Author Topic: carbtune nipples missing  (Read 3303 times)
Offline DAM650
  • DAM650
  • ain't conversation if you're doing all the talking
« on: August 24, 2025, 10:33:11 AM »
good morning
anyone know what and where I should buy for a 2013 NTX?
got the carbtune with the bike, but it's missing the little nipples
thx in advance
DAM
2013 NTX
2002 R1150R
2002 F650GS
Re: carbtune nipples missing
« Reply #1 on: August 24, 2025, 11:01:05 AM »
It there a line running from L to R intake manifolds? That is where you attach hoses.
They also make this in 5mm--------------------------------------------
https://www.denniskirk.com/tecmate/carbmate-brass-m6-threaded-adapter-ts-204.p283050.prd/283050.sku
« Last Edit: August 24, 2025, 11:08:41 AM by guzzisteve »
Offline Bulldog9
« Reply #2 on: August 24, 2025, 11:06:12 AM »
good morning
thx in advance
DAM
I just pull the vacuum lines for the evap system off the nipples.
MGNOC#23231
« Reply #3 on: August 25, 2025, 12:11:59 AM »
Tips from a mig welder can be used. Get the ones with the appropriate metric threads and they screw right in.
Offline DAM650
  • DAM650
« Reply #4 on: September 04, 2025, 05:30:42 PM »
thanks all, i got some off of amazonica.
time to replace the exhaust gasket, grease the swingarm bearings and dogbone needles, and of course do another quick valve check (they were spot on), then balance the TBs.
ran a 2K trip last week up to Mountain Grove MO, crafted a twisty .gpx file using AI, what a time saver.
bike ran like a top, avg about 37 mpg fully loaded, rattled my laminar lip and running light loose running down some dirt roads and blew out her o ring about 100 miles from home.  was sh!tting my pants thinking that i was loosing the top end until i stopped and found the exhaust leak.
what a mile eater.
DAM  :bike-037:
2013 NTX
2002 R1150R
2002 F650GS
« Reply #5 on: September 06, 2025, 09:28:18 PM »
Buy a pack of 6mm grease zerts.
Take a file to the threaded end until the spring pops out then push the ball out as well.
Now you have a nipple for carb balancing.
