Author Topic: 1975 850T Survivor Project  (Read 124064 times)
Offline cmice
« on: November 26, 2025, 07:42:40 PM »
Hey all - just got myself into a "barn find"/"ran when parked" project.  Last registered in 1985, last operated in 1991.  Apparently a stuck clutch is what took it off the road.  P.O. did a favor and drained all the fluids, fogged the cylinders, and stored it inside - so far, all the fasteners are coming out without too much of a fight.
Bike is pretty much all there, with the exception of the H-pipe and mufflers.  I'm not sure the Wixom fairing is going to stay or not, but it is growing on me.  Is a non-filter model, so that's fun.
Other things to fix are: broken steering stop, scored forks, bent crash-bar, and tired rubber (including tires).  If there's anything else you spot from the photos, do let me know.
I'll post my first question to the collective under this post.
Next up is to pull the heads as they are chrome bores and I'm pretty sure they're up to no good.
Offline cmice
Re: 1975 850T Survivor Project
« Reply #1 on: November 26, 2025, 07:46:06 PM »
Pulled the flywheel cover out, and the ring gear has seen some action.  What do you suppose caused this?  Inside of the bell housing is unmarred, so I think the thrust-bearing/end-play is ok.  Looks like maybe the starter hit the ring gear while the engine was running and spun against it for a bit?
Use it, or bin-it?  Whaddayathink?
« Reply #2 on: November 27, 2025, 08:40:39 AM »
If the steering stop is broken off and the crashbars are bent, then I would check very carefully to make sure the frame isn't tweaked. Those are both good indicators that there is frame damage. I have three Tonti frames here that wobble side-to-side on a flat surface.
With only 23k miles in 50 years the chrome is going to flake from the cylinder bores if you run them. Sitting around is the worst thing for them. IMO, there is not such thing as "good chrome bores" - it's not "if" they will flake, it's "when". Replace them now before they destroy the engine.
The ring gear damage likely happened from a tankbag or something else accidentally hitting the starter button. It will probably work okay as-is, but a replacement wouldn't be a bad idea.
Offline cmice
« Reply #3 on: November 29, 2025, 07:12:42 PM »
Today's update - figured I'll pull the conrod caps off and see what it looks like there as a quick assessment of how he's been treated. Mixed news.  The bearing shells look distressed but the crank journal looks great - at least on the center web anyway.  But the distressed shells mean the crank should come out and get checked, along with the front and rear mains.  Off comes the front cover.
By the look of the incorrectly folded folding-locks and the boogered up stake-nut on the crank-drive sprocket, someone has been in here before and without the right tools.  So here's hoping whoever it was treaded lightly.  Some additional good news is no stripped threads or helicoils anywhere - so that's a bonus.
Rubber finger tensioner was tensioning air - so chain and chain tensioner are in order.  The flywheel was incorrectly indexed to the crank for some reason, so that's going to need some additional investigation when it comes time to time-everything-up again.
So, let's pull the cylinders off and see what we're dealing with.  And,  whelp, I'd already budgeted to change the cylinders and pistons out, so this isn't a shocker - but chrome has left the building.
« Last Edit: November 30, 2025, 01:47:24 PM by cmice »
Offline cmice
« Reply #4 on: November 30, 2025, 01:44:22 PM »
Ok - today's update.  Made a rear main bearing puller - worked like a charm.  Here, again, mixed news.  First, the crank looks great so that's a relief.  The rear main bearing looks "ok" and I would probably run this, but curious what others think.  Unfortunately, front main doesn't look as good and I think he's a goner.  Again, what do calibrated eyes think here?
« Last Edit: November 30, 2025, 01:48:17 PM by cmice »
« Reply #5 on: November 30, 2025, 03:43:43 PM »
"Looks" are one thing, the micrometer tells the tale...
Offline cmice
« Reply #6 on: December 01, 2025, 05:55:59 PM »
Ok boys and girls, always remember to clean out your crank.
A sort of rubberized slug of chrome dust and who knows what else came out - almost in one piece, but it broke apart into lots of chunks when I tried to extract it.
The bung plug was in only finger-tight, despite being "staked" and came out with only a faintest hint of thread damage (just at the very top where the stakes are). So he's going back in, but sealed and sent home properly this time.
« Reply #7 on: December 01, 2025, 09:30:09 PM »
This is from a '71 Ambassador with 98k miles on it.
Offline cmice
« Reply #8 on: December 11, 2025, 06:24:07 PM »
While it seemed I've gone quiet, I've been doing quite a bit of work behind the scenes.  With the motor completely apart to assess the bearings, it was time to start building the shopping list...and that covered a lot of ground....
First-up was the re-plate vs. buy-new decision on the cylinders since my chrome has definitely failed and bare aluminum was showing, plus the bearing damage as a result.  I followed Charlie's math to look at re-plate vs. new, and indeed, buying new pencils out to the best eventual outcome.  I checked with the two usual places for re-plating, and one would come in about $100 cheaper than buying new (still no pistons or rings), the other would come in at $20 more expensive than buying new (with no pistons or rings).  Plus shipping back and forth, when you add up all the nickels, buying new sets gets you the most bang for the buck.  In the end, I flipped for 83mm Gilardonis which included pistons, pins, piston rings, and head gaskets.  Existing con-rods will be re-used; question as to whether the small-end bushings need to be mic'ed and reamed to size for the new pins, or close-enough and just run it?  Do the rings need to be gapped or do they come pre-gapped? (I'll check them regardless)
Speaking of conrods, that leads us to the great bearing replacement.  The chrome seemed to have done a number on the conrod big-end bearings and the front main bearing.  The rear main looks fine, and the journals all mic out to standard size and look great.  The rocker pins also look fine, as did the cam jounrals.  The cam bearings looked not great, so a *very* gentle touch-up with 1000 grit cleaned them up - called it close enough, we'll leave them alone.  Can these ever be replaced?  Seems like if you could find plain bearings the right size, a line boring machine would make this not too bad a job.
Ok, back to the update - given we're replacing the front main, that leads us to the topic of adding an oil filter.  The newer-style (with filter) front main bearing is cheaper and more available than the non-filter one; plus by adding a filter, we should be protecting all these expensive parts so this won't have to be done again by me or the next owner.  So new-style front main, plus a filter-in-pan off of Ebay, all that's left is the machining.  I didn't take a lot of photos, but there's a great writeup of the process here for those considering the change:
https://www.advrider.com/f/threads/moto-guzzi-early-big-twin-oil-filter-conversion.257513/
Just finished the machining today.  Hardest part, as others have found, is 1) having a 8mm drill long enough to do the deep oil passage (200mm will do it), and 2) the fixturing to hold the housing square with all the studs still in, and 3) having a machine tool with enough throat to hold this massive stack of parts plus extra-long drill (hint: the Bridgeport wouldn't accommodate just the housing with studs, let alone a Jacobs chuck and long drill).
Thankfully a friend has a habit of collecting old machine tools, including a 3-phase Rockwell gear-drive drill press - plenty of throat, nice and square and solid so nothing wiggles around while the quill spans a massive distance.  Little spooky working on that thing because if it snags on anything it will take your arm off.  All that's left is to fab the blanking plate for the old pickup, and then we can start putting the motor back together.
Lastly, earlier I'd posted a photo of the starter ring-gear and asked about how this could happen and whether to run it or not.  While I was browsing on eBay for a filter-in-pan sump, I found a listing for an "EV" flywheel and cover for cheap.  This alleged EV flywheel looked like a single-plate unit (which is junk) but figured what the hell - grab the assembly and if all I keep is the cover and ring-gear then great.  It showed up - and to my delight, it is completely unused and is not a EV flywheel at all, but a good-old multi-plate flywheel.  As an added bonus, the scale says the flywheel weighs in at 7.2lbs instead of the stock 9.2lbs(!) - so I guess I scored a lightweight LeMans flywheel by accident!  Gonna run that mofo for sure. :)
Next update should be about putting the motor back together - plus a fun side-quest in 3d-printing.
« Reply #9 on: December 12, 2025, 08:34:28 AM »
Yes, do check small-end bushing i.d. and compare that with the specs in the factory manual. The new pins will be the same o.d. as the originals.
The rings are supposed to be "pre-gapped" but it doesn't hurt to check them.
There have been reports of a few of this latest batch of Gilardonis not fitting into the crankcase - the "spigot" of the cylinder wasn't properly machined and is too large to fit. Check this before you begin assembly.
Offline cmice
« Reply #10 on: December 13, 2025, 04:18:17 PM »
A little overkill perhaps, but CNC cut the blanking-plate for the original screened oil-pickup (ie. non-filtered flow), and installed.  I added nylocs on the back side just for safety, and we'll see if there's room once the crank is installed...I think there will be no problem. Now that all the machining on the block is done, and it is clean, we can start building it up again.
« Last Edit: December 13, 2025, 05:48:50 PM by cmice »
Offline cmice
« Reply #11 on: December 14, 2025, 04:13:50 PM »
Short update for today.  Rear main lip-seal changed, and the rear main bearing is in the freezer waiting for the "big day" when the crank goes back in.
In cleaning up the rear main bearing, I forgot that there was still the old gasket stuck to it.  I don't know when whoever was in here was in here, but they used some sort of gasket sealant that got super hard and really stubborn over the last 30 odd years (can't be 50, surely).  Anyway, spent some quality time with a steamer with a brass-bristle brush attachment, and the almighty razor blade, and those stubborn things finally relented and came off nicely.  New gaskets will get hylomar - doesn't harden, cleans up easily, love that stuff.
New rear main lip seal went in with only oil - no sealant.  Old seal had I think shellac type sealant, and was a bear to get out.
Some arbitrary engine shots.
« Last Edit: December 14, 2025, 04:18:59 PM by cmice »
Offline cmice
« Reply #12 on: December 16, 2025, 12:59:16 PM »
Update from last post - freezing the rear-main is the bees' knees.  Dropped right in without a fuss.  Lip seal was a little stiff to get over the end of the crank, but gentle coaxing with non-sharp things got it to slip over and it went home with the gentlest tap of a dead-blow hammer.
Ok - today's question, and I'm sure it's a boneheaded one as it's been covered before....but this just doesn't make sense.
I'm reusing my existing conrods and kept track of how they came out (plus end caps, etc) - but I don't trust anything that's coming out of this motor now given someone else has been in it.  Looking at the oil squirt hole orientation, all the references say that the milled flats and the oil squirt holes should face to the right (which means one squirter points up, the other points down).
Oil Hole in question...
But that doesn't make sense if the role of these is to squirt the underside of the pistons.  It seems like both should squirt UP, but instead, all facing right means one side gets squirted underneath and the other squirts the sidewall of the engine case?  Am I overthinking it?  Using new bearing shells so previous run-in is ignored.
This is how I would THINK it would go, but this would be incorrect.
Also, looking at the two conrods, one side looks like something funny happened - unclear if this is from the factory or field related damage.  Is this just a manufacturing thing or is this rod suspect?  Underside of the cylinder skirt looks ok.  Thoughts?
Looks like a hand-grinder was taken to this???
[Post-lunch edit...] Everything I see says left-up, right-down.  I don't understand why, but that agrees with how they come out so that's how they're going back in.
« Last Edit: December 16, 2025, 02:34:59 PM by cmice »
Offline cmice
« Reply #13 on: December 19, 2025, 04:30:29 PM »
Ran the heads through the ultrasonic.  Had to put the valve keepers in a press to get them to pop.  Gotta say, never had to do that before - but this motor has been a long time sitting.  Valves cleaned up nicely, valve tips looked like this:
Couldn't catch a finger on it, but still peace of mind wanted them cleaned up.  My local VW hot rod shop chucked them into the grinder, and in under a few minutes cleaned them all up up (only 2 of 4 shown of course).
The kicker, he said "have a great holiday" and sent me home f.o.c.!  Refused to take any payment despite my insistence.  Love old school places who like doing old school stuff.  Gotta figure out how to keep them in business.
Started the cylinder build up - and let me just say - when the Italians say "everything is pre-sized", what they MEANT to say is they INTEND for everything to be pre-sized.  After putting one cylinder and head together, torqed it up - engine was pretty tight with only one cylinder installed and that was not a good sign.  Pulled it back apart, and found the oil control ring gap to be 0.0025".  That's not going to work.
Now we check them all.  Luckily, no wall scoring and this should be better once I get it back together again. Thankfully I've got a spare head gasket.
Offline cmice
« Reply #14 on: December 21, 2025, 09:49:46 PM »
Ring gaps set - that cylinder now moves like it should.  Since I had to pull a cylinder back off that put me short of a base gasket so I'm waiting for another gasket to turn up.
While we're waiting, as they say, "if you've got time to lean, you've got time to clean."  Front cover went into the ultrasonic - it's slightly too big for the cleaner so I had to do it in halves.  Yeah, baby.
Offline cmice
« Reply #15 on: December 26, 2025, 06:19:54 PM »
Ok - today's update - winter storms, holidays, and missing parts slowed me down a bit.  But with the ring-gaps set, and the replacement base-gasket in hand, I got to finish building up the block and top-end.  All is nice and clean (clean enough), sealed and torqued.  Spins nicely. (note: oil pressure gauge isn't going to stay, I just want it there for priming and first fire to make sure we are seeing what we need given all the oil system changes for the filtered front bearing)
However, in putting the left hand rocker bridge on and torquing it up, I found that the exhaust side rocker pin is wrecked.  Similarly, the rocker bushing is also buggared - so those are now on order.
Lastly, I was looking at something on the frame, and this fell out - and I cannot for the life of me figure out where it came from or where it goes.  Any ideas?
« Last Edit: December 26, 2025, 06:22:44 PM by cmice »
« Reply #16 on: December 27, 2025, 08:52:30 AM »
That's an "olive" that fits onto the speedometer and tachometer cables, the securing nut squeezes it onto the outer housing of the cable to keep it in place.
Offline Turin
« Reply #17 on: December 27, 2025, 09:38:40 AM »
Did you find it under the Battery tray? Any time I've taken apart an old guzzi , I find one or two of them. That's one of those bits that gets dropped and is never seen again.  :gr
1985 Sidlow Guzzi
Offline cmice
« Reply #18 on: December 27, 2025, 11:36:46 AM »
Thanks for the identification on the "olive" - I figured it was either speedo or tacho cables, or possibly throttle cables.  It fell from somewhere on the frame as I was looking at something and I couldn't tell where it fell from.
So, now that the motor is nearly buttoned up, attention turns to the gearbox.  And OMG this thing is full of misery.  Just a matter of curiosity at this point, but the clutch hub is wrecked and the friction-discs have plenty of material and look nearly new, the teeth tell a different story.  I have no idea what could have caused that kind of wear, but at this point doesn't really matter  So, that's another job on the list.
Stepping back for a moment - I bought this bike because it looked to be fairly complete, numbers-matching and had a presence and patina that looked genuine.  It also looked like a fun project to stay busy during the winter months.  While I still think this is true, a sane person would have called this a parts bike and harvested it.  I got it for a good "ran-when-parked" price, and by the time it's all said and done, it will probably be a break-even if the time comes to sell it...that's what I'll tell myself anyway.  :tongue:
« Reply #19 on: December 27, 2025, 06:22:08 PM »
The clutch plates appear to be those sold by Barnett and that is their usual failure mode. The sandwiched construction is part of the issue, but inadequate heat-treating seems to be a problem as well. The only plates I use are the "SD-TEC" bonded and riveted plates with matching deep spline hub.
Offline cmice
« Reply #20 on: December 27, 2025, 06:48:23 PM »
Makes sense - I remember when Barnett clutches were the thing to have, sadly.  Previous owner said the bike was parked because "the clutch froze up and they couldn't get it to release".  The friction surfaces and intermediate plate show no sign of being stuck, but the notches cut into the hub I'm sure gave the discs something to hang-up on...or, once in there, they wouldn't come out.  Grooves are probably 0.5-1mm deep in spots.
SD-Tec's ordered.
Any tips for replacing the rocker bushing?
« Reply #21 on: December 28, 2025, 02:07:28 PM »
SD-Tec's ordered.
I have my local machine shop replace the rocker bushings and ream them to size.
Offline cmice
« Reply #22 on: December 28, 2025, 04:40:06 PM »
I got brave and this worked to get it out without too much trouble - 16mm tap run in about 1", flip it over and then drop a punch into the centering point on the leading-end of the tap and drive it out with a bfh (big f'ing hammer).  Saw a Harley guy do it on youtube so it must be legit.
Remains to be seen if I'll be brave enough to install the new one (heat the rocker, freeze the bushing, oil it and go) or if I'll have a shop do it.  May go shop if it has to be reamed to size anyway.  Will see when the bearing shows up what I decide.
« Last Edit: December 28, 2025, 10:31:11 PM by cmice »
Offline cmice
« Reply #23 on: January 03, 2026, 02:39:52 PM »
Rocker bush and pin showed up - fabbed up an installation mandrel (formerly a Ducati clip on, then turned into a VW clutch installation tool, now a Guzzi bushing installation tool).  Pressed right in without really much drama.  Double, triple checked the installed diameter, and it's at the high-end of size for spec and reaming is not really going to help so gonna leave it alone.
Thinking I could finally button up the top end, and I found a booger'ed up valve-adjuster screw.  Galled like crazy and so again now we wait. :-/  All the others are ok.
Also clutch discs and hub showed up - so that's where we'll go next - the gearbox.
« Last Edit: January 03, 2026, 02:40:30 PM by cmice »
Offline matt franklin
« Reply #24 on: January 04, 2026, 12:30:28 PM »
Probably too late now that you've put the front end of the engine back together, but what did the oil pump look like?  If that engine had chrome flakes run through it, and no oil filter, it may be ready for a replacement.
Offline cmice
« Reply #25 on: January 04, 2026, 02:10:52 PM »
Good call - and yes I already took the oil pump apart and gave it a clean an inspection.  I didn't take photos of that part.  Gear teeth looked clean, and no slop between the pair when installed.  I didn't measure side-clearance, etc, but the pump itself looked ok.  That has been the case with many parts in here - one side of a mating surface will be wrecked (ie big-end bearing), but the other side perfectly clean (ie. crank journal).
The engine-side wear surface has some swirls on it, but nothing I could catch a nail on and felt perfectly smooth when you drug a finger across it.  Visibly it looks alarming, but I think it looks much worse than it is.  Not sure what can be done about it, however.  Fab and put a wear plate under it, but then that throws the chain alignment off?  So then have to machine the face of the case down to put the pump back in plane? (ugh)
Plan is once I get the front cover on it, to prime the system and crank it on the bench to check for oil pressure.  Any idea what can be expected with just starter motor rpm?
« Last Edit: January 04, 2026, 02:14:19 PM by cmice »
Offline cmice
« Reply #26 on: January 07, 2026, 11:01:19 AM »
Lots to share since the last update.  Checked and set both cam and distributor timing.  Also modified the advance plate to get left and right cylinders in the same ballpark as far as static timing.  Waiting on a couple small pieces before I can button up the motor so we move on to other stuff.
I'd mentioned in a previous update that I was working on a 3d printing thing - seems that all the 850Ts have their headlight switch cover broken off.  Local library has 3d printers which you can use for free - and they're also super excited if you use them for useful stuff.  Took several attempts but this is getting there.  Calling it close enough for now, but may work on making this better later after the bike is running.
On to the (mildly) terrifying task of the gearbox.  Nothing earth shattering in here - other than draining out only about 50ml of oil vs the 750ml that's supposed to be in there.  Also some really petrified lip-seals and o-rings needed to come out and be replaced.  Everything went for a ride in the cleaner (I cannot recommend an ultrasonic cleaner highly enough).
Of the internal carnage, the speedo drive looks absolutely hammered.  Do they all look like this? What do we suppose caused it?  The hypoid-drive on the inputshaft side looks like new so again, one side trashed, the other side clean.
Also, the throwout rod thrust-bearing is a one-piece/one-sided affair - the needles are enclosed completely on one side, and this looks like it was a bad idea as I think it locked up at some point and the plunger itself (with the o-ring) was spinning as a result and was starting to machine itself down along with the lever adjustment screw. So these are garbage and needed replacing anyway.
Now to put the gearbox back together before I forgot how it came apart.
Offline cmice
« Reply #27 on: January 07, 2026, 03:02:49 PM »
This caught my eye putting the shafts back in.  I didn't know Guzzi was so ahead of their time!  They apparently had invented "air bearings" for thrust applications!  :wink:
Needles are not in the parts washer, not in the oil I drained out, they are gone.
Interestingly, McMaster Carr has a needle bearing (5909K16) and hardened washers (5909K76) that look about right.  They'll be here tomorrow.  Question is, since I don't have the needles, can anyone tell me what the total height is of either the guzzi original stack (washers + bearing) or just across the bearing rollers?
« Last Edit: January 07, 2026, 03:34:47 PM by cmice »
Offline cmice
« Reply #28 on: January 08, 2026, 05:02:48 PM »
Everything measures up, including the thickness of the thrust washers - so installed it and put the box back together.  Torqued everything up, and everything shifts nice.  It seemed to get lost between 4th and 5th before, now not so - guessing the extra 1mm with the missing rollers was letting the gear pair float around.  A last couple of finishing touches on the motor and that can get oil and a spin for pressure.  Waiting for clutch throwout rod parts - when that shows up, then the gearbox can get oil and be assembled in anger.  We almost have a motor and gearbox.
Offline cmice
« Reply #29 on: January 16, 2026, 02:35:32 PM »
Ok - lots to update you all on.  After putting the gearbox back together, torquing it all up, replacing the galled valve-adjuster screw, putting all the fluids back in, I declare the engine and gearbox "ready" to go back in the frame.
With just a cordless drill and a hex key on the crank nose, I'm able to make 20psi of oil pressure.  I did have to prime it by hand first (opened an oil feed line to one of he heads and turned it by hand till it started puking oil out the banjo).  So I'm hopeful the oil-filter mod is good and will make good pressure while cleaning the damned oil.
So, speaking of going back in the frame - it leaves the matter of the broken steering stop.  Pretty impossible to work on this with the frame in its normal orientation so best to strip it down to the point where you can flip the frame over.  That means taking the triples off cuz the steering head bearings should get checked anyway, and here we are.
I think rather than cut the stop bracket away from the frame to replace the entire bracket, I'm going to clean up the "nub" and weld a new tang back onto the nub.  This approach makes both sides of the weld more accessible than trying to get up in there with a completely new bracket and I have a lot more confidence in my ability to weld things I can see vs. what I can't see.  Can also see the state of the steering head bearing outer race, can't feel those ridges where the rollers sit but I think it's worth replacing these since we're in it this far.
And speaking of being in it this far, that leaves the matter of what to do with the frame.  To get things to the point where they are, it wasn't much further to just get the frame bare and see what see.  The frame paint is scruffy and welding is going to mess up some of the paint in the area near the steering head.  So as far as we are in here, it probably just makes sense to take it to a powder coater and have the frame blasted and painted.  I'm still fretting over it, but it seems like the right answer if this bike is going to stick around for another 51 years.
A question to the collective then - the rear swingarm should probably get the same treatment as the frame and engine cradle.  I've never had a final drive apart before (planning to do seals and gaskets), but my question is, can I split the ring-gear housing from the drive-tube without opening a can of worms with shimming the pinion?  Or best to not break it open, mask that part off and do it that way?  What's ya'lls advice here?
« Last Edit: January 16, 2026, 02:48:23 PM by cmice »
