Author Topic: Voltmeter  (Read 41607 times)
Offline sign216
Re: Voltmeter
« Reply #30 on: June 28, 2025, 07:11:07 PM »
It's a bit of a bulky affair, especially as I don't have any real need for the USB aspect..
Let's see how long it lasts and/or until I get pee'd off with the size of the thing.   :rolleyes:
I point out my post and picture earlier in this thread, where my edgewise analog meter fits right into the dash, next to the ignition lock.  Analog, they way gauges were meant to be, and oddly, it's more compact than digital.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Online DoubleGuzzi
Re: Voltmeter
« Reply #31 on: June 28, 2025, 08:12:38 PM »
Yup, I agree and if the scale was a bit more meaningful eg. 9-15V, to me it's near perfect.  :smiley:
I've also shown the tiny LED meters that I normally use.
« Last Edit: June 28, 2025, 08:26:10 PM by DoubleGuzzi »
Nearly natural progression..
Online Anomaly
Re: Voltmeter
« Reply #32 on: June 29, 2025, 10:13:16 AM »
Can you post a link to that analog gauge? Please. Looks nice
Offline sign216
Re: Voltmeter
« Reply #33 on: June 29, 2025, 08:56:00 PM »
I might have more info, if you need it.
Joe
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Online Anomaly
Re: Voltmeter
« Reply #34 on: June 30, 2025, 06:30:41 AM »
Joe
Yes, that's what I was hoping for (I saw the image the first time you posted it)-- a link to where to purchase one like that or a brand name or some way of finding one like that ...
Offline sign216
Re: Voltmeter
« Reply #35 on: June 30, 2025, 12:16:12 PM »
Anomaly,
I got the meter 13 years ago.  A Modutec from ElectricScooterpart s.com.  The style is called "edgewise," meaning that instead of being circular, the scale runs lengthwise.  The meters were designed for electric golf carts and electric scooters.  Before you buy, look carefully at the scale, as some are designed for 6 volt or 24 volt systems, and some are designed for an up-down installation, instead of side-to-side.   Back then, there were several different manufacturers.  A search for "edgewise voltmeters" should get you started, but the search won't be easy.   Some vendors don't use the term "edgewise", and many are moving away from analog to cheaper digital gauges. So you'll have to work for it.
For the install on my '09 V7 Classic, I used a Posi-loc tap into the yellow wire at headlight, for the parking light (always on when engine is on).  Grounded on a nearby nut, which required a copper stand-off tube.  A pain to do, but the Posi-loc taps are easy connecting to the wire harness.  For my bike, the wire colors are:  blue is gnd, blk and wht are high and low beam, yellow is parking light.  The gauge reads 0.5 V low, but when contacted, the vendor said that was within their error range.
It works great for me, and it saved my butt once when the voltmeter showed an anomaly in the system.  Forewarned, I solved it early (burnt 4-way connector under the fuel tank, a known issue for that year).
Reach out to me if you have any trouble.
« Last Edit: June 30, 2025, 12:18:27 PM by sign216 »
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Online Anomaly
Re: Voltmeter
« Reply #36 on: July 01, 2025, 03:08:21 AM »
Thanks Sign, I'll start looking...
Offline nwguy
    • Jim Gallant's home page
Re: Voltmeter
« Reply #37 on: July 13, 2025, 07:43:26 PM »
I bought this LED one from ebay after reading this thread:
https://www.ebay.com/itm/126740001066?var=427799754119
My 2 admittedly cheapo multimeters read my Bassa's battery as the same 13.23 volts after it was just taken off a battery charger. The ebay voltmeter read 12.5 volts. These measurements were taken directly from the battery's positive terminal and the grounds to the bracket for the seat release. The cheap voltmeter's wires weren't long enough to reach both battery terminals. Assuming the multimeters are accurate, the voltmeter seems so inaccurate as to be useless. I've contacted the seller. Will see what they say. In the meantime I'm off to buy a decent multimeter.
Has anyone done a direct comparison like this to see if their cheap volt meters are accurate? How far off is acceptable for you?
Online DoubleGuzzi
Re: Voltmeter
« Reply #38 on: July 14, 2025, 04:31:58 AM »
Always - though cheap multimeters can't be assumed to be accurate either. 0.2V variation is acceptable and within usual specifications, for non-calibrated/certified devices.
Offline elrealistico
Re: Voltmeter
« Reply #39 on: July 14, 2025, 06:35:29 AM »
They are cheap junk, all over the map sometimes. I used them on my Triumph, connected to switched battery voltage. would be more stable at normal RPMS, but at idle would be off and blinking.
2018 V7III Special
1978 T140V Bonneville
2004 EV Touring
Online faffi
Re: Voltmeter
« Reply #40 on: July 14, 2025, 07:37:57 AM »
I bough ten volmeters like the one in the photo, but for 12Volt, that cost not more than a dollar a piece a decade ago. They are fairly accurate.
Current bikes:
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Online faffi
Re: Voltmeter
« Reply #41 on: July 14, 2025, 07:42:09 AM »
Integrated on my then Honda 650 Deauville
Current bikes:
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline nwguy
Re: Voltmeter
« Reply #42 on: July 14, 2025, 11:46:26 AM »
I replied to the seller with these pictures after buying a Klein multimeter yesterday:
Online faffi
Re: Voltmeter
« Reply #43 on: July 14, 2025, 02:02:24 PM »
that is way off :embarrassed:
Current bikes:
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Re: Voltmeter
« Reply #44 on: July 14, 2025, 06:22:06 PM »
I just plug a small meter into my SAE tender lead.  Check it a few times during the ride.  Yes, it's not a constant read-out but it's easy to check at a stop.
https://www.amazon.com/battery-tender-081-0157-disconnect-voltage/dp/b00dj5ke9a
Do you check it with th engine running, should be approaching 14 Volts at 3000 revs
I have one of those but I prefer my always in sight LED
Re: Voltmeter
« Reply #45 on: July 14, 2025, 06:29:20 PM »
I have one of those also but prefer to have a display I can see while riding
DO you check with the engine running, should be close to 14 at 3000 revs.
I did a test on mine using a bench power supply to see when the Status lights changed.
Red (Low) comes on at 12.4 Volts and below
Amber (ok) 12.5 Volts
Green (good) 12.6 Volts and above
So from that i would say accuracy is very important.
« Last Edit: July 15, 2025, 05:50:35 PM by Kiwi_Roy »
Re: Voltmeter
« Reply #46 on: July 15, 2025, 08:47:39 AM »
Doing quick head math.....
The first three meters are all within about 1%.
That bottom meter is off by almost 10%.
To me even 5% is too far off. I would prefer even my cheap meters to be within 2%.
Offline nwguy
Re: Voltmeter
« Reply #47 on: July 15, 2025, 09:52:44 AM »
That is my opinion too. I did that math.
I did this with the engine off. Was only concerned with the meter's accuracy.
Seller's initial response:
hello,Our products are accurate.
Then:
Could you provide some picture or video to show the details?
Please do not worry, we will give you reasonable solutions after check it.
Waiting for your reply.
Have a nice day.
Now this morning:
Dear friend,
We are so sorry to see this issue.
I have received the picture you sent,
I need a little time to verify it,
and then I will report the problem to the relevant person in charge,
please wait a moment.
We will notify you as soon as we receive a reply.
Best wishes
« Last Edit: July 15, 2025, 09:55:32 AM by nwguy »
Re: Voltmeter
« Reply #48 on: July 15, 2025, 04:50:00 PM »
Then:
Have a nice day.
Now this morning:
Dear friend,
Best wishes
In other words bugger off, we have your money
The small round meter I have lines up with my+$400 Fluke 87
11.8 Volts that's indicating the battery is flat, what's the good in that?
« Last Edit: July 15, 2025, 06:11:04 PM by Kiwi_Roy »
Online DoubleGuzzi
Re: Voltmeter
« Reply #49 on: July 15, 2025, 04:59:01 PM »
..my+$400 Fluke 87
Depending on which model of Fluke 87, then:
On 40V range, Voltage DC Accuracy ±(0.05% + 1). Resolution 0.01V
That is quite some accuracy, even uncalibrated!  :thumb:
( A 4 digit reading of 14.40 could mean a true voltage of between 14.42 and 14.38. However, a 5 digit reading of 14.400 could mean a true voltage between 14.411 and 14.398, if my math serves me correctly.)
« Last Edit: July 15, 2025, 05:13:48 PM by DoubleGuzzi »
Re: Voltmeter
« Reply #50 on: July 15, 2025, 06:00:31 PM »
Online DoubleGuzzi
Re: Voltmeter
« Reply #51 on: July 15, 2025, 06:26:59 PM »
Here]s a Voltage chart
Hmm, I ain't keen on that article - too generic/general purpose and seemingly out of date.
This is better..
https://www.ecoflow.com/uk/blog/guide-to-battery-voltage-chart
Notes: unless I'm really penny-pinching, I opt for Gel/AGM batteries, though occasionally LiFePO4 (especially when I find one cheaper than an AGM!)
« Last Edit: July 15, 2025, 06:32:41 PM by DoubleGuzzi »
Re: Voltmeter
« Reply #52 on: July 16, 2025, 02:40:46 AM »
This is better..
Theres very little difference in the two charts 0.2 at 10%  0.09 at 100%
If I see 12.5 when I turn the key on your chart says it's 80% mine says it's 70% plenty of cranking available.
With the older wet cells we used to use a hydrometer but nobody ever bothered to read the temperature which is critical.
Offline SemperVee
  • USMC Retired
Re: Voltmeter
« Reply #53 on: July 18, 2025, 12:13:03 PM »
 OK, about to install same Volt meter as Roy showed onto my 07 Norge.  Planning to tap into left hand flat side up of fairing above the ABS switch to view while Riding.  I am assuming any HOT and a ground will do.  Perhaps the Starter Yellow?  Or the ABS hot connected wire close by?   Where did some of you tap into?
Thanks.
https://www.amazon.ca/Waterproof-Voltage-Digital-Voltmeter-Motorcycle/dp/B09MZHJQJX/ref=asc_df_B09MZHJQJX?th=1
« Last Edit: July 18, 2025, 12:14:20 PM by SemperVee »
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
Online DoubleGuzzi
Re: Voltmeter
« Reply #54 on: July 18, 2025, 12:48:56 PM »
Fused, direct to battery (both terminals, my preference), or from regulator output (monitor performance/faults). Alternatively switched output from ignition switch.
Re: Voltmeter
« Reply #55 on: July 18, 2025, 02:37:42 PM »
Thanks.
That will draw enough power, that it should be switched off with the ignition. (or your own switch)
Then you get into the fact that many switched wires have something on them loading them down. For example, the headlight wiring may read 13 volts even though the battery has 14 volts. You have a one volt drop in the headlight wiring, maybe, which may be normal.
Not a problem, just something to keep in mind.
Try to find a circuit that is switched (like the dashboard maybe), without a heavy load.
Offline SemperVee
  • USMC Retired
Re: Voltmeter
« Reply #56 on: July 18, 2025, 05:39:13 PM »
   Could not find the factory Aux gps wiring  to use like I had on my previous 07 Norge so I end up running a fused connection from the +battery to under the tank and will with hole saw tomorrow install the volt meter just above the ABS switch on the flat open area above it.   I like the digital blue color. Hope is shows up better than the barely readable dim dash. (yes I have them turned all the way up via dash controls).  Thanks for the info.
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
Re: Voltmeter
« Reply #57 on: July 18, 2025, 05:49:43 PM »
So on full time?
Online DoubleGuzzi
Re: Voltmeter
« Reply #58 on: July 18, 2025, 06:09:36 PM »
So on full time?
I like mine on full time: can monitor status when out & about, as well as when parked up for Winter. I use automatic battery tenders/chargers most of the time (especially the colder seasons) but it's good to know the battery state anyway. Nothing to stop one adding an inline switch - with its inherent (usually minimal) resistance i.e a small/tiny voltage drop.
Re: Voltmeter
« Reply #59 on: July 19, 2025, 02:41:40 PM »
I have a 76 Convert that hasn't been ridden for nearly 2 years I thought it would be nice to take it for coffee on Sunday, I am a member of BC Classic Motorcycle Club.
I was pleasantly surprised to find that I had wired in a digital Voltmeter. After pumping up the front tire and charging the battery I think i'm ready to go.
Because th Convert gearbox has no Neutral position I put a piece of wood under the centre stand to raise the rear wheel from the ground
It started quite easily and with a few revs on I saw 14 Volts. I will give it another run today to make sure the battery is ready.
Update. On the run out to Fort Langley I saw Voltage up to 14.2
« Last Edit: July 21, 2025, 01:20:06 PM by Kiwi_Roy »
