Author Topic: Arcing coils / Running issue / no top end  (Read 20562 times)
Offline 73 sport
Re: Arcing Dyna Coils Added pics
« Reply #30 on: December 24, 2025, 08:33:59 PM »
   I've had Dyna coils and distributer plate on my '74 Sport since the mid '70s. never a moments problem. I have silicon rubber plug caps, the insides are lightly coated with silicon grease. The coil caps are also coated inside with silicon grease. Many of the gripes I've seen on this site looks like rain, humidity intrusion. Not all ignition wires and caps can handle higher voltages produced by performance components. The complainers seem to have similar problems, they don't want to spend the money for quality components.
Offline baloo
« Reply #31 on: January 11, 2026, 12:40:49 PM »
Yes, Any update?
I'm having the same problem of backfiring at higher rpm - I have the Dyna system, which ran great until parked about 1yr ago.
Thinking it might just be the coils (Dyna 5ohm) which test out OK per static tests with multimeter.
I'm thinking the coils just might peter out at high rpm (when I get backfiring - around 6000rpm)
Carbs cleaned out
Offline 73 sport
« Reply #32 on: January 11, 2026, 01:43:03 PM »
    Go to Google. Type in "What causes backfire at high RPM".
Offline Turin
« Reply #33 on: January 11, 2026, 09:37:36 PM »
It's not the Dyna ignition or the coils. Both have been swapped. Not the carbs either, those were swapped.
IOt has to be the NGK (racing) plug wires
1985 Sidlow Guzzi
Online michaell32
« Reply #34 on: January 11, 2026, 11:37:41 PM »
Weak valve springs cause this issue. The valves could be floating it the high rpm.
Edit: Nevermind. You already answered the other comment.
« Last Edit: January 11, 2026, 11:55:41 PM by michaell32 »
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Offline Turin
« Reply #35 on: January 19, 2026, 08:02:35 PM »
Some of my issue is the F@$K A$$ 2-1 pipe. Hail Mary pass, swapped a Rennsport 2-1-2 system from my stash and Voila... The bike revs to 8K with no jetting changes. Got more tuning to do, but this is a step in the right direction.
« Last Edit: January 19, 2026, 08:09:40 PM by Turin »
1985 Sidlow Guzzi
Offline turboguzzi
Re: Arcing coils / Running issue / no top end
« Reply #36 on: January 21, 2026, 03:50:08 PM »
Glad to hear you seemingly found the culprit.
Not sure an "exahust system issue" would have been top of my list, but one of the reasons i asked you for pics of the whole bike is that sometimes the problems is there staring at you.... :)
Now that i see it fully, wow, nice tool! some good goodies on it too...
Offline Tkelly
« Reply #37 on: January 21, 2026, 05:03:33 PM »
Nice collection!
Offline Turin
« Reply #38 on: January 21, 2026, 05:40:58 PM »
That's not my Garage !!! Mine is loaded with old guzzi's.
1985 Sidlow Guzzi
Offline Offcamber1
« Reply #39 on: January 21, 2026, 09:43:09 PM »
Rodent nest in the 2 into 1 pipe???
Offline Turin
« Reply #40 on: January 22, 2026, 07:01:36 PM »
nope. A rodent nest might have helped by adding back pressure.
1985 Sidlow Guzzi
Offline Turin
« Reply #41 on: January 27, 2026, 11:42:38 PM »
it revs quickly to 9K, pulling hard past 8k. Next item of business is to modify the bottom of the fairing, as the under oil pan exhaust takes up that real estate.
1985 Sidlow Guzzi
