Author Topic: 72 Eldo misfiring (?)  (Read 11869 times)
Offline BrianK
« on: July 18, 2025, 11:11:39 AM »
Looking for suggestions.
72 Guzzi Eldorado, well-maintained albeit all-too-seldom ridden.
Stored without gasoline last winter, drained the tank as best I could, turned off the petcocks, drained the float bowls.
This season, have only ridden a couple times but having issues.
Starts up and runs fine, mostly.  But intermittently it will feel, for a few seconds, like it's running out of gas - and then zooms back as though reserve had been opened.  Neither is the case.
Pulled the plugs and the right looks fine, left is carboned up a bit.
Replaced plugs, same result.
Checked plug wires, fairly new NGKs, they both ohm out nicely to ~5K ohms.
"Feels" like an electrical problem, although I know 95% of electrical problems are in the carbs, or is it vice-versa?
Still trouble-shooting but would welcome any thoughts.  May have the mechanical blinders on.
Thanks as always folks. - BK
Offline normzone
Re: 72 Eldo misfiring (?)
« Reply #1 on: July 18, 2025, 12:21:13 PM »
I had the exact same bike, and the exact same problem.
It drove me mad as I tried all the logical fixes.
Finally figured out that itsy bitsy teeny tiny rust particles from the tank were getting past the inline fuel filters I'd installed and collecting in the float bowls, where periodically a few of them would jump up into the jet and clog it momentarily.
My solution was creme coating the tank, and it solved all. These days I would probably acid wash it or something, I missed the fuel capacity the creme coat displaced.
I guess your verification of this would be pulling the bowls and looking for tiny hints of rust.
« Last Edit: July 18, 2025, 12:22:52 PM by normzone »
« Reply #2 on: July 18, 2025, 12:22:58 PM »
Could be a wiring problem. An intermittent open in power to the coil or a short in the points wire.. Could be condenser or coil failing. Intermittent problems are where the fun is . Check for fuzzy fuses , I found with that type of fuse they can grow fuzz on the ends so I just rotate them without taking them out. Could be a float needle sticking . Watch it run in the dark so you can maybe see if spark is escaping from plug wires. Could be a plugged tank vent. You’ll find it….
Offline eldointheweeds
« Reply #3 on: July 18, 2025, 12:42:58 PM »
Had the same issue on a long trip in 1984 so my memory may be fuzzy. Fixed it by pulling the bowls and poking a sewing needle though the jets.
Offline BrianK
« Reply #4 on: July 18, 2025, 01:31:46 PM »
Some good suggestions; thanks folks.
I can rule out the cap vent - tried that first thing, got gas on my pants and no change in bike behavior!
The rest, I will start working through....   Fun stuff.
Offline pehayes
« Reply #5 on: July 18, 2025, 01:36:57 PM »
There are pencil-diameter filters inside the fuel tank on top of the petcocks.  Remove and clean.
There are coin-sized disc filters on the side of the carburetor (DelLorto).  Remove and clean.
Blow vigorous air through every carb port.
« Reply #6 on: July 18, 2025, 02:47:41 PM »
Might help to just clean points w/a soaked card. Check off the list. Check off the list----------do a shot, by the time you get done, you'll need a rest.
Offline BrianK
« Reply #7 on: July 18, 2025, 03:22:07 PM »
Thanks all.  Working my way through the list....  Wish me luck.
« Reply #8 on: July 18, 2025, 04:56:17 PM »
Thinking about this... Others have mentioned very good starting points.
I would take a close look at the carbs with the bowls off. A dry bowl can get a dried build up on whatever is inside. Could be a float or float needle sticking or a bit of debris going through the jets. As mentioned, carefully using jet cleaning wire tips or a sewing needle or the like I would clean the jets. Heck once the bowl is off, just pull the jets for the cleaning. Then while they are off, take some carb cleaner and squirt it in the holes where the jets go.
Offline normzone
« Reply #9 on: July 19, 2025, 12:23:32 AM »
I remember those - the rust particles I was battling were small enough to get past both of those, AND some aftermarket inlines I installed.
OP's description of the issue sounds as though it may be the petcock/carb filters described.  :popcorn:
« Reply #10 on: July 19, 2025, 11:05:55 AM »
The only carbureted bike I have left is a V65 with PHF 30’s. Every so often the tank screens and the inline filters and the screens on the carbs get plugged enough to cause running problems. Mostly at idle but it is something I have to clean once or twice a year, especially because it’s not ridden much.
« Reply #11 on: July 19, 2025, 11:58:10 PM »
Could well be rust in the tank plugging the petcock filtersCan you remove the tank swill around the fuel and dump it into a bucket via the fill hole to see if there/s any rust
Offline BrianK
« Reply #12 on: July 21, 2025, 01:16:16 PM »
Might be double posting.... anyway, just ran a bore scope down the troubled cylinder.  Check out the cylinder wall.  Trouble?
Offline BrianK
« Reply #13 on: July 21, 2025, 02:09:42 PM »
Note, those are Nikasil cylinder liners.
I ran the borescope in because I pulled the plug and while the ground strap looked dry (mighty black though) the insulator looks shiny.
Starting to think rings or valve guides may be the (or "a") culprit.  Not a whiff of oil in the exhaust, at least that I can tell.
Offline BrianK
« Reply #14 on: July 21, 2025, 02:17:48 PM »
PS, checked points, they look fine and gap was perfect.
Removed and cleaned the fuel filters (Pingels).  Even before cleaning they were flowing just fine.
Test drove afterwards and no real change in the phenomenon.
Offline n3303j
  • Ron Cichowski
« Reply #15 on: July 21, 2025, 02:25:32 PM »
Any chance a float is sinking / needle not sealing and a bowl over filling? That will cut a cylinder.
Also isn't that bike distributor cap & rotor? Are either of those marginal?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline BrianK
« Reply #16 on: July 21, 2025, 03:13:49 PM »
Floats are definitely on my to-check list.  I hope it is something that simple.
Yes, it's a distributor and rotor set up.  They seem okay to me, just checked them and they look okay to me.
Another shot of the cylinder.   Note "discolorations" on the cylinder walls (!)
« Reply #17 on: July 24, 2025, 12:39:26 PM »
It’s my opinion that the engine is fine, especially if it has decent compression. The problem is either fuel , air or ignition. Keep checking and you will find it without yarding cylinders and heads off .
Offline BrianK
« Reply #18 on: July 25, 2025, 10:58:06 AM »
Thanks John.  Coincidentally I just came in from the garage, where's today's ten minutes consisted of checking compression.
Cold engine, throttle wide open, ~195 left cylinder (the troublesome one!), ~160 right.  Wouldn't swear by the absolute numbers, but same gauge should be consistent between cylinders I should think.  Kind of a troubling difference in compression but numbers aren't horrible, and again, the suspect left cylinder is the better of the two in terms of compression.  Bike does start up easily and runs as it always has, been bouts of misfiring or whatever the heck is happening.
Back to ignition (condenser?) and carbs (floats?).
Appreciate everyone's input and moral support!
Tx - B
« Reply #19 on: July 25, 2025, 11:12:33 AM »
Tx - B
New-ish condensers are failure prone, fortunately there are lots of alternatives.
https://www.thisoldtractor.com/moto_guzzi_loopframe_condenser_cross-reference.html
https://www.crustycycle.com/products/copy-of-moto-guzzi-ngk-ignition-coil-ambassador-eldorado-v700-12716500
If the floats are the white ones, you might find gas inside them. Even 50 year old used ones are better.
Offline BrianK
« Reply #20 on: July 30, 2025, 11:29:24 AM »
Pulled the lefthand (troublesome) carb floats, they seem fine - older black ones, don't seem to be taking on any gas.  Adjusted them to lower the fuel level a bit, no change in the misfire.
Doesn't seem to be an issue with too little gas.  Maybe too much but if so not finding the cause.
I have one of those new-fangled capacitors from Crusty coming, will give it a try but I wouldn't think a failing condenser would only affect one side as is my problem.
Frustrating.
Offline BrianK
« Reply #21 on: August 04, 2025, 11:22:06 AM »
It was the bloody plug wire!  Second thing I checked and it ohmed out fine.  Just did it again before binning the thing - ohms out nicely.  But replacing it instantly cured the problem.
This is a lesson I should already know, but I guess I had to learn it again.
As the saying goes, "YMMV."
Thanks all.
Offline guzziart
« Reply #22 on: August 04, 2025, 11:48:42 AM »
Yeah, I had an issue a few months ago luckily for me it was something simple....bad plug cap.  I've since replaced the 5k ohm caps with non-resistor caps and tossed resistor plugs into those bikes.  Glad you resolved the misfire.  My problem manifested itself at the 2500-3500 rpm range.
Offline BrianK
« Reply #23 on: August 05, 2025, 04:21:31 PM »
By the way, I received one of those Crusty Cycles capacitors Charlie mentioned (https://www.crustycycle.com/products/copy-of-moto-guzzi-ngk-ignition-coil-ambassador-eldorado-v700-12716500).  No need for it at present but I'll put in the spares box.
But I tested it with a multimeter and got no ohm-reading nor continuity reading between the mounting tab (the case is plastic of some sort, none conductive, so I assume the mounting tab, which is metal, is ground - ?) and the lead that connects to the points.
Does that sound right?
Tx - B
