Author Topic: Linked brake line replacement?  (Read 2669 times)
Offline monkeyodeath
« on: June 13, 2025, 04:48:56 PM »
My '79 1000SP brakes were de-linked by the previous owner, but the MCs weren't changed.
However, the PO did ditch the brake line that connects the rear proportioning valve to the front disk.
Is it possible to get a line like this made? Mark at Moto Guzzi Classics can get me a proportioning valve but the original plumbing is much harder to find.
Would be cool to get to ride this bike with linked brakes -- I've never tried them before and I'd like to do so.
Offline moto
  • Fear the deer!
Re: Linked brake line replacement?
« Reply #1 on: June 13, 2025, 07:20:01 PM »
850 T-3
Griso 1100 corretto
« Reply #2 on: June 13, 2025, 07:22:20 PM »
I've bought lines that are extra long, but with the correct fittings, at NAPA. Then bent, shortened and reflared them.
Offline Turin
« Reply #3 on: June 13, 2025, 09:37:34 PM »
I got a Spiegler stainless steel brake line kit from Harpers. (went with black rubber coating) , Factory fit, easy install.
https://harpermoto.com/collections/moto-guzzi-parts-brakes-spiegler-brake-lines
1985 Sidlow Guzzi
« Reply #4 on: June 13, 2025, 10:36:46 PM »
Very cool, thanks for pointing this out! Mark made it sound like the brake line was both unobtanium and had weird fittings.
Does anyone happen to have a picture of how it's supposed to be mounted to the frame? Wondering if I need to also source the frame mounted unions between the flexible and hard lines.
« Reply #5 on: June 14, 2025, 08:40:57 AM »
It only mounts to the frame in one place - up near the front via a wire retainer with grommet. There are several places along it's length where Guzzi used short pieces of split rubber hose to keep it from rubbing on the frame.
https://ibb.co/TDQ1v8Kf
