Author Topic: Rubber u-joint boot for EV1100  (Read 229 times)
Offline nwguy
    • Jim Gallant's home page
« on: October 15, 2025, 11:41:38 AM »
The rubber u-joint boot on my 99' Bassa has a tear in it, possibly from me overtightening the forward hose clamp after installing the swing arm a while back. I noticed a small amount of oil on my garage floor below this. That's how I found it. Here's the part from MG Cycle:
https://www.mgcycle.com/index.php?main_page=product_info&products_id=829
Probably good to replace it based on its age regardless of the tear. I'm curious as to how oil is getting there. Seals prevent oil from the pumpkin flowing up there. Is it transmission oil that's coming out? Wondering what oil level to check to determine if significant amounts leaked out while riding.
Re: Rubber u-joint boot for EV1100
« Reply #1 on: October 15, 2025, 11:57:58 AM »
The "pumpkin" is not sealed from the driveshaft, so oil/oil vapors can flow from it into the swingarm. It's also not uncommon for oil to leak from the output shaft of the transmission. Despite Guzzis best efforts it still happens on even the last of the five-speeds.
Offline n3303j
  • Ron Cichowski
« Reply #2 on: October 15, 2025, 06:38:19 PM »
The sealed (2RS) U-Joint carrier bearing keeps the transmission oil in the front section of the swingarm and the final drive oil in the rear.
I always get a bit of oil in both sections. I think this actually helps extend the life of all the internal components.
BMW had a reason for filling the /2 swingarm with oil.
I just finished replacing a torn boot on my T3 about an hour ago. Good chance to clean that whole area.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline JoeB
« Reply #3 on: October 16, 2025, 05:26:49 AM »
While the swing arm is off take a good look at the carrier bearing. I had a few miles on unpaved roads at the time, and the tear on the boot must of let some dust through. No symptoms riding but didn't feel completely smooth when inspecting.  Replaced the bearing and u-joint for peace of mind. Had a copy of 90's Guzziology where he advised adding an ounce or two of fluid in it before clamping it down. Helps keep things moist and lubed in there and any further leakage should be spotted early on.
« Reply #4 on: October 16, 2025, 06:28:11 AM »
The oil can transfer from front to back, my Cal2 does this! Even though the sealed bearing holds in it's lube the splines of ujoint & driveshaft let the oil pass. Level in my trans goes down & rear drive goes up.
Offline Moparnut72
« Reply #5 on: October 16, 2025, 07:18:20 AM »
The swing arms on the /5's also had oil in the swing arms. The final drive seal failed on mine which resulted in an over filled rear drive rather then the other way around. With the short framed bikes the swing arm pointed downhill quite a bit which also "helped" with the jacking effect. Anyone who complains about the jacking and torque reactions on a modern Guzzi should go ride an early Airhead. Sorry for the thread drift.
kk
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
Offline n3303j
  • Ron Cichowski
« Reply #6 on: October 16, 2025, 07:52:34 AM »
Last U-Joint I bought for T3 had blind spline holes. It was an intimate fit in the carrier bearing so there was no oil transfer. OTOH I overfill final drive. Oil is good. More oil is gooder. Doesn't leak past seals. Doesn't overheat. So I'm guaranteed full lubrication.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #7 on: October 16, 2025, 08:30:08 AM »
believe as you wish.
Offline n3303j
  • Ron Cichowski
« Reply #8 on: October 16, 2025, 09:11:48 AM »
Believe nothing.
100,000 miles actual experience seem pretty conclusive.
Your results and your machines may vary.
« Last Edit: October 16, 2025, 09:23:39 AM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline nwguy
« Reply #9 on: October 16, 2025, 09:20:44 AM »
Interesting stuff. Good to know.
I've only put a few hundred miles on my Bassa after doing a lengthy restoration since April when I bought it. During that I did pull the shaft, clean everything, and reseated the main bearing after punching some divots in it with a metal punch so it wouldn't rotate. Guess I get to do that again.
Offline n3303j
  • Ron Cichowski
« Reply #10 on: October 16, 2025, 09:23:16 AM »
What "main bearing" are you putting divots into with a punch?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #11 on: October 16, 2025, 09:51:50 AM »
I'm not here to boast on my bio but some here know it.
