Author Topic: Thanks Wayne O  (Read 4913 times)
Offline jrt
Thanks Wayne O
« on: January 21, 2026, 02:09:54 PM »
Big thanks to Wayne Orwig for drawing and posting 3D printable turn signal stalks.   They were easy to swap out with the cracked-up originals.  The "W" and "O" are a nice touch, as are the eagles.
jrt
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline Dirk S.
  • NO CONTROL
Re: Thanks Wayne O
« Reply #1 on: January 22, 2026, 01:57:50 AM »
That looks interesting! Those use to fail quite often - matter of age.
One question is whether the material used (we call it filament) is elastic enough to dampen vibrations.
The second question is whether the file is available. I can print at a friend’s place, but I can’t create a file (another matter of age …)
90`1000 S
91`1100 Cali III
74`850 T
86`LOW RIDER 1100 ccm
92 1200 ccm QUOTA carb
76´T3 polizia resto project
Online michaell32
Re: Thanks Wayne O
« Reply #2 on: January 22, 2026, 04:03:16 AM »
Last time I looked the file was available on thingiverse. I bought the replacement stalks from mg cycle or Harper's. I can't remember who had them. I don't trust the 3d print for something like this.
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Online Ncdan
Re: Thanks Wayne O
« Reply #3 on: January 22, 2026, 05:45:55 AM »
I had a set for my 03 cali which were a hard durable pladtic material and not rubber.
They worked fine and I don’t believe you’ll be able to tell any difference after you install harder material light stalks.
Offline guzziart
Re: Thanks Wayne O
« Reply #4 on: January 22, 2026, 08:01:14 AM »
Last time I looked the file was available on thingiverse. I don't trust the 3d print for something like this.
If I needed one of these and had access to the print file, I'd run up to our local library (they have a 3d printer) and would print one provided it was a more cost effective approach to obtaining a replacement.  What's to not trust about printing something like this, I don't consider it a a critical safety item but that's just me.  And, while I sit here thinking about it, my LMIVSE rear turnsignal stalks droop, maybe I'll attempt printing a pair of replacements to try this "new" tech.  Thanks Wayne O!
Art
Re: Thanks Wayne O
« Reply #5 on: January 22, 2026, 08:26:47 AM »
jrt
Glad to help out.
Yes the STL files are on Thingiverse. https://www.thingiverse.com/thing:6237141
You need to glue a steel rod though the center and that is the support. The PLA alone is not up to the job and just decorates the rod. Easy to do and no special tools needed other than the printer.
Online michaell32
Re: Thanks Wayne O
« Reply #6 on: January 22, 2026, 12:34:08 PM »
Art
I have seen several 3d printed things suffer from layer separation. With the weight, leverage, and vibration I just don't trust it for something like this.
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Offline jrt
Re: Thanks Wayne O
« Reply #7 on: January 22, 2026, 07:38:45 PM »
I'm not using standard PLA filament.  I'm using a photoreactive polymer and it is very solid.  Have a look at Formlabs printers.  I bought mine from a dental appliance manufacturer that was upgrading their printers.  A lot of dental implants are 3D printed nowadays- who knew?
BTW, I also printed one stalk that is the more hexagonal/angular version.  Oops.  If anyone wants it-  it is free.
L-720
1973 Eldorado
2020 R1250RS
