Author Topic: is this a lemans 1 head? im a bit stumped  (Read 343 times)
Offline amamet
« on: November 13, 2025, 03:51:44 PM »
The numbers dont correspond to lemans heads numbers but the manifold takes 6mm bolts. whatcha think?  found this in stash of old parts I have
thx
allen
Online PeteS
Re: is this a lemans 1 head? im a bit stumped
« Reply #1 on: November 13, 2025, 04:37:43 PM »
It appears to be a LM1 head. How deep is the squish band. It appears to be pretty shallow. Many think .040” is minimum height.
Online Frenchfrog
« Reply #2 on: November 13, 2025, 05:07:09 PM »
To confirm you just need to check the valve sizes....certainly looks LM though
Offline amamet
« Reply #3 on: November 13, 2025, 05:10:34 PM »
its bare, no valves.  what else can I measure like it is?
Online PeteS
« Reply #4 on: November 13, 2025, 05:23:38 PM »
The diameter of the valve seats. Should be slightly over 44 and 37 mm.
« Last Edit: November 13, 2025, 05:27:46 PM by PeteS »
Offline Turin
« Reply #5 on: November 13, 2025, 08:16:17 PM »
Without the valves and a caliper it's hard to check. the 6mm intake bolts holes indicate lemans heads,
Here are some comparison shots I took
1986 Sidlow Guzzi
1996 Triumph Daytona 900
