Author Topic: Brighter taillights  (Read 15712 times)
Offline slowmover
Brighter taillights
« on: April 01, 2026, 10:29:39 AM »
Will the PHINLION 3600 Lumens bright taillight work safely in a 2013 V7? Or is there a better alternative?
« Last Edit: April 01, 2026, 10:30:19 AM by slowmover »
Re: Brighter taillights
« Reply #1 on: April 01, 2026, 10:48:53 AM »
Never used that particular one. You want a red LED behind a red lens. I use these:
https://www.amazon.com/dp/B074GPX2Q8
Offline ridingron
« Reply #2 on: April 01, 2026, 09:13:05 PM »
Will you need a load resister with these?
« Reply #3 on: April 02, 2026, 08:26:06 AM »
Never needed one with the LEDs I use.
Offline DoubleGuzzi
« Reply #4 on: April 02, 2026, 09:27:20 AM »
Primarily to control indicator flash rate though the low resistance may appear as a short for standard bulbs on 'uneducated' canbus systems.
Nearly natural progression..
Online Bulldog9
« Reply #5 on: April 02, 2026, 01:37:53 PM »
I use these too. Work very well. 8 years for the Stornello, and 6 for the Convert.
As for needing a resistor, not for tail/brake or headlights. LED's are an easy plug and play. The issue with LED's is related to the load on the turn signal relay.  I usually just skip the TS, not worth the time or $$, but the head and tail/brake lights are worth the $$ IMO.  Much less load on the system for the constant on.
MGNOC#23231
Offline DoubleGuzzi
« Reply #6 on: April 02, 2026, 04:11:38 PM »
For a different perspective..
In the UK, replacing halogen headlight bulbs with LED is not allowed. This blanket ruling is no doubt due to the majority of LED bulbs that do not fully replicate the correct beam pattern. I've had to return to a standard bulb during an MOT (roadworthy) test, in order to pass. I now stick with just replacing/upgrading the side/pilot light with LED.
I do replace tail light bulbs with LED but the aim is not necessarily to increase brightness, rather improve resistance to the considerable vibration and hopefully extend longevity. Do consider that a brighter tail light on its own may confuse following vehicles, who may not think that you are braking. There may not be a sufficient difference to light levels when comparing the (normal) running tail light to when braking.
I prefer to wire in a cheap additional tail and stop light, with integral reflector. This replaces the OEM reflector on EU bikes, that sticks out underneath the number (license) plate. Different shapes are available, including semi-oval ones that fit well on modern Triumphs, for example.
« Last Edit: April 02, 2026, 04:22:47 PM by DoubleGuzzi »
« Reply #7 on: April 02, 2026, 07:15:11 PM »
If the taillight bulb also illuminates the license plate, then a red LED won't pass inspection here in Maryland (and likely other states as well). All of my current fleet are "historic", so that's a non-issue to me.
The bulbs I use, and linked to, have a very noticeable difference between taillight and brake light brightness. There is going to be no doubt that I'm braking.
Offline TN Mark
« Reply #8 on: April 03, 2026, 08:10:31 AM »
Thank you for this. I ordered it yesterday for my  Eldorado 1400.
« Reply #9 on: April 03, 2026, 08:22:56 AM »
I also have them in my vintage bikes.  Work well.
« Reply #10 on: April 03, 2026, 11:14:51 AM »
Superbright led may still have a tail red light bulb with white led's on one side to light the license plate.
Offline TN Mark
« Reply #11 on: April 04, 2026, 11:32:26 AM »
Thank you again for this information and the link. Two red LED 1257’s came in today. One has already taken up residence in the  Eldorado.
It’s a terrific improvement.
Next up, the Eldorado headlight and the driving lights need a major upgrade as well.
« Reply #12 on: April 04, 2026, 12:26:12 PM »
You're welcome.
« Reply #13 on: April 04, 2026, 05:58:44 PM »
For the headlight on the Eldo, you might look at this one. I have not ridden at night yet, but it's quite bright daytime. The looks are not quite right for an Ambo though:
https://www.amazon.com/dp/B0BJ1ZD3LF?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2
On my Eldo, I went with a H4 LED some years ago that seems to be pretty bright and a decent pattern in a H4 lens, I can look up the P/N if needed,
« Reply #14 on: April 04, 2026, 08:32:24 PM »
I have this one installed on a customer's "1200 Ambassador" project, which isn't on the road yet, so no feedback on brightness or beam pattern. https://www.amazon.com/gp/product/B0BNT4V2VC
Online Perazzimx14
« Reply #15 on: April 05, 2026, 09:02:13 AM »
When I had my DR650 I picked up a inexpensive pair of 1157 LED bulbs in the Walmart automotive section for under $20. They even had a 3 pulse strobe feature.
Offline SemperVee
  • USMC Retired
« Reply #16 on: April 10, 2026, 06:39:40 PM »
 Add a set of "Hyper-lites"...  I installed them on all my bikes and people stop way further back then without them.
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
« Reply #17 on: April 10, 2026, 07:46:23 PM »
With the bulbs I linked to, the same thing happens, especially on the Convert that has two bulbs in the taillight.
Offline larrys
« Reply #18 on: April 11, 2026, 07:53:50 AM »
I changed all of the bulbs in my Cal to LED's, including the dashboard lights. To check the headlight beam pattern, I put a big piece of cardboard in front of the bike and drew the outline of the halogen beam pattern with a sharpie. I then installed the LED emitter. The beam pattern from the headlight remained the same although considerably brighter and a whiter light. I bought a no-load flasher from Greg Bender so the turn signals would work. They're much brighter and flash like strobe lights. YMMV.
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
