Author Topic: Norge Extended Oil Stick  (Read 6476 times)
Offline Haioku_Mantan
« on: October 04, 2025, 03:12:48 AM »
Went down the rabbit hole looking for an extension after trying to check the engine oil level today.
That sure is a lot of plastic and bolts that need to be undone just to get a hand in.
After browsing multiple posts and forums, there seems to be a few options but none are in stock.
First is the original 2008 onwards updated pull stick https://harpermoto.com/products/oil-stick-978496
Next is the Stucchi Luigi oil extension which doesn't seem to be sold anymore, even under their new website: https://officinestucchi.it/en/
Same with the TLMS one (but this one is not recommended because of leakage)
There is a DIY method which involves destroying the original cap:
Any other kits or sources to try to get one shipped to Asia?
Current:
'07 Norge
Previous:
'07 Honda Deauville
'12 KTM SuperMoto
'94 ZZR 400
'92 ZZR 1290
'92 Bandit 250
Offline Pescatore
Re: Norge Extended Oil Stick
« Reply #1 on: October 04, 2025, 11:44:18 AM »
It's a struggle even with the pull stick.  Filling is a pain.
As you probably noticed, people permanently remove the lower fairing.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Online SemperVee
  • USMC Retired
« Reply #2 on: October 04, 2025, 12:54:43 PM »
 One of the main reasons I cut VroomHilda's skirts off...  Easy access and she looks so much lighter.. Mine was early 07 without even the hole to slip in dip stick!
:laugh:
« Last Edit: October 04, 2025, 12:57:31 PM by SemperVee »
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
Offline PJPR01
« Reply #3 on: October 04, 2025, 02:02:09 PM »
You can fill easily by removing the fairing at the back side where the two bolts attach to the other body panel, gently pull it forward and get a large socket on the plastic threaded portion, it undoes with very little pressure.
Then a long necked funnel and you're good to go...takes about 5 minutes to take off the panel/screws and black threaded insert.
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
« Reply #4 on: October 04, 2025, 03:36:28 PM »
I put a Teo Lamers addition on mine immediately when I got it.
Access just below the spark plug cap.
« Reply #5 on: October 04, 2025, 06:56:53 PM »
The way you have that muffler routed is *chefs kiss* and it seems to still have space for the saddlebag - perfection.
One of these days I need to get a muffler shop to mandrel bend me an extension.
Current:
'07 Norge
Previous:
'07 Honda Deauville
'12 KTM SuperMoto
'94 ZZR 400
'92 ZZR 1290
'92 Bandit 250
« Reply #6 on: October 05, 2025, 12:45:05 AM »
The top bend is 90 mm PCD and bottom is 110 mm PCD.
« Reply #7 on: October 05, 2025, 04:39:57 AM »
Actually this is a better shot of the pipe and the oil dipstick mod.
Really, I don’t know why you’d not just get a red Norge 2 VPC when looking for a good tourer, I’ve had mine 17 years from 2007 and I’ve never been tempted to sell it.
« Last Edit: October 05, 2025, 04:40:38 AM by Huzo »
Online Bulldog9
« Reply #8 on: October 05, 2025, 08:30:30 AM »
Huzo,
That dipstick is slick. How do you fill on a change?  The Gen 2 Norge (8V motor) has a screw in insert where the plug goes for the dipstick. I remove it for filling. Has anyone tried to adapt it? Not sure if the plug and insert  have the same threads.
Interesting that you moved the mirrors to the fairing.  I did that with my 2014 Mahogany Brown Norge, too many years with them fixed to the fairing on the FJR & C10 Concours.  I've never seen anyone else do it. I traded that in in 2019 for the MGX 21, and keep wondering if the bike will ever surface on the forum.
« Last Edit: October 06, 2025, 03:29:28 PM by Bulldog9 »
MGNOC#23231
