Author Topic: Rescuing a Cali 1100?  (Read 6176 times)
Offline toomanybikes
« on: November 01, 2025, 05:29:30 AM »
I'm toying with the idea of rescuing an '02(?) Cali 1100. Seller says the engine is frozen due to "a rat's nest being sucked into the cyls through the intakes."
which leads me to a few questions ...
1. Is that even possible? I don't see how anything "large" would get past the valves.
2. If so, might it cause serious damage? Possibly a bent valve if the nest caused a valve to stick open.
3. If there was no real damage are parts reasonably available? I've rescued many bikes and have owned three guzzi's, but none that old.
Thanks much. Any other input welcome. Normally I would just do it, but I'm tall and would likely be cramped on the 1100, so would mostly be doing the rescue as a project to flip.
Re: Rescuing a Cali 1100?
« Reply #1 on: November 01, 2025, 07:49:36 AM »
Get & fix it, you'll like it. Most likely bent valves from being stuck open. Lots of parts available, most everything for motor.
Offline nsmith
« Reply #2 on: November 01, 2025, 04:37:35 PM »
Remove plugs use borescope. If price is very right go for it. They ain't hard to make go again.
Neil formally from South Dakota now living it up in Arkansas
« Reply #3 on: November 01, 2025, 04:51:51 PM »
blow it out with air
« Reply #4 on: November 01, 2025, 05:48:13 PM »
If the motor is frozen, you'll be into it for way more than it's worth.
JMHO,
Offline pehayes
« Reply #5 on: November 01, 2025, 06:53:40 PM »
To reach the valves, the nesting material would have to get past the air filter.  Have to pop off the tank and then the filter box top to inspect that route.  Was he running with no filter????
Online Turin
« Reply #6 on: November 01, 2025, 11:22:45 PM »
If you're looking to flip a bike for any kind of profit, look elsewhere.
1985 Sidlow Guzzi
« Reply #7 on: November 02, 2025, 04:48:45 AM »
Yes, I often flip bikes, sometimes for a profit, sometimes not. It's a hobby, not a business. The rescue is the enjoyable part.
« Reply #8 on: November 03, 2025, 07:57:25 AM »
Just keep in mind that a very good condition '02-'04 California EV can be bought for $3,000 - #3,500.
Offline kidsmoke
« Reply #9 on: November 03, 2025, 01:21:36 PM »
Not sure how tall is tall, but with saddle manipulation and boards, these can accomodate a leggier rider.
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
« Reply #10 on: November 07, 2025, 10:08:15 AM »
UPDATE - Someone else may have snagged it. Not sure since the ad on FB marketplace is being flaky.
I suspected the "seized" engine wasn't as bad as the seller assumed, but it was too far away (suburban Atlanta) for me to check out easily.
Congrats to whomever got it, maybe someone on here?
https://www.facebook.com/marketplace/item/1475885013387321?ref=saved&referral_code=null
« Last Edit: November 08, 2025, 05:26:04 AM by toomanybikes »
Online Turin
« Reply #11 on: November 08, 2025, 08:44:59 AM »
For what it's worth, I'm 6'3 with a 34" inseam and I fit on my Cali just fine. They are very good bikes.
1985 Sidlow Guzzi
« Reply #12 on: November 09, 2025, 05:18:02 AM »
I already have an Audace, so the rescue project aspect was the interesting part. Bikes already sold so a Cali 1100 is no linger on my radar ... unless another interesting project comes up.
