Hello, If you've ever replaced the oil pressure sensor, what tool did you use to tighten it? I've found nothing so far that fits. It's a 15/16" (24mm) wrench, but any wrench with that opening is designed for much higher torques. I'm considering making something out of flat scrap. I reall;y don't want to drop the engine TIA.
You might want to double check the size of the sender. If it's a Guzzi one not automotive aftermarket, IIRR it's 21mm, at least for most models.Tom
There's a tube sticking down from the left rear corner of the air box. Is this the aperture for the drain hose? I think the hose may have dry-rotted and fallen off. I don't remember taking a hose off that area of the box. There was a short rubber collar on it when I went to start the re-installation process.
