Author Topic: Monza/Le Mans-inspired V9 Project  (Read 17332 times)
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: V9 Project
« Reply #30 on: July 21, 2025, 07:01:02 AM »
Reading this article and seeing a video about this build they had to modify the rear drive somehow, which is not clear, but it wasn't a bolt on job.
Yeah, I spoke with him briefly yesterday. He said it was the only part they had to make from scratch for their builds.
« Last Edit: July 21, 2025, 08:36:54 AM by Dirk_S »
Offline Aldo
  • "Ton-Up"
Re: Monza/Le Mans-inspired V9 Project
« Reply #31 on: July 21, 2025, 08:12:39 AM »
Great looking bike, really love how it came out!
What did you do regarding the fuel pump etc? Is everything external now or did you modify the Monza tank?
Online Dirk_S
« Reply #32 on: July 21, 2025, 08:45:23 AM »
I bought a used external system off an early 00s EV big block. The one I bought had the regulator that runs inline with the pump and filter, but then I bought a tank-fitted regulator and placed on the right side petcock fitting. Using a high-flow manual petcock on the left.
I’d love to install an in-tank setup. Maybe one day, but I don’t know if I can avoid the internally welded nuts part. Might have to bite the bullet there.
BTW, big shout-out to Charlie @ Antietam Classic Cycle for helping me LOADS with the fueling system.
Offline DoubleGuzzi
  • '08 750Breva; '19 V7III CS; '79 V50;(Triumph S400)
« Reply #33 on: July 21, 2025, 04:51:34 PM »
I wonder if pop rivet captive nuts (blind rivet nuts) would be a good alternative - easier than welding? There are versions with an integrated seal.
« Last Edit: July 21, 2025, 08:21:28 PM by DoubleGuzzi »
Nearly natural progression.. SS50, Z200, Z250B, Z400J, (H100), GT750, K100, ZR1100, 900 Trident, 955 Sprint ST, (ZR550, M600), 900 ST, (B750), V7III CS, (V50II).
Online Dirk_S
« Reply #34 on: July 21, 2025, 08:26:34 PM »
RIVET NUTS ARE A THING!? With a seal, that could indeed be an enticing option.
Offline DoubleGuzzi
« Reply #35 on: July 22, 2025, 03:49:30 AM »
https://www.huyett.com/blog/what-is-a-blind-rivet
I assume these ones are expensive:
https://www.boellhoff.com/gb-en/news/2021/blind-rivet-nuts-and-studs-with-integrated-sealing-solution-rivkle-seal-ring/
https://www.gesipa.co.uk/products/technologies/g-sealed-blind-rivet-nut/
https://www.bossard.com/eshop/global-en/rivet-technology/blind-rivet-nuts/closed-end-blind-rivet-nuts/tubtara-dpx/p/25108/?category=02.200.200.10&index=26&q=%3Arelevance#tab-features
Shop around.  :wink:
IF the fuel pump flange seal fits around the perimeter, outside the retaining bolt holes, then you'd likely get away with not needing the sealed rivet nuts. You may get dribbles of fuel sitting in the flange void though. YMMV
A while back, I bought a boxed assortment from AliXpress, for my various farkles. Non-specific/generic rivet nuts tend to have a larger minimum contact area though i.e. the material thickness that you want to attach them to.
« Last Edit: July 22, 2025, 04:12:11 AM by DoubleGuzzi »
