Author Topic: Ducati Voltage Regulator  (Read 1934 times)
Offline wirespokes
« on: August 28, 2025, 10:36:38 AM »
I'm in need of a Voltage Regulator for the permanent magnet system. I can find replacements for $32 and then there's the OEM for $150+.  Should I avoid the cheaper alternative? Are they durable and long-lived?
Do any of you have a good used one you'd sell?
Offline wirespokes
Re: Ducati Voltage Regulator
« Reply #1 on: August 28, 2025, 02:36:27 PM »
I've got another regulator here, but it's got seven leads rather than 6. Is there a place that explains what they are and whether it'll work for me?
« Reply #2 on: August 29, 2025, 08:08:43 AM »
Some have a ground, some just use the case. Some have a second battery wire, some have a single. You need a drawing.
Offline wirespokes
« Reply #3 on: August 29, 2025, 09:59:07 AM »
It's a simple potted item with ten horizontal fins. The leads exit top. Starting from the left -
white
brown
black
white
red
green
There are no markings on it anywhere.
I believe that it had been connected previously with only the red, black and three whites.
white
« Reply #4 on: August 29, 2025, 12:21:50 PM »
https://www.euromotoelectrics.com/category-s/1846.htm
This may show a diagram. I’ve bought regulators, starters and parts from them with good results
Offline Don G
« Reply #5 on: August 29, 2025, 12:35:57 PM »
I have used Drag Specialty's HD Big Twin regulators as replacements to good effect. DonG
Offline Stevex
« Reply #6 on: August 31, 2025, 01:26:44 PM »
I replaced my Aprilia RSV Tuono reg rec with a used Honda CBR1000 Shindengen mosfet. I connected the outout direct to the battery withe the +ve wire fused. Works perfectly.
