Author Topic: What's your preferred engine size?  (Read 6856 times)
Offline faffi
« on: February 10, 2026, 05:20:40 AM »
All thing else being equal, let's say a wet motorcycle weight of 500 lbs and 60 hp from the engine, the engine being of typical Guzzi design (air cooled V-twin), what capacity would you prefer?
Realistically, the engine would need a capacity of at least 450 cc to reliably deliver 60 hp, but it could also be ten time as big if someone prefer. Ignore the obvious, that a larger engine would be heavier, just imagine it would not. Basically, would you want a screaming 450 or a loping 2-liter or something in between?
Current bikes:
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Offline auzziguzzi
  • This ain't no dress rehersal
Re: What's your preferred engine size?
« Reply #1 on: February 10, 2026, 05:42:10 AM »
For solo riding, a 650cc air-cooled, 90º, V-twin.
For two up riding with luggage, a 1000cc, air-cooled, 90º, V-twin.
Since your parameters state that both bikes weigh 500 lbs and each has 60 hp and both are air-cooled, there is nothing to separate them, there.
However, the bigger engine would be higher geared, lower revving with more torque.
It would engender a more leisurely feel to the day's riding.
The 650 would be higher revving and more sporty with most likely a smoother power delivery, remembering that both are 60 hp.  It would be a sweet motorcycle.
'96 Sport 1100c (67,084 km)
'83 V50 III (80,000 km)
'06 Norge (169,000 km)
'90 NTX 650 (66,911 km)        SOLD 21/08/2025
'06 Breva 1100 (84,505 miles) SOLD 03/03/2022
« Reply #2 on: February 10, 2026, 05:44:05 AM »
In my heart motorcycle engines should be air-cooled and about 1000cc give or take a couple hundred at most.
Once it meets or passes 1.5L it starts to feel like an exercise in excess.
I understand how emissions standards and marketing have pushed size and power, but my last Harley had more displacement than at least one car I've owned and that's dumb.
It's one of the many reasons I'm personally embracing the smallblocks as a comparative exercise in "minimalism" without all the work of actual minimalism and having to worry about getting run over on a T125 or a Grom.
« Reply #3 on: February 10, 2026, 06:15:31 AM »
Screaming 450/550's didn't set well for Aprillia, putting out 80+ hp. Owners failed to listen to the engine & pistons flipped. Last ones you got 2 for 1 price.
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #4 on: February 10, 2026, 06:16:40 AM »
I think the state of tune of the engine would be more influential than engine size.  That and intended usage.
I remember 35 years ago, getting off my Suzuki GS1000G and getting on a friend's Kawasaki Ninja 500 and being astounded by the wide powerband, low end torque, and top end horsepower of that puny 500. Of course, that is apples to oranges, a 1970's two valve air cooled motor vs a 1980's four valve water cooled motor.
For where I ride and how I ride, 500 lbs is 100 lbs more than I prefer.  Still hard to beat a Suzuki DR650 for versatility.
Based on my buying history, I have owned a lot of 650's.
Although, I think the Royal Enfield 650 twins might fit the bill.  The parallel twin with a 270 degree crank feels very similar to a 90 degree V-Twin.  IIRC, someone makes a 865cc kit, in case 650cc doesn't cut it.
If superchargers ever come into the production world (electric powered, and activated by button or voice command?), I suspect 350cc engines might just surprise a lot of people.
« Last Edit: February 10, 2026, 06:39:47 AM by SIR REAL ED »
2019 Beta EVO 250
Offline SIR REAL ED
« Reply #5 on: February 10, 2026, 06:24:30 AM »
Yep!  I bought 2 for 1 in 2012.  One of the most amazing, exciting motorcycles ever made. Mind blowing if not quite practical styling.
All it needed was a total engine teardown and rebuild by a master like Allan Noland before you started it.  Then keep your eye on the oil level and change it often (no oil control rings on the pistons), and you had a very reliable bike.
3 or 4 simple design changes upfront, followed by not allowing drunk people to assemble the bike, and those engines would have changed motorcycling for a lot of people.
I think the closest modern equivalent in terms of riding excitement would be a KTM Duke 690.
2019 Beta EVO 250
« Reply #6 on: February 10, 2026, 06:55:26 AM »
These days, 900 - 1200 cc.
I’d settle for an even 1000.
Online Perazzimx14
« Reply #7 on: February 10, 2026, 07:13:25 AM »
Parameters are a air cooled transverse V-twin engine producing 60hp in a bike weighting in at 500lbs and the amount of CC's would not effect weight or performance. Since CC's have no effect this is sort picking a sticker for the side panel.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline faffi
« Reply #8 on: February 10, 2026, 07:25:20 AM »
CC would alter torque and the revs needed to make 60hp.
Current bikes:
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
« Reply #9 on: February 10, 2026, 09:08:10 AM »
They came in restricted & had to be un so they would go faster than 15mph, cut stuff out of exhaust & install a tune. Piaggio tour truck came one year with a road race bike w/250 frame & 450 motor in it, cool bike.
Online johnwesley
« Reply #10 on: February 10, 2026, 09:55:38 AM »
I like an engine that pulls good without having to wring its neck. So I would want a larger capacity engine, say 1000-1100. That said a smaller engine if the midrange was there would be fine. Typically a larger engine with the same hp is under less strain and therefore lives a longer life as well. So let’s just keep to 1000-1100cc
2003 cal ev custom build/ adv scrambler thing
2000 Quota
1989 cal III FF
1985 cal II
1977 T3 California
Offline MGrego
« Reply #11 on: February 10, 2026, 10:32:09 AM »
500 lbs, 60hp ?
Sounds like my 04 Triumph Bonneville T100.  Parallel Twin 790 CC.
Offline SIR REAL ED
« Reply #12 on: February 10, 2026, 10:32:25 AM »
I remember the 48mm (?) throttle body butterflies didn't even open enough to allow a 1/4" ball bearing to pass.  All the experts said "Don't even start it!  Take it to Allan immediately!"  I disobeyed.  Even in restricted form it would still throttle only wheelie easily.
Another Achilles heel was the oil soluble sealant they used on the engine cases!  Red not black stuff IIRC.
2019 Beta EVO 250
Offline Bulldog9
« Reply #13 on: February 10, 2026, 11:13:53 AM »
I bought my first 'adult' street bike in 1986. In the years that have passed, all but 4 have been liter+
Yamaha XS 750 & 650 - Moto Guzzi V7ii & Breva 750. Of those, the only one I REALLY like is the V7ii.....
So, I guess you could say I prefer Liter +.  I had an MGX 21, and found it too big. I had an FJR 1300 and liked it but it became boring unless I was riding at go to jail or morgue speeds.
I loved my FZ1 and C10 Concours, and absolutely love my 1000 Convert,  1100 Griso, 1200 Norge, so to dial it in, between 1000 & 1200 CC is my preferred engine size. Will be interesting to see how the 853cc V85 jives with me. I think it will be mighty FINE..........
MGNOC#23231
Offline faffi
« Reply #14 on: February 10, 2026, 12:18:31 PM »
I would not have minded a 2-liter engine geared to turn 2000 rpm @ 60 mph.
My Mongrel fitted with a Virago 1100 engine makes a claimed 62hp and so comes pretty close to what the majority so far have asked for, apart from it not being a Guzzi. The Yamaha engine is more satifying in every functional way than the V9 in my Roamer, but the difference is not miles apart.
Current bikes:
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Online Ncdan
« Reply #15 on: February 11, 2026, 05:55:58 AM »
A decade ago I was on a 900 pounder.
The last few years 650lb.
Now waiting for the spring delivery of a V50 coming from Maine. I think, what 400+or -?
Offline Dukedesmo
« Reply #16 on: February 11, 2026, 06:37:57 AM »
Ideally around 900-1,000cc with 2 cylinders which all my bikes are.
I consider the optimum size of a cylinder for a 'proper' power delivery is around 500cc (+/-50cc) - not keen on small capacity i4 engines.
I try to stick to this 'rule' where possible with both bikes and cars and, infact my 3 bikes and 2 cars all have cylinder sizes between 450-500cc.
Le Mans II
Ducati 916
Ducati M900
Offline blu guzz
  • Loves to ride
« Reply #17 on: February 11, 2026, 06:38:33 AM »
my old r100rs was around 60 hp and a little over 500 lbs and was very satisfying in the midrange at the time.  it would shoot from about 50 to 90 pretty fast.
Blue Guzz
Online TN Mark
« Reply #18 on: February 11, 2026, 08:56:43 AM »
For the last 12 years, it’s been the Victory 106” (1737cc) with enhanced intake, exhaust, tuning and cams etc. The end result being 114 RWHp and 114 RWFtTrq. Absolutely a wonderful experience in power to weight, sound and fun. I hope to have that bike till my end.
Installing a 117” (1917cc) to the Victory bumps both RW numbers to about 139 which is quite an amazing ride. But, parts alone are nearly $7k so, no, not today.
Since getting the Eldorado 1400 (84cu inch) late last year, with its similar enhancements (except cams), it seems to punch well above its weight class. I’ve never owned or been interested in a bike under 1000cc.
Someday there may be a small block in my future, but most certainly not now. I’m only 65 and still fit for riding.
Decades ago I did build my G5 into a beast with 36mm carbs, a RaceCo cam and a lightened flywheel from Moto International. Plus all the other ‘normal’ upgrades. That old Guzzi was amazing. I think I was CA Mark here on the forum at that time.
I don’t recall ever leaving any bike stock.
« Last Edit: February 11, 2026, 09:16:01 AM by TN Mark »
Offline Joliet Jim
  • Justus Esto, Et Non Metue
« Reply #19 on: February 11, 2026, 10:39:56 AM »
I've always preferred 500cc per cylinder for a single or twin or 250cc each for a triple.
2002 Cali Stone "Moby Dick"
2003 Buell Blast "Pegasus"
Online bad Chad
« Reply #20 on: February 11, 2026, 04:44:07 PM »
Mark, this statement you just made makes you seem a little out of touch,
"Someday there may be a small block in my future, but most certainly not now. I’m only 65 and still fit for riding."
Your notion that a sub 1000cc bike is for the old, or riders who just can't handle a liter bike is misguided.   I'm 6'6 240Lb and 59 years of age, and I have chose to ride 853cc bikes the last few years.  I can easily handle much bigger bikes, and I'll give you, there is something to be said for big time cc's, but to conclude that sub 1000cc bikes are for those who can't handle or enjoy the big stuff is absurd.  I get the idea that you don't know what you're missing?   But I'm happy your happy, but I suggest you keep an open mind to the possibility of the excitement and enjoyment that a smaller motor can provide.
Offline SIR REAL ED
« Reply #21 on: February 11, 2026, 06:51:29 PM »
I re-read that post several times.  I don't think Mark asserted anything like that at all.  But I can see how one might assume that.
As always, content is determined by the receiver, not the transmitter.
One of my favorite sayings:  "People!  They're all like that!"
"Only you can prevent forest fires..... or determine the best looking bike, or determine the best engine size, or figure out what the inkblot really is!!!"
Which is what makes human communication so fun!  It will be a really boring day when everyone understands everyone else perfectly!!
We'll miss these tumultuous times where our imaginations were like wild horses if that day ever happens!!!
« Last Edit: February 11, 2026, 07:01:19 PM by SIR REAL ED »
2019 Beta EVO 250
Online TN Mark
« Reply #22 on: February 11, 2026, 08:43:34 PM »
You have your notions Chad, I have mine.
Are you saying my preference of motorcycles isn’t valid because they don’t align with yours?
Our preferences and our experiences are quite different.
I only hope you enjoy your motorcycles as much as I enjoy mine. Ride what you like and I’ll do the same.
Carry on.
« Last Edit: February 11, 2026, 09:07:23 PM by TN Mark »
Online elrealistico
« Reply #23 on: February 12, 2026, 04:57:37 AM »
750-ish CC. As it happens, the V7III and 78 Bonneville have the exact same displacement-744cc. 40 years apart. Largest bike I had was a 1200 Suzuki Bandit.
2018 V7III Special
1978 T140V Bonneville
2004 EV Touring
Offline SIR REAL ED
« Reply #24 on: February 12, 2026, 07:06:49 AM »
650 - 800cc seems to be a design sweet spot for motorcycle engine size with current technology.
2019 Beta EVO 250
Online TN Mark
« Reply #25 on: February 12, 2026, 09:04:53 AM »
I think the design sweet spot varies by the engine and it’s associated components. Regardless of the engine size.
For instance, my Victory 106” in 6th gear at 80mph is turning about 3000rpm and returning about 40mpg.
That, to me, is that particular configurations sweet spot.
There’s no particular technological limit to materials or design that dictate an engines capacity. Small motors have their sweet spot, same with medium and larger motors.
Many factors contribute to a particular setups sweet spot. A Bergman 650 has one, as does a Guzzi V7, as does a Harley with a 121” setup. It doesn’t seem engine size matters. The overall design of the ‘system’ most certainly does though. People have a preference for an engine size. But that preference doesn’t necessitate a particular engine size. It’s just their preference.
I tend to like big bikes with big motors and big power. Others prefer medium sized bikes with medium sized motors and power etc. that simply personal taste and preference, nothing more.
I don’t have enough miles on the Eldo 1400 to make a claim if it’s sweet spot. I can only go by what others report. Though my particular Eldorado 1400 likely has a different fuel map and exhaust than most. Therefore, I’d ‘guess’ the sweet spot may be somewhat different as well.
Offline SIR REAL ED
« Reply #26 on: February 12, 2026, 09:27:34 AM »
Good points.  Better language on my part may have been "marketing sweet spot" or "sales quantity sweet spot."
600cc sport bikes make over 100 HP.  Even a so-called beginner's bike of the late 1990's, like an SV650 will stomp all the mind blowing superbikes of the early 1970's into the ground in any measure of performance.
As I noted before, a friend thought my DR650 (35 HP) was more powerful than his son's GSXR600 (100+HP).
The difference between a DR650 and a KTM Duke 690 is phenomenal!!
Preferred usage and owner desired "sweet spot" probably makes more sense as metrics than any mechanical aspect of the motorcycle.
I suspect, desired mood requirements in the owner, mandates why many people own more than one bike.
What stimulus buttons do I wan t pushed today, determines which bike leaves the garage, and which routes are selected.
2019 Beta EVO 250
« Reply #27 on: February 12, 2026, 09:54:02 AM »
My favorite motorcycle was the Guzzi Sport 1100.  Under 500 lbs.  Putting out about 80 bhp at the rear wheel, after some tuning.  Lots of character.  It was great!  Beautiful sound from the full Staintune exhaust.
Runners up are the 1000 LeMans and the V11 Lemans I also owned.  Same reasons.  Nice chassis, moderate weight, good power.  Enjoyable to ride.
Seems to me that 450-500 lbs and 75-80 bhp V-twin is a good sport-touring combination.
The 1990s Ducati SS900 and ST2 were also real enjoyable to ride, for the same reasons.  Moderate weight, good power delivery, enjoyable to ride.
I've not ridden the V100 Mandello, yet, but suspect it's along these lines.
Online Dr. Enzo Toma
« Reply #28 on: February 12, 2026, 10:04:23 AM »
Since the displacement would only really impact the dyno curves in this hypothetical, I'd go with large displacement on a pushrod engine, small displacement on an overhead cam engine. Between the two engineering marvels, I prefer OHC and a high revving engine.
MGNOC Member
Online bad Chad
« Reply #29 on: February 12, 2026, 10:27:38 AM »
Carry on.
Ride on Brother.
