Author Topic: 1974 Eldo Police Rebuild...Having Fun!  (Read 43549 times)
Offline DaGootz
« on: November 10, 2025, 09:23:36 AM »
  So, I didn't want to hijack Dave Swanson's thread of "1974 Eldorado Rejuvination" so I'm starting my own. Dave has been very helpful to this point and I thanks him for that. I purchased this 1974 Eldo Police from the son of the previous owner after the Father passed about four years ago. The Father lived in California so I know the bike is a Cal. Police bike. The son had it stored in Baltimore, I answered the ad so here I am. I always thought Moto Guzzi's were cool bikes, not having never ridden one, I just liked the design. I've owned BMW's for the last 26 years, both opposed twin and flying brick, putting close to 250k on them. I've had motorcycles since 1970 and had formal motorcycle mechanic training and worked in several motorcycle shops in the 70's and 80's.
  I wanted to ride this bike so badly after I purchased it but you guys here talked me out of it and told me to inspect and check the cylinders and pistons for wear and the dreaded chrome flaking of the cylinders. I did all that and am grateful to you guys to point these things out. At this point the bike is down to the frame, engine out, heads off, forks and triple tree disassembled. I'm not going into a total restoration to the point Dave did, which is absolutely gorgeous, but I just want, at this point, to get it mechanically sound and dependable. The lack of attention to detail on this motorcycle in the past has led me to a total disassembly and inspection of this poor bike. The first thing I did was rebuild the front wheel with new bearings and install a bearing spacer it didn't have, if it's not supposed to have one it does now. Then a rebuild of the front caliper and master cylinder. I lengthened the braided brake line for better routing.
  The engine was then removed, cleaned, sludge trap cleaned and sits ready for re-assembly. I'm looking at a Stein-Dinse oil filter conversion kit for it right now....thoughts? The rear end was very tight, so I'm leaving that alone for now. I did have to replace a u-joint that had excessive movement. The front forks are being rebuilt with new 10mm seals and Wirth progressive springs and dampers, the forks were a mess and assembled incorrectly. I have new steering head bearings and races going in also. New bearings were installed in the generator and the cross-threaded shaft has been repaired and new hardware installed. Transmission bearings and shifting feel good so I'll leave that for now. There's chrome hardware everywhere, I hate chrome hardware. So much is flaking off I have to be real careful when I'm handling hardware. I'll be replacing a lot of hardware with zinc coated bolts and locking nuts where I can....thoughts? I had custom ignition wires made, distributor is tight. I'll need to re-wire the bike and also go LED on bulbs and H4 headlamp.
  So I'm saving the big items for last, the cylinders/pistons and valve job. Okay, that's it for now, thanks for reading. Feel free to comment and guide me where your expertise may help this Guzzi Noob....much appreciated.
Offline Aldo
Re: 1974 Eldo Police Rebuild...Having Fun!
« Reply #1 on: November 10, 2025, 12:21:17 PM »
I personally wouldn't bother with an oil filter kit.  I don't have one for my Eldo, I just a use a good quality oil and change it more often.
You can a get stainless hardware kit from Stainless Cycles to replace your existing stuff:
https://stainlesscycle.com/wordpress/product/moto-guzzi-eldorado-ambassador-stainless-kit-bolts-screws-kit-loopframe/
For electrical/wiring if you decide to replace, I highly recommend Greg Bender's custom harnesses built to spec:
https://www.thisoldtractor.com/for_sale_wiring_harness.html
« Last Edit: November 10, 2025, 12:24:35 PM by Aldo »
MGNOC Lifetime Member
1973 Eldorado 850
1971 Ambassador 1000 Automatic
1960 Gilera Giubileo 98
1967 Benelli Sprite 125
« Reply #2 on: November 10, 2025, 07:38:52 PM »
Yes, there is supposed to be a spacer in between the front wheel bearings. Do note that only one bearing is fully seated in the carrier and secured by a circlip - the other one is installed flush and is allowed to float.
I would recommend replacing the seals and o-rings in the transmission, along with the shift return spring. The original spring is prone to failure, Guzzi redesigned it at least 2 times before they got it right.
At the same time, I would replace the clutch with the "SD-TEC" kit that has deep splines on the hub. I would also recommend the throw-out bearing outer body with two o-rings. I will send you a set of six o-rings for the clutch pushrod for free - I'll just need your address. They are far superior to the hard plastic tube that was original and the "upgrade" rubber cones that came after that.
Offline DaGootz
« Reply #3 on: November 11, 2025, 08:46:00 PM »
Thanks Aldo. I have a lot of Mobil1 15-50 I use for my BMW K1200RS. What are your thoughts on using that? Thanks for the links, I'll check them out, pretty sure I glance through ToT wiring guide a few weeks back......I've been immersed in so much Guzzi information I have to take a break sometimes.
Offline DaGootz
« Reply #4 on: November 11, 2025, 08:59:54 PM »
Yes, there is supposed to be a spacer in between the front wheel bearings. Do note that only one bearing is fully seated in the carrier and secured by a circlip - the other one is installed flush and is allowed to float. Ahh, I did install a clip, thought someone left one out. Should I remove it or will it be ok? I believe it was the left side if I'm not mistaken...Thanks
  Do you have any info on the clutch parts you're talking about. Can you give me the Guzzi part numbers please and I'll look them up on my parts guide .pdf. I see MG is out of stock on the clutch kit. How about all those clutch tools MG has....are all those really needed? Thanks
« Reply #5 on: November 12, 2025, 09:14:10 AM »
One bearing needs to float, so the spacer should be long enough that one sits flush with the carrier and the other fully inserted.
Here's the dual o-ring outer body: https://www.mgcycle.com/index.php?main_page=product_info&cPath=193&products_id=4793
Clutch from the source: https://www.stein-dinse.com/en/moto-guzzi-clutch-set-with-locking-plate-new/item-2-1078679-200033302+-.html Unfortunately, it will be hit with tariffs... Might be back in stock at MG Cycle and Crusty Cycle soon though.
The tools aren't absolutely necessary - you can use the clutch hub (with a suitable spacer and bolt) to align and compress the clutch plates.
Shift return spring: https://www.mgcycle.com/index.php?main_page=product_info&products_id=1011
Offline DaGootz
« Reply #6 on: November 13, 2025, 09:28:49 AM »
Thanks Charlie. With regard to the front wheel spacer, here's what I did. I purchased the recommended spacer from McMaster-Carr suggested by This Old Tractor and had my buddy cut it down to the correct length posted by Gregory. I got it home and went to install it and, because I'm a Guzzi noob, it appeared too long so we cut it down until we could get the newly purchased snap ring to fit. So it sounds like you're telling me the original spec would be good, remove that snap ring and go with that. I bet that's why my axle hole on the right side was partially covered when it was tightened down......that would make sense as it was drawn too far to the nut side when tightened. With all the things I'm finding mechanically incorrect with this bike I assumed some one left out the snap ring, since they left out the spacer.
Any alternative tool source for the clutch hub nut? That's a real bite paying $60 for a tool you won't use often.
Offline kidsmoke
« Reply #7 on: November 13, 2025, 09:50:49 AM »
Sounds like a great project. Good Luck!
Pictures always welcome for those of us following along.
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
« Reply #8 on: November 13, 2025, 05:12:46 PM »
The dimension (76 mm long) on This Old Tractor is correct. As I wrote previously, one bearing will be fully inserted and secured with a circlip and the other will be flush, or nearly so, with the outer edge of the bearing carrier.
You can make your own clutch hub nut tool - an old socket of the appropriate diameter and an angle grinder or even a hacksaw. Or modify a tool purchased on Amazon to work as shown here:
https://www.thisoldtractor.com/moto_guzzi_loopframe_clutch_hub_securing_nut_tool_14912600.html#option_2
Here's information on the bolt size needed to use the clutch hub as an alignment and compressing tool.
https://www.thisoldtractor.com/moto_guzzi_loopframe_clutch_plate_spline_alignment-_centering-_and_pressure_plate_compression_tool_-_using_a_clutch_hub_and_a_bolt_-30906500-.html
Here's a photo of the spacer Les Price made:
Offline DaGootz
« Reply #9 on: November 14, 2025, 08:36:59 AM »
Thanks again Charlie. I ordered one of those tool from Amazon that was recommended on TOT, and I'll dig into the other link you sent.
Getting back to the front axle spacer. What was Guzzi's thought process with regards to the left bearing being a "floating" bearing? I took the front hub apart yesterday and the spacer my buddy made came out to 70.22mm. My buddy Gil was with me and I decided to just make a 6mm spacer from the leftover McMaster-Carr tube and reinstall it. Gil asked why couldn't we just leave everything the same, bearing in place with the snap ring like the right side, and put the 6mm spacer on the outside of the left bearing? This will allow the front axle to still seat at the proper distance.....unless Guzzi decided the wider stance of the bearing is needed for stability or tracking reasons. Thought's?
« Reply #10 on: November 14, 2025, 08:39:53 AM »
I've been asked that question more than once and really don't have a good answer. If Lino Tonti was still alive we could ask him...
Offline DaGootz
« Reply #11 on: November 14, 2025, 10:04:59 AM »
That darn Lino just had to take that secret with him...
Offline DaGootz
« Reply #12 on: November 19, 2025, 08:46:13 AM »
I spoke with Greg at This Old Tractor and he said about the same. He stated he didn't think the 6mm difference was that big of a deal and to try it with the bearing snap-ringed in place, so that's what I'm going to do, I made a 6mm spacer so I'll put that on the outside of the bearing between the nearing and axle....easy enough to reverse it if needed down the road.
Offline DaGootz
« Reply #13 on: November 23, 2025, 06:28:26 PM »
 I tore into the transmission last week to check how things were, since I can't trust anything the previous owners did. All the proper spacing worked out pretty go, except the layshaft is .011" short, if I can leave it I'll leave it. The two shift forks show some wear, like .010" (Striker fork 1-2-3-4 gear forks) 14230501. I found one for sale but I'm not paying $300 for one fork....or even two....KMA! I may have the welded and re-ground, I have people that can do that. Is .010" in tolerance? I couldn't find a spec on minimum thickness.
 Installed the rebuilt front forks on Saturday...YAY! Finally! The forks were bent a little but the triple tree was also bent, nothing lined up. Thanks to Charlie for offering up a straight lower tree but we got it straightened. So I installed new progressive would springs from MGCycle, along with damper inserts. Had to buy a tap/die set for the two top fork plugs and had to straighten some other parts from improper installation by the cavemen.
 Also installed the rebuilt front caliper and master cylinder but need a 90 degree banjo coming off the master cylinder, didn't like how it was originally routing the brake line, so I have that coming. Later guys! I'll get pictures once I sync my phone to my PC.
« Last Edit: November 24, 2025, 02:55:30 PM by DaGootz »
Offline DaGootz
« Reply #14 on: November 25, 2025, 09:15:06 AM »
This is exactly what I ran into with my fork delima, I finally got straightened away. So next time your triple tree is out, check it for straightness. https://youtu.be/ZX1fXmeTbAk?si=07SajviHcKg1TuqS Since the bike showed no signs of a crash, I wonder if they were coming out of the factory like this. These lower triples are strong, so being bent in an accident would take a lot, since the fork tube are much softer and take most of the impact, me thinks.
« Reply #15 on: January 06, 2026, 04:18:10 PM »
I'm glad to see you are heading down the right path with your Eldo.  They are worth the effort.
Offline DaGootz
« Reply #16 on: July 01, 2026, 07:42:46 AM »
I posted this in the "General" section so thought I'd post it here too.
"He Gang, Slowly restoring my 1974 Eldorado Police and the ignition switch boot was missing when I bought it. I've been looking for one but no luck and I thought the one from McMaster Carr is way over price but I did find this inexpensive rubber boot from Amazon. Try this link- https://a.co/d/0b4dhhai if it doesn't work then copy and paste this description in your Amazon search bar- ( Set of 5 - Motorcycle Scooter Wire Harness Loom Connector Covers - Large - Fits Honda Kawasaki Yamaha Suzuki ) without the parentheses. This connector cover is the largest they sell at 38mm and will fit over the ignition switch which I believe is 41/42mm with no heat, just work it around with a small diameter pick/screwdriver and best if you take the switch out of the holder to maneuver the boot on. It fits great and looks good. Any questions let me now. Later!
Offline DaGootz
« Reply #17 on: August 20, 2026, 12:07:31 PM »
Anyone have original spark plug/coil wires lengths for making a new set? I had a guy at Scott Wires in Mooresville make me a set last year but they are resistor wires and I want to go to the braided copper core wires. He built the set off the one that were on the bike when I bought it and I don't think they were the correct length. I'm going to have Ton's make me a set and I'd like to have the correct oem specs. Thanks
Offline wirespokes
« Reply #18 on: September 18, 2026, 11:04:56 AM »
Make  your own. It's not difficult. You can buy solid copper plug wire from Napa or ebay. NGK spark plug caps used to be the way to go, but they're now NLA, though you can find new old stock. I'm sure there are replacements now - probably from China. As for the distributor end, those parts are also available from NAPA. It's an easy job and no reason to farm out the work.
Offline Roman Hordan
« Reply #19 on: October 07, 2026, 05:04:28 AM »
Wirespokes is right that it's an easy job, and if you do build your own, the wire lengths on a loop frame are forgiving enough that you don't really need OEM specs. Run the wires with the plug caps on and the distributor cap in place, leave a little slack for engine movement on the rubber mounts, and route them clear of the exhaust and the cylinder fins. Then cut to fit on the bike, each one a couple of inches longer than the straight-line distance.
If the first set came out wrong because it was copied from old wires, that might just mean the previous owner's wires weren't right either, so measuring on the bike is a better reference anyway. Once you've crimped the ends and checked each wire for continuity, you're done.
