Author Topic: Ring gear teeth chewed up.  (Read 12997 times)
Offline neetones
« on: January 22, 2026, 05:48:17 PM »
Teeth are all chewed up in the same way. Bike would start okay but it was a bit crunchy.
Any suggestions? Can I dress it with a file and even things out or do I really need to look into replacing this and the starter?
1969 Ambassador
2022 V7 850 Centenario (sold)
Re: Ring gear teeth chewed up.
« Reply #1 on: January 22, 2026, 06:09:58 PM »
The starter is fine - the teeth are made that way. The ring gear is another story - that's pretty chewed up. I'd try to find a better one.
Offline n3303j
  • Ron Cichowski
« Reply #2 on: January 22, 2026, 06:14:02 PM »
I'd dress the ring gear and use the system.
But! Unless you routinely hit the starter starter button when you need the horn you need to find out why the starter is not fully engaging before beginning rotation.
When the start button is pressed the solenoid pulls a fork that brings the small bendix drive into engagement. At the end of the stroke the solenoid connects the high amperage line to spin the starter motor. Your starter motor is being turned on too early in the cycle.
First thing I'd do would be to thoroughly clean and lubricate all parts of the starter motor. Yours looks really gummed up.  Maybe the bendix drive isn't advancing fully before spin up. Or maybe it's disengaging too slowly. The small gear is on a helix that under starter power drives it into full engagement and at startup pushes it out of engagement (and freewheel as engine speed exceeds starter speed).
So first add personal labor. It's the less expensive alternative. If rhat doesn't work then add starter and ring gear.
« Last Edit: January 22, 2026, 06:16:28 PM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Moparnut72
« Reply #3 on: January 23, 2026, 06:30:23 PM »
What bike is this? I have one depends on which bike.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online Dukedesmo
« Reply #4 on: January 24, 2026, 09:23:35 AM »
Seeing that you have it all apart, it would be crazy not to replace it.
You don't want to reassemble everything and then dismantle it again to change it when it fails, the hours it will take is not worth the cost of a new (or good used) gear.
Le Mans II
Ducati 916
Ducati M900
« Reply #5 on: January 24, 2026, 11:34:27 AM »
kk
Although the early ones are slightly heavier, pretty much any of them with the dual-plate clutch will work.
Offline lazlokovacs
« Reply #6 on: January 24, 2026, 12:27:43 PM »
I dunno, I had a ring gear chewed up exactly like that due to a faulty starter that was spinning but not fully advancing, once I swapped in a proper starter motor it never gave me any more trouble. Never had to bother swapping out the ring gear.
maybe I got lucky
YMMV
« Reply #7 on: January 24, 2026, 12:58:26 PM »
It says 69 Ambo if you look
Offline Moparnut72
« Reply #8 on: January 24, 2026, 03:08:02 PM »
I didn't look down at the bottom. I was going to offer one for a nominal amount plus shipping but there is a whole clutch assembly plus flywheel on eBay for $30 + shipping which is $27 or so. I would post a link but on this goofy Chrome book a pain to do. Easy to find though.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #9 on: January 24, 2026, 04:10:50 PM »
kk
This one? https://www.ebay.com/itm/135647623698 Doesn't come with the ring gear it seems.
« Reply #10 on: January 24, 2026, 04:46:35 PM »
That is what it looks like. Like the starter did not fully engage, or stuck partly engaged, and chewed up the ring gear. And I would guess the starter gear is hardened a LOT more than the ring gear.
Offline Moparnut72
« Reply #11 on: January 24, 2026, 07:45:29 PM »
That's the one. Seems like an awesome deal to me. I also have a complete clutch but that one is a bit cleaner. The one I have came out of a bike that had been sitting for a few years or probably a lot more.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #12 on: January 24, 2026, 09:57:26 PM »
kk
It's an okay deal but doesn't have the part (ring gear/clutch cover) that neetones needs.
Offline Moparnut72
« Reply #13 on: January 25, 2026, 07:44:21 AM »
I would think he has that part already. He just needs the ring gear the rest is extra spare parts.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #14 on: January 25, 2026, 08:51:24 AM »
kk
The auction you referenced and I linked to does not include the ring gear, which is the part neetones needs. The topic of this thread is "Ring gear teeth chewed up" after all. Buying that $30 flywheel and clutch parts would therefore be a waste of money (unless he needs those parts too).
Offline Moparnut72
« Reply #15 on: January 25, 2026, 04:03:38 PM »
Yes, I think I got that one confused with another I looked at. There is a complete clutch listed or $98 plus $13.45 for shipping. It is for a later bike so I don't know if it will fit or not. I have tried to copy and paste the address but I haven't figured out how to do it on this new laptop.
kk
« Last Edit: January 25, 2026, 04:05:58 PM by Moparnut72 »
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online faffi
« Reply #16 on: January 26, 2026, 12:57:37 AM »
kk
If right click and choose copy does not work, and ctrl+c does not work, it could be that fn+c will work in order to copy. At least Lenovo seems to be set up this way where fn is placed to the left of ctrl.
Current bikes:
2002 BT1100
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Offline neetones
« Reply #17 on: January 26, 2026, 11:33:15 PM »
Thanks all.
I took the starter apart and cleaned and lubed it. Found a slightly used and much nicer ring gear on Ebay for $30 plus shipping!
Let's hope it all works out and doesn't eat up the new ring gear.
1969 Ambassador
Offline Croft46
    • Limited Slip Diff&Locking Differential Supplier - XJX Parts
« Reply #18 on: April 28, 2026, 01:44:54 AM »
I found this differential calculator quite helpful for checking ratios and tooth counts:
https://www.xjxparts.com/differential-calculator/
It might be useful when figuring out ring gear and pinion combinations.
