Author Topic: dog leg clutch lever  (Read 5973 times)
Offline turboguzzi
« on: October 11, 2025, 09:20:23 AM »
Hello All.
Trying to find a dog leg clutch lever that fits the original perch (see pic ) on my 1983 SP 1000 to match the brake lever which i did find
does it even exist?
tnxs
Link to brembo 1027062 dog leg brake lever
https://www.ebay.it/itm/357452332943?var=0&mkevt=1&mkcid=1&mkrid=724-53478-19255-0&campid=5338727090&toolid=20006&_trkparms=ispr%3D1&amdata=enc%3A1AuHS2g3RSQmyBvOrXMBG4w6&_ul=IT&customid=Cj0KCQjwgKjHBhChARIsAPJR3xe0bfR44X0wUNz2y2YDfgGyth_jytzzALyt1fbRGyNyL6OBGVeQDloaAgfaEALw_wcB|0AAAAADihhqUk5Efi8URGfcivsikBLjKCb|Cj4KCAjw3aLHBhBbEi4AmX3MNu8j7bfaBWcq0fkHo4rRZ_b6Z6DwM7PspX_uWuYaN7lilkk_89HrzU0hGgLv7A&gclid=Cj0KCQjwgKjHBhChARIsAPJR3xe0bfR44X0wUNz2y2YDfgGyth_jytzzALyt1fbRGyNyL6OBGVeQDloaAgfaEALw_wcB&gbraid=0AAAAADihhqUk5Efi8URGfcivsikBLjKCb&wbraid=Cj4KCAjw3aLHBhBbEi4AmX3MNu8j7bfaBWcq0fkHo4rRZ_b6Z6DwM7PspX_uWuYaN7lilkk_89HrzU0hGgLv7A&loc_interest_ms=&loc_physical_ms=9207046&adtype=pla&gad_source=1&gad_campaignid=22852324485
Re: dog leg clutch lever
« Reply #1 on: October 11, 2025, 11:28:50 AM »
There was a guy here not long ago was looking for the same thing.
Offline turboguzzi
« Reply #2 on: October 11, 2025, 02:58:24 PM »
Tnxs steve,
Do you remember if he nded up finding one ?
could find the post, so if you happen to remember the name, let me know.
for the time being, looks unaobtainum
Online bmc5733946
« Reply #3 on: October 11, 2025, 05:00:15 PM »
Maybe something here.
https://dominoracing.com/shop/domino-classic-lever-perch-systems/
Maybe not the original perch? But could work!
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline turboguzzi
« Reply #4 on: October 12, 2025, 01:41:26 AM »
tnxs
i did find Domino's complete page of levers, the original Guzzi levers are the two under "Anticorodal levers" in the center.
I think that if there was a dog leg, Domino would be making them, but they dont....
But they do a host of others, for 12$ ill try to see if any of the "Aluminium Left Levers" can be modified to suit, they are just a bit different around the pivot ear.
https://www.domino-group.com/tommaselli/en/levers-on-road.html
Offline Stevex
« Reply #5 on: October 16, 2025, 10:33:38 AM »
They are out there. I fitted one to my LM2 to go with the PS15 brake master cylinder dog leg I fitted after de linking.
I got it from Gutsibits in UK.
Have a look through these:
https://www.gutsibits.co.uk/pr/TheShop/index.php?q=clutch+lever&f=d&Model=0&search=SEARCH
« Reply #6 on: October 17, 2025, 07:39:34 AM »
Thanks for the Domino link, found the choke lever for one of the bikes and it only cost a little over $6 bucks but it cost $32 bucks to ship it from Europe.
Offline turboguzzi
« Reply #7 on: October 17, 2025, 11:06:44 AM »
well, its local to me.... i checked and regretfully there is no cheaper options these days.... otherwise would have helped....
Offline turboguzzi
« Reply #8 on: October 17, 2025, 11:20:01 AM »
Well, the MC lever exists and has a Brembo PN
The clutch lever SP I has is the one on top of second pic.
There is good info there about the pin to cable ferrule distance (F31mm), so ordered the one on the bottom that has F30
Will need to modify it the red arrow area as they are not the same, will tell you how it went
« Reply #9 on: October 17, 2025, 02:58:22 PM »
Thanks, it isn’t that important as the lever I have works but the tip is broken off from a crash many years ago. I never knew it could be purchased separately or I would have bought it years ago.
Offline turboguzzi
« Reply #10 on: October 27, 2025, 05:19:11 AM »
Well, it's done, and boy what a difference in comfort and effort! Highly recommended
I think the pictures are self explanatory so wont add much text
The front brake is just a swap, order a BREMBO 10270622 lever
Clutch needs Mcgyvering, order a DOMINO 1661.61 lever, make a small template, a few hacksaw strokes and its done.
Cheers
TG
Offline turboguzzi
« Reply #11 on: October 27, 2025, 05:21:09 AM »
Offline turboguzzi
« Reply #12 on: October 27, 2025, 05:22:19 AM »
« Last Edit: October 27, 2025, 07:35:35 AM by turboguzzi »
