Author Topic: Why the T3 Cross-Over So Long?  (Read 1070 times)
Offline Dimples
« on: December 23, 2025, 07:00:23 PM »
Is there a design function to the cross-over to extending so deeply into the mufflers?
What are the consequences of cutting it shorter?
'96 Sport 1100
'71 Ambassador
'81 V50 Monza
'83 850 Le Mans III
'85 Le Mans 1000
'04 V11 Le Mans Nero Corsa
'77 850 T3
Re: Why the T3 Cross-Over So Long?
« Reply #1 on: December 23, 2025, 09:20:34 PM »
From what I have read, true/not true??. The deeper into the muffler, the less prone to heat discoloration of the muffler.
« Reply #2 on: December 23, 2025, 09:25:32 PM »
I always thought that the closer you can get the x-over to the quarter size outlet holes the better. That way the exhaust forces the exhaust out.
Offline moto
  • Fear the deer!
« Reply #3 on: December 23, 2025, 10:15:22 PM »
I believe that a longer exhaust pipe at a constant diameter creates a column of exhaust with higher inertia than would happen with an exhaust that increased its diameter away from the port. This means higher inertia of the gas column as it moves away from the head, leading to better extraction of the spent charge during the overlap period of the cam, when the piston tries to draw gas in from both the intake and the exhaust valves. That in turn draws more fresh mixture in through the intake valve, and means more power. I believe this effect is more important at lower and medium RPM. The crossover pipe between the two longer, constant-diameter exhaust pipes is a secondary issue that doesn't figure into the benefit of long exhaust pipes.
Just my understanding. I'm no expert.
« Last Edit: December 23, 2025, 10:20:53 PM by moto »
850 T-3
Griso 1100 corretto
Offline ray bear
« Reply #4 on: December 23, 2025, 10:41:00 PM »
my convert is the same
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Online turboguzzi
« Reply #5 on: December 24, 2025, 02:17:25 AM »
Exactly,
In guzzi racing exhaust system for higher rpm,  the pipes are usually much sorter.
Offline chuck peterson
« Reply #6 on: December 26, 2025, 05:16:38 AM »
Yes
A friend did track days by taking off the muffler leaving the crossover which is designed to scavenge the spent exhaust. He said each header isn’t big (wide) enough alone, but the crossover, being a split that widens the available exhaust space, acts like the exit side of the venturi. Guzzi has two venturi, one in front of the carb and the other formed by the exhaust and crossover
Taking off the crossover takes away the venturi effect.
I’ll be back with the right info from wikipedia…
https://en.wikipedia.org/wiki/Venturi_effect
In fluid dynamics it’s a Venturi. Same as air. My old brain forgets the term for that little piece in front of the carb that first constricts the airflow (same as fluid) and then expands to create faster flow
 (my understanding is the exhaust pipes on guzzi are a little too small)
and then there is an expansion (the crossover that almost doubles the area for exhaust to both pipes) that make a scavenging effect for faster airflow, pulling the spent gases away faster then the piston can push into the exhaust header
So he suggests…i never went to track days. Ymmv
This also explains Guzzi moving the crossover closer to the exhaust valve to above the rotor/stator on the higher powered LeMan type bikes. With the header being stuffed by higher rpm usage, creating a need to split in the exhaust gas sooner, and also a second crossover below the transmission
Looking at the unmuffled exhaust of the La Franconi, here in the race bike foto, you can see the slowly expanding exhaust pipe as it goes away from the second crossover below the transmission This too has a scavenging venturi effect. Notice if you straighten this race exhaust you’ll have approximately the same length as your stock T3 headers, but without mufflers
The stock guzzi bits are pretty well thought out. Yes you can just remove the crossover but that removes the venturi effect.
Start your bike with just the headers and it makes a funny pop pop pop sound, not the explosive roar you might expect
« Last Edit: December 26, 2025, 06:13:16 AM by chuck peterson »
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
