Author Topic: GuzziDiag - file not found  (Read 1174 times)
Offline SemperVee
  • USMC Retired
« on: August 24, 2025, 12:33:36 PM »
  Going in circles... On Macbook OS High Sierra O/S 10.13.   GD works fine on Norge - Yes I have the correct read and write files for both.  On 2003 EV ...  READ file for 2000> Cali is 15M PF3C but it won't find it then when it does does will not "read".    Moved over to the Norge, selected correct ECM and file and all works as it should?   Making me crazy now.... EV starts and runs fine. No lags but I believe it is a bit on the rich side. wanted to hook up to GD to read and  adjust CO trim for fuel..
Finally got my HB mounts and bags installed yesterday along with +1in up and back risers and new battery & tires. Guzzi WS works fine for me at freeway speed luckily but guzzidiag is making me crazy...I have opened GD and file from both desk top and applications to no success.  Looks to save but file does
 not turn off FI and fails.
« Last Edit: August 24, 2025, 12:39:05 PM by SemperVee »
53 years of Street Riding - All Brands
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
Online antmanbee
Re: GuzziDiag - file not found
« Reply #1 on: August 24, 2025, 07:12:47 PM »
Does a 2003 EV use a 15RC ECU? I thought that they did. If so make a different selection in the set up.
Offline SemperVee
  • USMC Retired
« Reply #2 on: August 24, 2025, 07:20:37 PM »
I started with that selection per the GD instructions as it is FI not carbed as the Tutorial instructs but that makes no difference nor any other model?  It's a conundrum?
« Last Edit: August 24, 2025, 07:21:42 PM by SemperVee »
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
« Reply #3 on: August 24, 2025, 07:35:58 PM »
No 15"M"
IIRR select "2001"?" >" and if the correct Com Port is selected it will work on a PC at least!!!
Offline SemperVee
  • USMC Retired
« Reply #4 on: August 25, 2025, 12:28:45 AM »
No 15"M"
 Not so  much.  I only show 1 port on Windoze and that is the one selected.  On the MAC is is the USB that is being seen, no problem   My options are GD <2000 & >2000, Besides the 2000 p.i. (Fuel Injected).   One is pre year 2000 and one is post year 2000 on Mac version GD V46 and V60
« Last Edit: August 25, 2025, 12:38:54 AM by SemperVee »
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
Online DoubleGuzzi
  • '08 750Breva; '19 V7III CS; '79 V50;(Triumph S400)
« Reply #5 on: August 25, 2025, 04:03:47 AM »
Given that you get on better with the Mac - which the software isn't developed for - then my usual advice to boot Linux Mint from an USB pendrive seems appropriate. However, if you only have one USB port, you'll need to install Mint alongside the other OS(es).
Nearly natural progression.. SS50, Z200, Z250B, Z400J, (H100), GT750, K100, ZR1100, 900 Trident, 955 Sprint ST, (ZR550, M600), 900 ST, (B750), V7III CS, (V50II).
Offline SemperVee
  • USMC Retired
« Reply #6 on: August 25, 2025, 09:55:15 AM »
Nuts to that. Movin on
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
Online DoubleGuzzi
« Reply #7 on: August 25, 2025, 06:05:14 PM »
Can lead a horse to water..
 :violent1:
Offline SemperVee
  • USMC Retired
« Reply #8 on: August 25, 2025, 08:52:46 PM »
 :violent1:
  Thanks anyway but Not going off on a "Wild Goose" chase with yet another operating system I know nothing about.  Be helpful with realistic answers.
« Last Edit: August 25, 2025, 08:57:52 PM by SemperVee »
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
Offline moto-uno
« Reply #9 on: August 27, 2025, 03:39:12 PM »
  If my memory serves me it was made kinda clear in the beginning to use windows .
Got myself a used win 7 notebook and succeeded in getting guzzidiag to install the CPU remapping and all was fine .
It was no walk in the park with win7 , so I can't imagine what it'd be like with a Mac ! But Guzzidiag was a great piece of software
for my 2018 Eldorado .
« Reply #10 on: August 27, 2025, 03:58:48 PM »
I have had that work 1st on a Vista I have for VDSTS, screen don't work. 2nd worked fine on my W7 and I even had VDSTS working on the W7, NOW W11 and still works fine. If you get older laptop you need the older software #. I started out using DIAG IAW software before there was GuzziDiag and swear by these guys software, it just works for me. There is ways to make it work, I have had to go into properties & change bit speed to get the VDSTS to work & a different serial adapter.
This morning I was thinking to put it on my MAC Air & see what happens. Might learn something.
Offline SemperVee
  • USMC Retired
« Reply #11 on: August 27, 2025, 07:08:17 PM »
  IT works on my Norge.  No workee on my EV...  Dunno why?    I have an old Macbook and a new Windoze 11.   Splain that!
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
« Reply #12 on: August 27, 2025, 07:41:21 PM »
Ok, download on the MAC & driver and it won't open either one. What a piece of crap. I don't use it, was a Bday present. So O called my tech sister and told her HA she says she's not an engineer. WTF One reason not to learn anything new
EDIT:  There isn't a usb port on the MAC no wonder it won't work, junk for what I do
« Last Edit: August 27, 2025, 09:14:12 PM by guzzisteve »
