Author Topic: Source for rebuilt PHF30 carbs? (Mille GT)  (Read 4214 times)
Offline baloo
« on: October 07, 2025, 10:19:40 AM »
89 Mille GT - I'm tired of messing with my carbs, and thinking there's a source for already rebuilt PHF30 (stock) Dellorto's, right?
Any recommendations where to find a pair of these?
I can rebuild carbs, but I've got too many other projects (cars) that need the attention!
Re: Source for rebuilt PHF30 carbs? (Mille GT)
« Reply #1 on: October 07, 2025, 10:23:38 AM »
There are shops that can rebuild them, but I don't know of any that offers rebuilt ones for sale. New PHFs are available though.
Offline baloo
« Reply #2 on: October 07, 2025, 10:27:28 AM »
Shops to rebuild... any recs in the Houston area?
It's likely that any shop can rebuild a carb (even I can), but if finessing is involved, I just don't wann spend any more time on this bike.  Sorry Guzzi lovers, but too many things pulling me in other directions.  I just want to bolt them on, start it up and ride to run errands.
I don't even have time for "cruising".
Thanks.
« Reply #3 on: October 07, 2025, 10:34:29 AM »
Even if you find rebuilt carbs or someone to rebuild them, it still won't be "bolt them on, start it up and ride", adjustments will be necessary for it run right.
Offline baloo
« Reply #4 on: October 07, 2025, 10:41:20 AM »
Charlie,
Only adjustments should be air/fuel mixture needle, right?
...well maybe throttle cable.
« Reply #5 on: October 07, 2025, 11:23:50 AM »
Charlie,
Balance at idle and sync when opening the throttle, idle mixture screw adjustment.
Online monkeyodeath
« Reply #6 on: October 08, 2025, 12:21:59 PM »
Seems like the most obvious answer that requires the least time is to take the bike to a mechanic who can rebuild the carbs and get them adjusted. Then you can show up at their shop and ride away.
"Finessing" is kind of part of the deal of installing carbs, no?
Offline baloo
« Reply #7 on: October 08, 2025, 12:50:27 PM »
Yah, guess I knew that all along (take to mechanic, and finessing being part of the job) -- just hoping for some magic.  I'm too overwhelmed with the numerous car projects begging to get done, so I'm looking for an easy fix on the bike.
My unfortunate and 51% of the time experience with mechanics has been bad -- I end up fixing what was fixed, or fixing what they screwed up, or fixing the real problem myself -- but paying far too much for their errors or for parts that really did not need fixing.
OF COURSE, every mechanic bitches about the previous mechanic who worked on the car/bike, and swears they do not do such sloppy and inept work -- until I get the vehicle back from them; THEN I hear how this and that was so screwed up on the bike that it was the best they could do, or that they found 10 other problems associated with the problem, OR while they were there, this or that needed to be fixed or the bike would have xploded, etc.  I should have started documenting the excuses starting back in 1972.
Ultimately it ends up I could have done the job myself, with the same (or better) results.  It's also how I learned so much about working on cars over the decades.
Tell me, some of you know exactly what Im talking about.
Offline bigbikerrick
« Reply #8 on: October 08, 2025, 12:51:44 PM »
Listen to Charlie,and monkeyodeath.   :thumb:
Rick.
« Reply #9 on: October 08, 2025, 04:43:15 PM »
You could go to MPH, isn't any better, pay & go ride.
Online Turin
« Reply #10 on: October 08, 2025, 06:54:03 PM »
I don't know of any source of remanufactured Dellorto carbs. Dellorto Direct doesn't seem to be around anymore.
MPH's website https://mphcycles.com/
1986 Sidlow Guzzi
1996 Triumph Daytona 900
Offline DaGootz
« Reply #11 on: October 08, 2025, 08:01:19 PM »
What can go wrong with them where they need "rebuilt"? ...unless someone was in there hacking things up. or water in the bowls, or you need external work like syncing/idle adjustment like Antietam Cycle said.
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #12 on: October 09, 2025, 04:09:55 PM »
I guess the diametral difference between slide and carb-slide-bore can become sloppy; the accelerator pump ramp on the slide can become worn?
Can someone turn them into 32mm carbies by fitting new slides in bored-out bores, and opening up the air-flow passage to 32mm?
« Last Edit: October 09, 2025, 04:10:56 PM by Cdn850T5NT »
1985 Eurospec 850 T5 NT (Nuovo Tipo - New Type... i.e. Series III)
Offline Frenchfrog
« Reply #13 on: October 10, 2025, 08:29:48 AM »
opening them up is not as simple as it sounds ...and it leaves the slide bore untouched.
New PHF's are still available ...I bought several sets a while ago.
Offline baloo
« Reply #14 on: October 10, 2025, 11:04:24 AM »
MPH!  Thanks.
Offline baloo
« Reply #15 on: October 10, 2025, 08:16:34 PM »
Passages possibly logged with lacquer (bike sat), and tiny grit in bowls.
Online Turin
« Reply #16 on: October 10, 2025, 09:50:09 PM »
Go buy your local auto parks store and buy a gallon pale of Berrymans Chem dip carb cleaner. Take one apart and soak for 24-48 hours. blast clean with carb or brake cleaner. It's $30.00 and some time. Cheaper that a new set of carbs.
1986 Sidlow Guzzi
Offline Walton
« Reply #17 on: October 10, 2025, 10:32:03 PM »
Herdan's. If you talk to Herm he'll send you proper jets, needles, slides or needle jets to correct the problem. He had new carbs as well and will send jetted and ready to go.
https://herdancorp.com/
« Last Edit: October 15, 2025, 10:23:18 AM by Walton »
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #18 on: October 12, 2025, 01:17:51 PM »
Unless I'm mistaken in interpreting your response...I had said opening up the airflow bore to 32mm and boring/changing slides...? There is also a guide for the slides to refit too. Anything else, other than jetting, needles?
Offline Frenchfrog
« Reply #19 on: October 13, 2025, 06:33:02 AM »
Raceco UK (long gone now) used to offer this service, taking PHF 30's to 34 mm which is the optimal size for small valve heads, and some of the laverda lads have done it too but from what I understood the bore cannot be done concentric to the original ...the new enlarged bore has to be offset upwards or the atomiser /needle jet placement gets buggered.Maybe also the idle circuit too as this goes back a few decades now but it's certainly not as simple as you would think.By the time you have done that (at some expense ) you still have a worn slide and the only replacements are slightly different to the old pattern so they need to be modified which then leeds to getting a satisfactory idle  virtually impossible as the tabs for the screws are then too high.Old pattern slides are made of inobtanium now.
New carbs are expensive but on the other hand necessary if the bike is to run nicely and properly....and still available at the moment.That is likely to change as demand cannot be very high anymore.
Offline brider
« Reply #20 on: October 13, 2025, 05:55:57 PM »
Maybe I missed it somewhere, but what is the reason for the need for rebuild? I read lacquer possibly, and particles in the bowls, but have you merely tried pulling the bowls and spraying carb cleaner up thru every orifice you can find, removing slides & float & needle & use low-pressure compressed air to clean things out and see how she runs? Kind of basic suggestions I know, but dialing in new carbs vs cleaning out existing which may ALREADY be dialed in seems 50-50, with less work (IMO) involved trying to clean existing.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Offline wirespokes
« Reply #21 on: October 16, 2025, 10:48:39 AM »
Jets don't need replaced, only cleaned out. They get gunked up, along with passages. Flowing gasoline doesn't wear out brass jets.
Get a Harbor Freight ultrasonic and some simple green and clean em out.
Look, carbs are really very simple, and actually fun to work on. All you need to understand about carbs is that air traveling through the carb creates low pressure. Since the float bowl is at normal air pressure, the fuel is pushed up the jets into the air stream in an attempt to equalize pressures (nature always wants things to balance out).
If you can think with that, carbs are a snap to understand. Oh, and one other thing - use the correct screw driver - one the fits the slot. That IS important.
