Author Topic: Lowering idle speed on V11 Bassa  (Read 1272 times)
Offline nwguy
    • Jim Gallant's home page
« on: October 31, 2025, 09:43:58 AM »
My Bassa idles close to 1,500 RPM after my last tune up attempt. What is the correct way to lower the idle speed? I've reviewed Jeff B's and Bike Boy Brad's tune up documents and I'm thinking it's adjusting the air bleeds while using my Carbtune balancer. Correct?
Re: Lowering idle speed on V11 Bassa
« Reply #1 on: October 31, 2025, 10:45:08 AM »
Not when I tune, I set air screws at a contant like 3/4 turn open. When you open them up it makes mixture leaner, one reason I keep at a constant for both cyls. For mixture yuo use software and buttons.
« Last Edit: October 31, 2025, 11:18:17 AM by guzzisteve »
« Reply #2 on: October 31, 2025, 11:06:31 AM »
The info I have from the factory at that time says 1/2 turn on both air bleeds for that bike. Basically what Steve indicates.
Then set the high speed balance with the screw on the linkage. And the idle balance and speed with the two idle stops.
Make sure the 'choke' lever setup is not holding the throttle open at idle.
Online RinkRat II
  • Lake Powell AZ
« Reply #3 on: October 31, 2025, 11:16:28 AM »
    Top notch tutorial here......https://www.v11lemans.com/forums/topic/19610-decent-tune-up/           My $.02.
     Paul B  :boozing:
Offline normzone
« Reply #4 on: October 31, 2025, 05:24:46 PM »
You are clearly more tech than I am, but the best results I consistently got from my Bassa resulted from air filter changes. I'm going to assume your tuneup included that.
Offline nwguy
« Reply #5 on: November 01, 2025, 09:29:39 AM »
Yes it did.
