Author Topic: What did you do last?  (Read 6159 times)
Online mhershon
« on: July 22, 2025, 04:02:08 PM »
Over the weekend, I changed the engine oil in my '14 V7, that's a single throttle body model jus' so you know, and washed the bike - gently, with a garden hose. I rode it today with my m/c club. During the ride, occasionally the engine would try to quit on first opening the throttle under load. It did it several times. The bike has 57,000 miles on it and has been boringly reliable, never a skipped beat. If I got water somewhere washing it, where would I look? Or what else would I check? It runs great at steady throttle and pulls like a (40hp) train. Starts and idles just like it always did. All suggestions gracefully accepted...
Re: What did you do last?
« Reply #1 on: July 22, 2025, 04:38:11 PM »
Spark plug boots and crankshaft position sensor.
Online mhershon
« Reply #2 on: July 22, 2025, 05:06:00 PM »
Kev, as you may recall, this is Cam's old bike. It has NGK plug caps. I don't even know where the crank position sensor is... Under the alternator cover?
« Reply #3 on: July 22, 2025, 05:18:49 PM »
I do recall but poop happens over time or if manhandled.
Crank sensor I think is top front left of case (unless that's big blocks?).
« Last Edit: July 22, 2025, 05:19:11 PM by Kev m »
« Reply #4 on: July 22, 2025, 06:25:38 PM »
Saw that issue a few times while at Hamlin's on the early bikes like his.  And mine!
The plug boots can get "worn out".  Nothing is made like it used to be.  Try spraying WD 40 into all handlebar controls, too.
Online mhershon
« Reply #5 on: July 22, 2025, 09:54:35 PM »
I'll spray the plug caps and all the stuff on the bars. Thanks!
« Reply #6 on: July 23, 2025, 04:06:34 PM »
Maynard, it’s got the better plug boots.  I’ve always used cleaner spray/wax on my bikes.  Never a hose.  Now you decide to break my old bike?
« Reply #7 on: July 23, 2025, 06:35:13 PM »
Cam,
I have most likely the same replacement boots.  Changed them at Jim's after Gerry's bike crapped out the ECU when it got wet.  What a mess!
Anyway, you and I have seen stranger things than boot failure.  Maynard should at least check them.  Gotta start simple and go from there.
« Last Edit: July 24, 2025, 12:27:22 AM by kingoffleece »
Online mhershon
« Reply #8 on: July 23, 2025, 07:12:29 PM »
Good to hear from you, Cam! Guys, I checked the battery bolts and they are tight. So are the ground straps. I sprayed the handlebar switches. I pulled the plastic covers and the plug caps, checked that the plugs were tight in the heads, and they were. I sprayed the nice NGK plug caps and reinstalled them carefully. I lifted the sweet saddle that Cam put on the bike and checked underneath. All is well there. I'll ride the bike tomorrow and report progress, if any appears. I feel bad about having a problem with Cam's old bike, but it has never been abused, not in my hands. As I mentioned in the original post asking for help, the bike has been remarkably reliable, barring the final drive leak, healed by Jim Hamlin's capable hands. Watch this space for an update...soon!
« Reply #9 on: July 24, 2025, 12:28:36 AM »
May just turn out to be water got somewhere and eventually worked itself out.
Let us know............... ....
« Reply #10 on: July 24, 2025, 04:02:57 AM »
Just kidding with you buddy!  I know it’s in very capable hands.
Online mhershon
« Reply #11 on: July 24, 2025, 12:37:09 PM »
Rode my bike this morning, out Morrison Road past Red Rocks (yes, THAT Red Rocks) out to Evergreen, Colorado, and you wish you'd been on that ride with me on that road on a lovely 75-degree Rocky Mountain foothills morning. Whatever we did cured whatever was wrong, and the bike ran great! I have to conclude that as someone suggested, water got in someplace and either the WD-40 dried it out or it evaporated out and now the thing works fine. Thanks for your help, all of you! Cam, you know you can tease me all you want; after all, you sold me a great bike...
Online Scott Carpenter
  • Banjo playing secular humanist who reads a lot
« Reply #12 on: July 28, 2025, 12:15:49 PM »
The V7 community is a good one by the looks of it. Glad i've joined up.  :bow:
"The Dude abides. I don't know about you but I take comfort in that. It's good knowin' he's out there. The Dude. Takin' 'er easy for all us sinners."
« Reply #13 on: July 28, 2025, 03:54:12 PM »
I’ve posted this before, but I’ll do it again.  Maynard bought my ‘14 special sight unseen.  He did get photos and my meticulous maintenance records.  He did a fly and ride from Denver to NJ to pick up the bike.  He shipped his riding gear to me in advance.  I mapped out the return trip the long way.  Skyline drive, BRP, Cherahola, etc.  over 2000 miles and about 5 days later he was home.  And all that in his late 70’s.  Mad respect.
« Last Edit: July 28, 2025, 04:11:32 PM by Cam3512 »
Offline Huzo
« Reply #14 on: July 28, 2025, 09:01:35 PM »
I would have suspected contaminants in the TGPS.
What did Guzzidiag say ?
Online mhershon
« Reply #15 on: July 30, 2025, 09:19:25 AM »
Huzo, I sprayed everything with WD-40 and the problem disappeared. I confess I am not sure what the acronym TGPS stands for or where that item is on my bike, but it is running great.
