Author Topic: Why spline lubrication?  (Read 3476 times)
Online faffi
« on: November 19, 2025, 04:11:56 AM »
Especially BMWs seems to require spline lubing of the clutch shaft splines as well as final drive splines. But we never hear this about cars. Well, at least I do not. Anybody know what this is required (more) on bikes than cars?
Current bikes:
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Online Littlefield
Re: Why spline lubrication?
« Reply #1 on: November 19, 2025, 06:01:16 PM »
One thing is that automotive driveshaft splines are in an oily environment
Online wirespokes
« Reply #2 on: November 19, 2025, 07:00:39 PM »
 The lube is more to inhibit corrosion than to provide lubrication.
Online Pescatore
« Reply #3 on: November 20, 2025, 07:15:50 AM »
On a single joint cardan shaft I add a tiny bit of grease at the final drive.
That side slides back and forth when the swingarm... swings.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
« Reply #4 on: November 20, 2025, 07:31:09 AM »
Many car splines (except for the clutch) are 'wet'.
Maybe fewer cylinders mean the power pulses are stronger, as in for two revs:
2 cylinders BOOM------BOOM------
4 cylinders boom-boom-boom-boom
More cylinders have more 'flywheel' weight (crankpins, pistons, rods) to smooth the booms out.
And the clutch splines may be deeper than on a bike.
Or BMW uses that VERY expensive lube as a profit center.
Offline JHBettsSr
« Reply #5 on: November 23, 2025, 10:40:40 AM »
I was a Master ASE automotive tech for about 20 years. And yes, the manual transmission input shaft splines are supposed to be cleaned and lubed when the clutch is replaced. Most clutch kits come with a small amount of specialized grease.
'17 Triumph Bonneville T120
'13 BMW K1600GT
'25 Moto Guzzi V85TT
