Author Topic: Norge Heated Grips  (Read 621 times)
Offline scottmcdaneld
Norge Heated Grips
« on: November 19, 2025, 03:29:06 PM »
I have a 2017 Norge  and two questions.
One.  The heated grips just stopped working.  The dash icon is no longer displayed, and the heat selector makes no change. I have traced wires and all looks good.  I have checked manual for fuse and find none mentioned.
On the same bike, the mode selector for seeing codes, setting trips, updating clock is a pain.  I did have to change the battery and most of this started then.
Any ideas?
Scott McD
Offline PJPR01
Re: Norge Heated Grips
« Reply #1 on: November 19, 2025, 04:19:01 PM »
Have you tried holding the heated grips button for about 10-15 seconds to see if the icon activates on the LCD?
I don't know from memory which fuse might activate the heated grips, but there are not many to check...just open the fuse box and inspect every one.  Possibly one is blown...there's only 5 or 6 to check.
« Last Edit: November 19, 2025, 04:20:01 PM by PJPR01 »
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
« Reply #2 on: November 19, 2025, 10:11:02 PM »
When mine sopped on my ‘07 Norge, I got a 12V test probe and checked down alongside the grip. Only to find that the wire had fatigued and broken off, 5 minutes with the soldering iron had them up and running again.
