Author Topic: 750 Ambassador head mystery  (Read 359 times)
Online neetones
« on: December 24, 2025, 04:32:18 PM »
Hi all. I have a '69 750 Ambo that's fairly new to me. I've fixed up a few things but it always ran quite weakly.
I finally did a compression test and found a disappointing ~80PSI on each cylinder. Just pulled the heads for the first time and found Gilardoni cylinders (great!) with excellent crosshatching.
I noticed, though, that the diameter of the cylinder bore doesn't appear to match that of the combustion chamber. Cylinder measures 83mm and combustion chamber measures 72mm. I suppose that's normal.
Additionally, I'm seeing this odd arc of wear across the piston.
Looks like my Gilardonis don't have oval pushrod holes so I can use a regular head gasket?
Any insights? I haven't pulled the valves yet but they appear to be seating well.
« Last Edit: December 24, 2025, 04:41:47 PM by neetones »
1969 Ambassador
2022 V7 850 Centenario (sold)
Offline turboguzzi
Re: 750 Ambassador head mystery
« Reply #1 on: December 24, 2025, 05:02:17 PM »
The mismatch is normal, designed into other models too, actually beneficial because it creates a squish area that helps combustion. the "wear" arc you see, is the squish area actually doing its job.
still, 80 is not a good compression, have you tried to do valves leak test by pouring fluid into the ports? valve / seat sealing would be my first suspect.
Online pehayes
« Reply #2 on: December 24, 2025, 05:05:34 PM »
I must ask.  What is your compression check procedure?  Did you arrange to have both spark plugs out and have someone or something to hold  your throttle wide-full-open throughout the test?  Pressure should be around 160psi with no more than 10% variation side to side.  Your numbers are a clear indication that your throttles were closed during the test.  Common error. Reassemble and  you might find that everything is OK.
Online michaell32
« Reply #3 on: December 24, 2025, 05:45:31 PM »
I wouldn't be surprised if the mark on the piston is simply fuel coming around the intake valve and cleaning the carbon off that spot. I doubt it's wear.
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Online neetones
« Reply #4 on: December 24, 2025, 05:48:10 PM »
Well this is very helpful. I did not have the throttles open. I had both plugs out, though. Tried with one plug in and got the same results.
I may just check the valves and bolt everything back up.
1969 Ambassador
Online neetones
« Reply #5 on: December 27, 2025, 04:13:25 PM »
I continued taking the head apart and found that the valves are very loose in their guides.
Exhaust is looser than intake but both can be freely wiggled around. Looks like I have bronze guides and the exhaust valve is stainless (non-magnetic).
Having a difficult time finding a machine shop that can K-line them. Any suggestions? The bike doesn't get ridden much so I'm not sure how much I want to shell out, but I'd like it to run properly and reliably.
video of valve play: https://photos.app.goo.gl/jfE961oZUvhaHdoN6
1969 Ambassador
« Reply #6 on: December 27, 2025, 06:17:05 PM »
Do you have a micrometer or even a dial caliper to measure the valve stems in the area that slides through the guides? The valves might still be usable, but those guides are knackered. Guides cost $14 ea. and my local machine shop charges $280/pr. to clean and media blast the heads, replace the guides and recut the seats.
Online neetones
« Reply #7 on: Today at 09:38:32 AM »
Thanks Charlie,
Do you have some contact info for that machine shop? Sounds like you trust their work.
Nitin
1969 Ambassador
« Reply #8 on: Today at 12:17:40 PM »
Thanks Charlie,
Nitin
Sent you a PM.
