Plugs on PHBH30 carburetor body
Topic: Plugs on PHBH30 carburetor body (Read 4875 times)
Pescatore
July 19, 2025, 06:20:09 PM »
I've cleaned this plug on the carb body 3 times now, to convince myself that it is leaking.
It's more of a wheep, after long rides. Both carbs are doing it.
What is it for? Can it be replaced?
Internet wisdom says it's an expansion plug that you set with a punch.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
guzzisteve
"Just Ride It"
Re: Plugs on PHBH30 carburetor body
Reply #1 on:
July 19, 2025, 07:29:12 PM »
That is the breather for the bowl, may be a small hole that pukes fuel. Have a close look hole will face down. Some had a tube there or strait across on back side.
Look in the well, up at bottom of that pressed in cap, should be a hole in it.
Last Edit: July 19, 2025, 07:33:08 PM by guzzisteve
Pescatore
Reply #2 on:
July 19, 2025, 09:21:45 PM »
Thanks guzzisteve, I just found this, #10
So gas is evaporating out of the hole?
I guess there's no stopping it.
Last Edit: July 19, 2025, 09:22:45 PM by Pescatore
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
guzzisteve
"Just Ride It"
Reply #3 on:
July 20, 2025, 07:59:12 AM »
If the float is set correctly, maybe some dribbles.
