Author Topic: Rubber on Exhaust  (Read 10016 times)
Offline Rad1o
Rubber on Exhaust
« on: July 16, 2025, 06:08:46 AM »
Hello,
I have a Stelvio E5. The exhaust on the right hand side has a somewhat flimsy heat shield which probably could be longer. I must have had my boot resting on it when I moved my feet back once or twice and some rubber melted off the sole and transferred onto the exhaust. Now it is burnt in and dark black charcoal. I tried turpentine with not much luck.
Is there anything that would easily take the rubber off without scratching the exhaust?
Online PeteS
Re: Rubber on Exhaust
« Reply #1 on: July 16, 2025, 06:18:20 AM »
I use wet Brillo pads on chrome. Won’t scratch it or stainless though if the stainless is oxidized it may
Brighten it and you might have clean the whole exhaust to match.
Offline Vagrant
« Reply #2 on: July 16, 2025, 06:47:47 AM »
Razor blade paint scraper.
Online n3303j
  • Ron Cichowski
« Reply #3 on: July 16, 2025, 08:10:37 AM »
Get it good & hot then rub hard with a 100% cotton cloth.
Also works when plastic bag blows onto headers en route.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online Perazzimx14
« Reply #4 on: July 17, 2025, 12:27:41 PM »
Oven cleaner is also said to work.
Online jcctx
« Reply #5 on: July 17, 2025, 02:00:16 PM »
Starter spray and a rough cloth rub has worked for me in the past. This also works for many spot cleaning chores; of course do not spray on hot exhaust!!!!!
Offline Turin
« Reply #6 on: July 17, 2025, 06:21:47 PM »
I've used oven cleaner . get the pipes hot first. Spray on and wipe off with a wet towel
1985 Sidlow Guzzi
Offline slowmover
« Reply #7 on: July 17, 2025, 10:32:06 PM »
I tried everything to get a melted plastic bag stain off. Eventually the extreme heat of the pipe just vaporized it away.
« Reply #8 on: July 17, 2025, 11:05:54 PM »
I’ve found that after some heat cold cycles it gets brittle when cold and a sharp non metallic scraper gets it off with minimal cosmetic damage to the pipe. I prefer a hard wood scraper
Offline vintagehoarder
  • Cycle Hoarders
  • Ride to Eat, Eat To Ride
    • Facebook Page
« Reply #9 on: July 18, 2025, 02:45:34 PM »
I agrree get them hot use a triple up cotton towel to wipe it off one hot m then once you get it off Mothers mag and alum polish will finsih the job!  Don't ask me how i know :grin:
Cyclehoarders Garage
2022 Honda CT125 Trail Cub
2018 Triumph Tiger 800
2014 Moto Guzzi V7 Speical
2009 Vepsa GTS 250 ie
1977 V1000 Convert
1969 Yamaha YAS1C
2027 Vespa GTS 310 Super
LaGrange, KY
Online AJ Huff
« Reply #10 on: July 18, 2025, 02:59:41 PM »
I just leave it.
Because I know I'll put my boot on them again. 😀
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
Offline BrianK
« Reply #11 on: July 18, 2025, 03:52:53 PM »
Oven cleaner does work.  Learn from my mistake - spray it on a cloth and then rub onto the pipe.  Don't spray! - you'll overspray and take paint off cases, etc.  Ax me how I know!
