Author Topic: Portable air compressors  (Read 1400 times)
Offline NuGuzzi
« on: December 26, 2025, 06:06:58 PM »
Any recommendations on small portable air compressors, battery operated or USB?
Something to carry on bike, smaller and lightweight, anyone have advice on better ones.
I see a lot of ads for a unit called AirMoto I believe, any thoughts on this one?
Maybe some of you folks know of good ones, any help would be appreciated.
« Last Edit: December 26, 2025, 06:19:54 PM by NuGuzzi »
Offline Dr. Enzo Toma
Re: Portable air compressors
« Reply #2 on: December 26, 2025, 08:30:17 PM »
I have an Airmoto and also bought one for my dad which he's been using. They're convenient and fit our use case which was battery powered for use with motorcycles that are 6V or just magneto bikes with no battery. Personally, in any situation of having a 12V bike with a battery I would prefer to just use a wired inflator connected to an SAE pigtail off the battery. The Airmoto ones do not have a serviceable battery, so they will eventually be a paperweight because of that.
I also a few of the DynaPlug inflators, one with several years of regular use on it. They hold up great, the only thing I don't like about them is common for most portable air compressors and it's that they're missing an air chuck so as you unthread them from the valve stem air escapes. To compensate for this, you just overinflate the tire knowing that's going to happen, then use your tire pressure gauge to check again and let some more out if needed. If I were buying one again I'd also consider the MotoPumps ones.
« Last Edit: December 26, 2025, 08:31:07 PM by Dr. Enzo Toma »
MGNOC Member
« Reply #3 on: December 26, 2025, 10:56:21 PM »
I have a couple of these, works well https://www.amazon.com/s?k=tire+inflator
Air moto.
« Last Edit: December 26, 2025, 10:57:34 PM by John A »
Online michaell32
« Reply #4 on: December 27, 2025, 03:26:21 AM »
I have a fanttik as well. I like it because I use it on my car which doesn't have a same plug. On our last guzzi ride it topped off three bikes and still had plenty of charge left.
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Offline Bill W
« Reply #5 on: December 27, 2025, 05:37:52 AM »
« Reply #6 on: December 27, 2025, 06:45:37 AM »
I have 3 Motopumps.  Works a treat.
« Reply #7 on: December 27, 2025, 01:34:45 PM »
Unless you are moving at the glacial pace you only lose a little burp of air (using a screw on type ) or not enough to effect the overall level of inflation. The DynaPump does have an air test port so you can take a pressure reading while everything is connected. If you are really that worried about nailing the pressure over inflate the tire by 1 PSI and then disconnect. If you are using a $2 stick gauge also be advised their accuracy will rival the accuracy of 70's ere Veglia speedo/tachometers.
This depends on the valve stem design. I've found that the schrader valve stems with smooth sides, commonly found on some tubes, will lose a few PSI even if it only takes you a second or two to unthread the nozzle from them. I suspect that's because there's a relief for air to pass by the threads. On one of my sets of wheels I overinflate by about 5psi and that seems to hit the mark once removed. If not, my digital tire pressure gauge has a stick to let some air out, though many caps that come on motorcycle and dirt bike tubes these days tend to also have that on the back.
MGNOC Member
Offline jcctx
« Reply #8 on: December 27, 2025, 02:12:33 PM »
Many on Amazon; bought the grandson one for Xmas that is a jump starter and an air pump. About $30~ of course it may be worth every penny (no longer minted!)?????????
Offline Moparnut72
« Reply #9 on: December 27, 2025, 02:43:06 PM »
Project Farm did a test of several different brands on Utube. I didn't watch as I ride a tubed bike. I do carry a small bicycle hand pump to top up if I need to when on the road. I have a compressor in the shop for bigger jobs.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #10 on: December 28, 2025, 08:05:53 AM »
I have 12 volt pumps in each bike. I didn't want yet another battery that I need to charge.
I did get a small battery operated one for the shed for the riding mower. Mainly just to try one out and play with the pressure level in the tires on a zero-turn mower. It is really handy, and the battery is fine for what I am doing. But it doesn't have great battery life. I'm sure one day I would need it on the bike, and it wouldn't do it.
Offline Ncdan
« Reply #11 on: December 29, 2025, 09:01:31 AM »
+1 on the Bauer. This pump will top off a full size pickup tire. It would challenge it to pump up multiple car or truck tires but it works great when topping off 4 of any size passenger vehicle tires.
« Last Edit: December 29, 2025, 04:13:16 PM by Ncdan »
Offline turboguzzi
« Reply #12 on: December 29, 2025, 09:20:10 AM »
and for people in Europe with access to Lidl supermarkets....
Im a Parkside tool junkie, already have plenty 20V batteries to swap, so this was a no brainer for me. Even when using it on my 4x4, never run out a single charged battery on a trip.
Offline chuck peterson
« Reply #13 on: December 30, 2025, 07:00:10 AM »
Before you hit the road with your new portable air pump, double check the fuse in line with the pump has enough resistance to keep working when you need it. Mine popped right when I needed it most…thankfully we had spare higher rated fuses within our group, 200 miles from any rescue, in a desert, at 120degrees, with sweat dripping down your nose and considering how the hell your going to remove and fix a rear tire with tube under those conditions. It doesn’t help your psyche either when the four Harley guys your with start snickering…ask me how I know
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Groover
    • Scooteropolis
« Reply #14 on: December 30, 2025, 09:43:56 AM »
This one is great, seems out of stock, but if you can find one, its definitely worth it.
https://www.amazon.com/AirXwills-Compressor-Portable-Inflator-Inflatables/dp/B08CXVBKTZ?ref_=ast_sto_dp
« Last Edit: December 30, 2025, 09:44:26 AM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline glenm64
« Reply #15 on: January 01, 2026, 06:29:46 PM »
I have a Desert Fox. Not the cheapest but they are decent quality.
Offline Luap McKeever
  • Owner, WildGuzzi.com
  • Administrator
    • Wildgoose Chase Moto Guzzi
« Reply #16 on: January 02, 2026, 09:39:39 AM »
FWIW, I put one of these in all my bikes, along with a plug kit. I really like them. Set your desired pressure and it shuts off automagically when it reaches it. They're not tiny, but not huge and they do rely on a 12V plug.
https://www.amazon.com/dp/B0C6GS6JR3?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3
2021 V85TT Centenario E5
2001 California Special
2001 California EV
