Author Topic: working on an 850t without wheels  (Read 4313 times)
Offline BIF
« on: January 22, 2026, 12:19:21 PM »
I am going to do a lot of work on my 850T and I need to support it while working on it without wheels. I have considered hanging off the legs of my auto lift with straps, but it is going to be there for a while and I don't want to tie up the lift that long. I also considered putting it on a hydraulic table and lifting in the center, but I am  a little worried about stability. The work will encompass new tires, and a new twin disc setup for the front and checking the rear brakes, and polishing the rims. The tank,front fairing and fender are going to the paint shop, and the bike will get a brand new Bender wiring harness, so it is going to be a long project. what do you guys do when you have no wheels?
Kevin BIF stand for British Italian French
2010 Vespa 300
1975 Moto Guzzi 850T Blue
1993 Ducati 907ie
1975 Moto Guzzi 850T silver
Re: working on an 850t without wheels
« Reply #1 on: January 22, 2026, 01:12:54 PM »
I built a set of saw horse type supports years ago when I was doing a Ambo restore & my LM3 clutch.  It was long before working at the Guzzi dealers. Been using them all along all these years. Made from wood one under front lower tree & one under rear frame rails by where shocks mount. I don't spend $ when I can make things for cheap.
« Reply #2 on: January 22, 2026, 02:02:44 PM »
I whipped this box together about 20 years ago and it has come in handy many times since.
1970 Ambassador
2021 V7-850 Centenario
Online n3303j
  • Ron Cichowski
« Reply #3 on: January 22, 2026, 06:21:55 PM »
I hang them from a sound ceiling beam (rafter) using a couple of Come-Alongs.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Moparnut72
« Reply #4 on: January 24, 2026, 09:08:16 AM »
I am currently rebuilding a T3. I am using a combination of a chain hoist from a gantry track, floor jack, center stand and a small motorcycle lift depending what I am doing. I just ordered two new tires an hour ago so it will be on the wheels shortly. The bike was an absolute mess, semi basket case, it has obviously been apart before. Quite a few SAE fasteners and the wiring has been all hacked to hell. First Guzzi I have done so I have had to back track a couple of times.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online Dukedesmo
« Reply #5 on: January 24, 2026, 09:28:18 AM »
No wheels and stable;
Le Mans II
Ducati 916
Ducati M900
Offline theoneandonlymin
« Reply #6 on: January 26, 2026, 01:08:50 PM »
Guzzi engine stand is the business. It may be still available. Nice range of adjustment. Apart from my G5 I've used it on my Stelvio, NorgeGT and an XT600.
Cheers
Offline janguzzi
    • My YouTube Channel (Guzzi Content)
« Reply #7 on: January 26, 2026, 02:12:31 PM »
A lifter with a mounted blockboard under the engine and square timber under the gearbox.
Kind Regards
Jan, Schuby (near the Danish Border), Germany
www.janguzzi.de
-1992-2002: 1000S, 2nd Series
-2002-2004: V11 Le Mans "Grigio Titanium"
-2004-2011: V11 Le Mans "Rosso Corsa" & 2008-2011: 950S
-2018-2021: California Vintage
-2011: Griso 8V & 2023: V85 TT "Giallo Mojave"
Offline Moparnut72
« Reply #8 on: January 26, 2026, 02:38:26 PM »
This what I use plus a chain hoist on a track mounted on the bottom of the trusses. I will also enlist a floor jack if needed. I have used all three on my T3 project.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline Groover
    • Scooteropolis
« Reply #9 on: January 28, 2026, 12:58:56 PM »
Similar to Dave's, but with mobility. I added a vertical, notched 2x4 towards the rear, if I remember right at the centerstand "axle". It was pretty stable overall, got the job done. That dark wood is/was a railroad tie.
« Last Edit: January 28, 2026, 12:59:36 PM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline snobear
  • 1980 1000SP, 2022 V85, 2012 DR650,
« Reply #10 on: January 28, 2026, 03:48:51 PM »
Nice looking project coming together there
1980 1000SP
2022 V85
2012 DR 650
1997 BMW R1100R Hack
I do these things not to escape life but so life does not
escape me
Offline turboguzzi
« Reply #11 on: January 30, 2026, 04:21:04 AM »
Neat
Who did a Piaggio Si ever arrived to the states?
« Reply #12 on: January 30, 2026, 07:04:52 AM »
Thanks.  That was my 1980 T3 California.  Now finished
1970 Ambassador
Offline Missionguzzi
« Reply #13 on: January 30, 2026, 03:25:35 PM »
I've done this many times and haven't really had a problem with stability.  I have an ancient hand-cranked motorcycle lift with a platform about 15 x 18 inches.  I put it under the sump just forward of the center stand, and insert a wooden block (4" x 4", I think) under the transmission, so the bike doesn't tilt too far backwards.  Both wheels will come off the ground enough to remove them.  I also keep the center stand down, and put a 2X4 under it for added stability and leveling.  Never had one become unstable except due to my own stupidity by trying to push the bike too far sideways on the lift.
Offline BIF
« Reply #14 on: February 03, 2026, 12:09:22 PM »
Thanks for all the ideas, and I thought I would follow up with what I did. Some of them I used and some of them I filed for future use when I add a motorcycle lift to the garage.
First thing I did was put some straps on my auto lift. This was only complicated by the fact that I had a dead vehicle on the lift that could not be moved, but not too difficult. I just connected the straps to the arms of the lift, and then when I had it secured I lifted the vehicle, motorcycle and all. I lifted far enough that I could wheel a HF table underneath it. The table raises and lowers and I use it to remove engines/transmission combos that some out the bottom. so I was certain it would be strong enough, and I could roll the motorcycle around to different places in the shop.
Next I just set it on a couple of 2x6 and set it on the oil pan, and then ran a couple of straps to tie it down.
Am I completely happy with this setup. No, with the rear wheel on it, it is a little unstable. While the table is down a floor jack under the rear tire really stabilizes it. I think once I remove the rear wheel I will become much more stable. The table also raises and lowers which will help when installing the wiring harness, and I think I have enough room to install a center stand which this vehicle lacks but I would like. My next biggest problem is that while I will clean up, I really want to avoid the "Might as well" syndrome and do a total restoration. I will let you know haw that works out.
2010 Vespa 300
1993 Ducati 907ie
