and substitute leads with a copper core
Another thought, have you got the sparks crossed over, remember its not 180 apart so it goes Spark Spark with a long gap then Spark Spark again
What i'm trying to say is the right spark going to the right cylinder or have you got it timed to send the right spark going to the Left cylinder?
With a small lamp connected from the distributor terminal to chassis check the lamp lights just before TDC on each side.
« Last Edit: June 15, 2025, 11:54:06 PM by Kiwi_Roy »
« Reply #14 on: June 16, 2025, 11:34:05 AM »
I'm a little confused.
Did the entire bike loose power or just the ignition system?
Did you replace both spark plug wires?
I understand that it was running fine and then stopped. You put a new coil in and it was fine and then acted up again within a few miles?
Just in case you didn't get the plug wires installed correctly, when looking at the dist. cap from above, the socket closest to the RH cyl is for the LH cyl.. The one farthest from the RH cyl. is for the RH.
Also, There are two lobes on the single point dist.. A short pointy one and a long one. The short one is for the LH cyl. and is the one you "should" use to set your points and static timing.
A FWIW: On a single point dist. (IMHO) if one cyl. is working correctly, then both should be. Unless there is an issue with the dist. cap, spark plug wire, cap or the plug. So the coil and condenser should be fine if one side works correctly.
Offline lazlokovacs
« Reply #15 on: June 16, 2025, 03:26:35 PM »
yes tom you've got it right
bike was running perfectly then
the ignition system died. no spark. but plenty of power to the starter etc.
replaced coil
got spark
now have a weird misfire low revs on right cylinder
have swapped out condenser for 3 others and gone back to original
points have been correctly set.
left side is back to perfect
misfire only on RHS
of course problem only on right side means it must be cap, rotor, HT lead, spark plug or plug cap. ALL OF WHICH HAVE BEEN REPLACED.
Hence I'm confused too.
And yes the HT leads are correctly routed.
« Reply #16 on: June 16, 2025, 03:52:25 PM »
You didn't accidentally hook the coil up backwards did you? I've heard of that providing only enough spark for one cylinder.
« Reply #17 on: June 16, 2025, 04:11:39 PM »
Charlie has a good point there, though I really did not know what would happen if you did.
So....You changed out the coil, only the coil. Fired right up and then had issue within a few miles. OR did you also change the dist. cap at the same time?
I ask because there has been bad brand new dist. caps around lately. Have you tried the old cap again?
Your replacing the coil should have solved your no spark issue and both sides should have been fine after doing so.
Could be a heck of a coincidence that a carb issue happened at the same time. It might be time to make sure your throttle and choke cables are seated fully, easy to pull up on a housing a bit and have it sitting on the adjuster instead of in it. Check the choke plunger to make sure it's sealing. After that, might be time to open up the carb and see if it looks gunked up and give it a cleaning.
Hope this helps,
Offline lazlokovacs
« Reply #18 on: June 17, 2025, 01:36:07 AM »
I'll check. I really doubt it but worth a shot.
Tom - I had the exact same thoughts, choke plungers are ok and cables aren't hanging up.
changed only the coil and I got spark but with a misfire.
then changed cap
then changed rotor
every change was done one at a time so I could observe the results.
« Reply #19 on: June 17, 2025, 09:45:45 AM »
Well.....
You might want to go down to your auto parts store or HF and get an inliine spark tester. like this. But it is for the nut style plug not the threaded stud:
https://ibb.co/mWSyGqZ
You might also try swapping the LH and RH carb??
PS: what's up with the inline image attachments??
« Reply #20 on: June 17, 2025, 01:04:10 PM »
I posted re crappy carbon core spark leads, did you check that out.
I had that issue on a 98 EV, would cut out on one cylinder due to the carbon not making contact, new copper core leads fixed that.
Roy
Offline lazlokovacs
« Reply #21 on: June 18, 2025, 11:28:38 AM »
cheers kiwi
yes I did change out the ht leads
« Reply #22 on: June 22, 2025, 05:42:03 PM »
Well......Is it up and running correctly? How?
Offline wirespokes
« Reply #23 on: June 23, 2025, 09:53:19 PM »
You replaced the leads, but we still don't know if they're the carbon core or copper core.
Carburetion doesn't normally change so suddenly. And the only thing that could cause it to suddenly run rich is float level suddenly higher or float valve leaking.
Offline lazlokovacs
« Reply #24 on: June 24, 2025, 02:13:17 AM »
copper core. and the coil is the right way round.
Offline BMCMOTO
« Reply #25 on: June 24, 2025, 05:32:48 AM »
One of my "electrical" problems!
Brian
« Last Edit: June 24, 2025, 05:33:55 AM by bmc5733946 »
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline lazlokovacs
« Reply #26 on: June 24, 2025, 02:14:14 PM »
funnily enough, went into the carb today, all is fine in there.
Going to do a compression and leak down test when I have time.
Offline lazlokovacs
« Reply #27 on: September 04, 2025, 11:10:59 AM »
- SOLVED -
why I had no spark, I still have no idea but the misfire has now gone after I did a compression test and fit new rings on the RHS
thanks for all the input
got there in the end
Offline moto-uno
Re: Eldovert no spark -SOLVED-
« Reply #28 on: September 07, 2025, 07:25:55 PM »
  Am I to believe that you fitted new piston rings ? How did the head gasket look ? And of course , what was the before and after compression readings ?
  Just love to have all the blanks filled in for future info . Peter
Offline lazlokovacs
« Reply #29 on: September 08, 2025, 03:28:06 PM »
yes new rings fitted,
I didn't get to see the head gasket,
compression was around 60 percent of the other side and is now up to about 95 percent, can't remember exact numbers sorry
