Author Topic: When the brain is disconnected  (Read 8597 times)
Online faffi
« on: January 01, 2026, 08:35:47 AM »
Happens to me all the time. Like yesterday, when I was going to put the pork ribs into the oven and forgot I had added water to the tray. The rib and tray came along just fine, but a good portion of the water decided to prove that Newton was right...
But it can also happen to professionals. I am going through old M/C magazines, and today I read an article about how to improve the then current VFR750 as well as the GPZ1000R Ninja.
For the Honda, they changed the fork springs, and the maker delivered a set of straight wound springs plus spacers. In addition, the kit came with 4 short and very stiff springs. According to the instructions, springs plus spacer would yield the softest setup. To go firmer, you could add one firm spring on each side and cut down the spacer accordingly. For the stiffest ride, you should discard the spacers and use the standard spring plus the two firm ones in each leg. And the article claimed that the only way they could get a modicum of comfort, was with the spacers and the standard spring. Preload was the same in all instances.
Now, even the stiffest spring will compress, something a spacer will not. Also, the longer a spring become, the softer it will get. So unless it is my brain that is disconnected again. the stiffest ride should be with the standard springs and full length spacers.
When it came to the Ninja, they felt that the overall gearing was too tall in order for the bike to reach 160 mph at its redline. This "tall" gearing (4000 rpm @ 60 mph is not what I personally consider tall gearing, but whatever) made the liter bike sluggish in acceleration in its top three tallest gears, struggling to keep up with 750s. After fitting a rear sprocket with three additional teeth - reducing theoretical top speed from 160 to 146 mph - acceleration from 45-70 mph in 4th gear dropped from 6 to 2.88 seconds! That could only happen if the bike was sitting in a big hole in the powerband with the stock gearing. However, after this gearing change, the Ninja was now a lot quicker in 6th gear than it was previously in 4th. Which does not compute. Either the conditions had changed dramatically, or they used a different test bike, indicating something was off during the original full road test of the bike.
In this case, the collective brains of the magazine staff was clearly out to lunch. They should at least understand this when they, after learning the Ninja was too busy with the low gearing, changed to a one-tooth extra rear sprocket (compared to stock) and the acceleration was still 40-45% better than what they had achieved in the original road test.
Current bikes:
2002 BT1100
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Offline SIR REAL ED
  • uh.... it's personal....
Re: When the brain is disconnected
« Reply #1 on: January 01, 2026, 09:49:38 AM »
The gearing is simple math.  If the new sprockets resulted in a new sixth gear that was lower than the original fourth gear, it makes sense.  If not, they were wrong.
IIRC, the original GPz900 had a very close ratio gearbox.
Springs can be difficult to understand.  For my simple mind, the following visualization always clears my confusion.
Imagine straightening out the spring wire.  One end is anchored so the wire become a horizontal, cantilever beam.  Compression of the spring with a load applied in it's original configuration, will be identical to the vertical deflection of the free end of the imaginary horizontal beam with an equal load applied.
Thicker wire results in a stiffer beam, obviously
Thinner wire result is a less stiff beam, obviously.
Shorter wire is a shorter, stiffer beam.  The can be accomplished with less spring coils or a smaller outside diameter (OD) of the spring, while keeping the same wire diameter.
Longer wire is a longer, less stiff beam.  This can be obtained by more spring coils, or increasing the outside diameter (OD) of the spring, while keeping the same wire diameter.
My most common brain checkout these days is looking for something I remember as green, while the item I am looking for is actually blue and is sitting right in front of me.
« Last Edit: January 01, 2026, 09:58:06 AM by SIR REAL ED »
2002 MZ Skorpion
1994 DR Skorpion
Online faffi
« Reply #2 on: January 01, 2026, 04:31:12 PM »
Big difference in gearing; 1.33:1 in 4th and 1.03:1 in 6th, so about 30%, whereas the changes in final drive ratio was at first 7.5%, then reduced to just 2.5%.
I think of spring rates like this (for straight wound springs): Double the length and the rate is halved. Halve the length, and the spring rate is doubles.
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline SIR REAL ED
« Reply #3 on: January 01, 2026, 06:26:45 PM »
Yep.  It is all about the wire length.  The same holds true for progressive rate springs.
If the wire diameter is uniform, spring rate is determine by length of wire per unit of spring length.
« Last Edit: January 01, 2026, 07:30:31 PM by SIR REAL ED »
2002 MZ Skorpion
1994 DR Skorpion
Offline YellowDuck
« Reply #4 on: January 02, 2026, 04:33:34 PM »
The one I always have a hard time accepting is that if the fork is extended to the point where the topout spring is engaged, it becomes stiffer (i.e., the spring rates *add*).  It's equivalent to having springs in parallel.
Offline SIR REAL ED
« Reply #5 on: January 02, 2026, 06:38:23 PM »
Me confused, "if the fork is extended to the point where the topout spring is engaged" ie: you are pulling a wheelie or the bike is jacked up where the front wheel is off the ground, the the only force on the compression fork spring is the preload from the fork cap.
The topout springs are compressed when the fork is in tension.  The regular fork springs are compressed when the fork is in compression.
As they used to say on Laugh-In:  "Different strokes for different folks!"
Springs in series function like resistors in parallel, spring rate (force/distance) is reduced.  Springs in parallel function like resistors in series, spring rate is increased.
Please explain.  Thanks in advance.
« Last Edit: January 02, 2026, 07:42:22 PM by SIR REAL ED »
2002 MZ Skorpion
1994 DR Skorpion
Offline Tkelly
« Reply #6 on: January 02, 2026, 06:45:10 PM »
How were the pork chops?
Online faffi
« Reply #7 on: January 03, 2026, 12:08:59 PM »
Decades ago, I read an article about this. And failed to fully understand how and why, I just had to accept it. I wonder if it was in RaceTech's Suspension Bible :huh:
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline Moparnut72
« Reply #8 on: January 03, 2026, 01:09:16 PM »
I watched a video last night, more of a podcast. It was produced by CanyonChasers which was about an hour long. It was all about suspension, including racing, track days and street riding. He and his co-host had Fuzzy from Fuzzy Suspensions on the show. There was a lot of discussion about setting up suspensions. Well worth watching, it sure opened my eyes as suspension setup is not one of my strong points. One thing that really surprised me was that he said that self adjusting suspensions like the one on the V100 S is a no no. He goes into details as to why. Better off to have a standard suspension and set it up to fit the rider and how he rides. I fiddled with the suspension on my V100 standard and thought I was totally out of wack as to what should be done. It turns out for what I wanted I was on track. Well worth watching, I plan on watching again.
kk
« Last Edit: January 03, 2026, 01:17:22 PM by Moparnut72 »
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #9 on: January 03, 2026, 02:50:54 PM »
When mine does this I used to smoke a big bowl to solve it. Now no smoking so have to restructure that process. HA GOOD LUCK
Offline SIR REAL ED
« Reply #10 on: January 03, 2026, 03:52:19 PM »
Now that we are surrounded by virtual reality 24/7, spending money on halucinogenic drugs seems frivolous!
Coast to Coast AM.... Caravan to Midnight..... Wildguzzi.com..... virtual brain jump starting aids are everywhere!
2002 MZ Skorpion
1994 DR Skorpion
Online faffi
« Reply #11 on: January 03, 2026, 05:05:07 PM »
kk
Will watch it later. I am interested to learn how the advice compare to Moss and RaceTech. Link https://www.youtube.com/watch?v=ueO01ILy1TQ
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline turboguzzi
« Reply #12 on: January 03, 2026, 06:08:49 PM »
Well, some magazines had good technical editors, some didnt,
the only people i reckon knew what they were talking about were Kevin Cameron, John Robinson and Massimo Clarke.
If you still like reading rather than watching videos, here's the link to the suspension bible:
http://didier.clergue.free.fr/gsxr/livres/Livre_Race_Tech%27s_Motorcycle_Suspension_Bible.pdf
« Reply #13 on: January 03, 2026, 06:18:11 PM »
Sorry I don't do virtual reality or social media anything, this place is the closest I get to any of it, I'm Mostly ANOLOG do you remember what that is, I doubt it. Your Utube world does not exist except in your own reality NOT mine. I do things I do not watch others do anything, does not interest me.
Offline Moparnut72
« Reply #14 on: January 03, 2026, 08:30:48 PM »
Thanks for posting the link. I have not been able to do it with this stupid Chrome Book.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline SIR REAL ED
« Reply #15 on: January 04, 2026, 09:30:27 AM »
I would add Cook Neilson, Joe Minton, and Phil Schilling to that list.
Great book!  Thanks for posting.
2002 MZ Skorpion
1994 DR Skorpion
Online faffi
« Reply #16 on: January 05, 2026, 03:30:18 PM »
Another suspension video, this one breaks things down to the very basics in order to let people understand the concept of suspension https://www.youtube.com/watch?v=cHeqZGRzzu4
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Online faffi
« Reply #17 on: February 01, 2026, 02:42:38 PM »
I have finally gotten around to watch it. It was very general, leaving us with no other information than what I learned back in 1983 about suspension: As soft as possible, as hard as required. And that a bike should finish a corner. That is useful to know, that it can be addressed with suspension, because I have had a lot of bikes that wanted to go wide. The only bike I have ridden that was absolutely neutral was a Yamaha Dragstar Classic 650. After I significantly firmed up the springing and damping front and rear. But it was still fairly soft. It was comforting to know that no matter how early I opened the throttle, the bike would not run wide. I would start progressively opening the throttle simultaneously as I progressively released the brakes, allowing a short overlap of brakes and throttle. Another benefit of the stiffer suspension was good cornering clearance; the floor boards would touch down about the same time that the peg feelers do on my Roamer, but after that there was a ton of lean possible with nothing else touching down, unlike the Roamer.
A former German racer, BTW, raced a BMW R75 back in the early 70s. Softly sprung as the airheads are, he used softer suspension still on track.
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
