Author Topic: Ambo won't stay running - advice?  (Read 8626 times)
Offline neetones
« on: June 25, 2025, 02:37:29 PM »
Hi all.
I just went through this very new to me 69 Ambassador with Gilardoni cylinders. Here's what I did:
- rebuilt carbs, set screws to factory recommended settings, set initial slide sync with drill bits, checked throttle play
- changed all fluids, cleaned sludge from oil pan
- new spark plugs
- set distributor up based on factory specs, cleaned points
- checked generator belt tension
- rebuilt petcocks
- set valve clearances
So now I can get it to start on full choke but it will soon die even if it stays on choke. Won't start at all without full choke.
Here is a video: https://photos.app.goo.gl/BZ7SCLVyzATkFFc3A
Any suggestions?
1969 Ambassador
2022 V7 850 Centenario (sold)
Online Turin
Re: Ambo won't stay running - advice?
« Reply #1 on: June 25, 2025, 03:56:26 PM »
did you double up on intake manifold gaskets? intakes checked for leaks at the gaskets?
my 69 ambo ended up needing the throttle stop screws and air bleed screws being set differently from recommended specs.
1985 Sidlow Guzzi
« Reply #2 on: June 25, 2025, 03:57:39 PM »
Have you checked the cables and slides?  Set the cables.  After that check the 2 into 1 cable pull canister.  Forgot what it's called.  You'll have to synchronize the slides when they open & close.  Minor tinkering.  You'll have to take the tank off.
« Reply #3 on: June 25, 2025, 04:07:30 PM »
What size of drill bit did you use to set the baseline slide open with? A 9/32" seems to work best for me.
Did you set the float level to 24 mm +/- .5 mm?
I don't use the choke for starting in warm weather (and rarely even cooler temps), I just twist the throttle twice and start it.
Have you tested fuel flow (hoses disconnected from the carbs, into a container)?
Make sure the vent hole(s) in the gas cap are open.
Offline neetones
« Reply #4 on: June 25, 2025, 06:37:30 PM »
Thanks all. No air leaks and yes, double gaskets on the intake. Fuel flow is good on both sides.
Set baseline with 9/32" bit and float levels are good.
I did play around with the bleed screws and got it to run for a bit without choke, but it's still sputtering out.
Going to continue to adjust cables and get some even fresher gas for tomorrow's testing. Looks like I might be making some progress.
1969 Ambassador
« Reply #5 on: June 25, 2025, 06:58:04 PM »
"Bleed screws"? Idle mixture screws? I set those at 2 1/2 turns out to start and adjust for the best idle from there.
You didn't mention what jetting is in the carbs. Stock is 45 idle, 145 main, 268 atomizer, V5 needle with the clip in the middle slot, 60 slide, 80 "choke" jets.
Offline neetones
« Reply #6 on: June 25, 2025, 07:32:35 PM »
I meant to say mixture screws. I'll try setting them out a bit further than recommended. Any suggestions on where to start with the idle screws?
All other jetting appears to be stock.
1969 Ambassador
« Reply #7 on: June 25, 2025, 08:13:27 PM »
The idle screws (knurled with exposed springs) are what you should have already used to set the slide height with drill bit. The mixture screws (small, recessed into the carb body) are what I set at 2-2.5 turns out.
Offline neetones
« Reply #8 on: June 25, 2025, 08:18:24 PM »
This is hugely helpful. Thank you
1969 Ambassador
Offline neetones
« Reply #9 on: June 25, 2025, 08:36:07 PM »
I was misreading things and trying to set the idle stops via the throttle freeplay. Dummy.
It runs now with no choke but the revs start to run away when I give it some throttle. Time to do a lot of tweaking.
This forum is priceless.
1969 Ambassador
« Reply #10 on: June 25, 2025, 10:52:25 PM »
Priceless but not free, we need  :gotpics:
Offline neetones
« Reply #11 on: June 25, 2025, 11:42:59 PM »
1969 Ambassador
Online Turin
« Reply #12 on: June 26, 2025, 01:32:44 AM »
I had to do the same thing last month with my ambo. Carbs were cruddy. I let it sit due to leaky petcocks and a hand injury that left me without a usable thumb for a year. after the rebuild I had the same symptoms. It's just a matter of messing with a screwdriver.
https://www.youtube.com/watch?v=1m9YuXPIXvM
« Last Edit: June 26, 2025, 01:36:48 AM by Turin »
1985 Sidlow Guzzi
Online Tom H
« Reply #13 on: June 26, 2025, 04:06:19 PM »
I see you have it running now :thumb: I was going to mention that when you install the square slides, the large flat side goes towards the head.
"Runaway"... If you mean you give it a little throttle and then let off, close the throttle grip, the revs keep going for a few moments. I  have noticed that if the air mix screws are set a bit on the lean side, it will do something like this. But........
I would also make certain the cables are working freely (if in doubt, lube them) and do not have any very tight bends in them. Tight bends "can" cause a cable to bind. Also, if you have the cable splitter under the tank, they have been known to gum up and need to be cleaned and lubed. Sometimes just a good spaying where the cables enter the splitter (just pull the cable sheath out of the splitter a bit) with something like WD40 will help.
Just some thoughts,
Offline neetones
« Reply #14 on: June 26, 2025, 06:21:33 PM »
Thank you! Runaway throttle solved. Running pretty well now, though I'm sure more tuning will help.
My issue now is that the engine struggles to stay running if I start letting the clutch out in first. I've tried adjusting the tension - ensuring that there's some freeplay. Can't figure it out yet.
Also I've got a pretty good leak coming from what looks like the clutch pushrod seal....I'm going to have to pull the transmission to fix this, aren't I?
facebook share winner
1969 Ambassador
« Reply #15 on: June 26, 2025, 06:31:47 PM »
Remember that the shift pattern for this bike is "backwards" - up for 1st and down for the other three.
It's not uncommon for the four-speed to leak from the throw-out bearing outer body area. The outer body is sealed with an o-ring and that could be old and hardened, or there could be a groove worn into the transmission rear cover where it slides in and out. The o-ring can be replacing with am "X-ring" which seals better. If there a groove worn, that's a lot more work - the transmission needs to be removed and partly disassembled, then the bore the outer body slides in sleeved (Patrick Hayes can do that for you).
Someone has substituted a bolt for the clutch arm pivot pin and used button-head screws instead of hex-heads. How "artsy".  :grin:
Online Tom H
« Reply #16 on: June 26, 2025, 08:27:52 PM »
So how did you solve the overrun?
With what Charlie said about the O ring issue........
I would pull the trans fill plug (or even the oil level plug) and with a screwdriver, stick, Q tip or the like gently slip it into the trans to see what color the gear oil is.
Your pic makes me think it "could" be grease on the bolt (why a bolt????? unless it's a shoulder bolt with a long shoulder) dripping when hot. I guess the gear oil in the trans could drip down that way? Clean the drips/runs off and run it to see where it may be coming from. I would also change out that bolt to the correct "clevis" pin, unless the bolt has a shoulder for the arm to pivot on. You can change the bolt out without removing much. Could be done all from under, but I would consider removing the battery tray and assorted bits for better access.
Just some thoughts,
Offline neetones
« Reply #17 on: June 26, 2025, 10:44:08 PM »
I can't believe that my clutch problem was just me trying to pull away in 4th gear. 1 up and 3 down! Solved!
Took my first glorious ride around town at sunset. Transmission is clunky and I'm sure the carbs and timing could be dialed in more, but she runs beautifully.
Tom, it's definitely gear oil. I just changed it and the color is the same. I'll see about replacing that bolt with a pin and look into what it will take to pull the transmission and fix the leak. Thank you for the advice here everyone - especially you, Charlie - you saved me days of blind experimenting. Glad to be learning.
online foto maken
1969 Ambassador
Offline pehayes
« Reply #18 on: June 26, 2025, 11:06:18 PM »
The oil leak can be solved with the transmission in place.  Remove the swingarm and the throwout system will be fully exposed.  You can replace or improve the o-ring.  Good idea to check the quality of the throwout bearing.  Not a lifetime item.  If the bearing failed in a prior life then it may have torn up the inside of the rear cover bore hole.  That is much more complex to correct.
It was hard to see, but it looks like you do have vacuum ports on the intake manifolds. Can you post a picture?  If you do have vacuum ports then use those to manage the minute adjustment of carb settings.  Using vacuum comparison is much more accurate for balancing and synchronizing the carbs.
Online John A
« Reply #19 on: June 27, 2025, 12:07:13 AM »
Tight valves can cause that.
Edit  not the leaking, the poor running
« Last Edit: June 27, 2025, 11:12:57 AM by John A »
Online guzziart
« Reply #20 on: June 27, 2025, 07:55:09 AM »
Hey Charlie,
Can the the x-ring be used on Loop/Tonti 5 spd?  If so, can you recommend a size or p/n and vendor?
Thank you,
Art
« Last Edit: June 27, 2025, 07:56:08 AM by guzziart »
« Reply #21 on: June 27, 2025, 08:36:19 AM »
Hey Charlie,
Thank you,
Art
I'm sure an x-ring can be used on a 5 spd, you would just need to find the correct size to use. The size for the 20 mm outer body on early 4 spds is on Greg's website:
https://www.thisoldtractor.com/moto_guzzi_loopframe__for_sealing_the_outer_body_of_the_throw-out_bearing_assembly.html
I haven't tried one on the larger 22 mm outer body yet since it fairly uncommon for the 5 spd rear cover to wear the bore like the 4 spd. I normally use the aftermarket dual o-ring outer body anyway. This size >might< possibly work:
https://www.mcmaster.com/90025K236/
Offline neetones
« Reply #22 on: June 27, 2025, 12:13:47 PM »
Thank you! Yes, it does have vacuum ports though I need to figure out what size they are to find a nipple that will fit.
Also, just woke up to a puddle of oil that appears to be coming out of the smaller tube of the breather box. Oil level may be too high - hard to tell as I have an aftermarket engine temp dipstick.
1969 Ambassador
Online Tom H
« Reply #23 on: June 27, 2025, 02:27:37 PM »
3 Quarts of engine oil is all it needs.
The fittings should be m6X1.0 if they are factory drilled. A zirk fitting with the check ball removed works well.
« Last Edit: June 27, 2025, 03:08:21 PM by Tom H »
« Reply #24 on: June 27, 2025, 02:41:26 PM »
Are you using synthetic oil?  It could be too slippery and accelerate the oil leakage.  The same for the gear lube.  It will be clunky when you shift.  You have to shift gears with a very positive input to the shift lever.  It won't be as smooth as a Japanese bike or later Moto Guzzis.
« Reply #25 on: June 27, 2025, 03:42:27 PM »
Those clamps looked like they have "bottomed-out" before they squeezed the hose sufficiently. I use these instead:
https://www.mcmaster.com/53175k86/ Also available at auto parts stores as "fuel injection" clamps.
Like Tom H wrote: 3 qts. only (it helps the sump to drain more completely if the front wheel is raised approx. 4") and make a new mark on the dipstick.
As Tom wrote: skip the synthetics. Since the transmission gears all run on bronze bushings, I feel it is important to use GL-4 gear oil or other oils that specifically state "safe for yellow metals" on the label.
Online Tom H
« Reply #26 on: June 27, 2025, 05:55:22 PM »
On the GL-4.....
Charlie.....What brand are you finding GL-4 from? StaLube used to be readily available, now seems only GL-5.
Lucas clams to have a GL-5 conventional gear oil that says in a spec on it that it is safe for yellow metals. It was reasonably priced, so I gave it a shot for my R75's and Guzzi 4 speed.
« Last Edit: June 27, 2025, 05:56:07 PM by Tom H »
« Reply #27 on: June 27, 2025, 06:43:24 PM »
On the GL-4.....
I had been buying the CRC Sta-Lube as well. To tell the truth, it's been so long since I've needed any (rarely any Ambos through the shop lately) that I haven't kept up with what's available.
Online Moparnut72
« Reply #28 on: June 27, 2025, 07:29:36 PM »
Also any gear oil approved for a NV 4500 5 speed manual transmission  in a 1st generation Dodge with a Cummins engine will be fine. I used a Pennsoil product in mine but I don't remember which.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #29 on: June 27, 2025, 08:38:02 PM »
