Author Topic: ring gap spec  (Read 1603 times)
Offline realgone
ring gap spec
« on: September 05, 2025, 01:10:24 PM »
Hello, I am installing a set of Meteor/Caber nikasil big bore cylinders and pistons on to an Eldorado.
Is the spec for the ring gap as per shop manual, or is it different for these kits?
thank you
1970 Ambassador
1985 California II, sorta
Online RinkRat II
  • Lake Powell AZ
Re: ring gap spec
« Reply #1 on: September 05, 2025, 02:08:58 PM »
 Doesn't show a gap spec just says there ready  to go. I personally would run .004" per inch of bore on cast rings. My $.02.
     https://www.meteorpiston.com/installation-instructions
     Paul B :boozing:
Re: ring gap spec
« Reply #2 on: September 05, 2025, 02:25:13 PM »
Wont the rings come already gapped for the cylinder kit?
Re: ring gap spec
« Reply #3 on: September 05, 2025, 04:21:12 PM »
For Nic cyl  mm     .40-.65 compression rings    mm .30-.60 on oil scraper  Strait out of Sport 1100 book           is what it is
85 Cal II 1000cc Nic compression mm.30-.45   oilscraper  mm .25-.50
« Last Edit: September 05, 2025, 05:21:45 PM by guzzisteve »
Offline realgone
Re: ring gap spec
« Reply #4 on: September 06, 2025, 03:49:06 PM »
Thank you Steve and Rat
1970 Ambassador
