License plate light assembly
Topic: License plate light assembly (Read 4747 times)
slowmover
Locked in the arms of a crazy life
April 08, 2026, 05:34:44 PM »
Can’t seem to find one. I checked MG Cycle and Harpers. It broke away from the screws. I might could just glue it as I never ride in the dark. Was there a lens on top? It’s a 2013 V7
Dirk_S
www.dirkshearer.com
Doodler of doodles
Re: License plate light assembly
Reply #1 on:
April 08, 2026, 05:41:35 PM »
Is this one on eBay too ugly for you? Could always spray paint it with chrome paint:
https://ebay.us/m/C1qWOy
slowmover
Reply #2 on:
April 08, 2026, 05:52:28 PM »
I need the bracket it’s attached to.It bolts on from the back inside the fender.
slowmover
Reply #3 on:
April 08, 2026, 06:00:18 PM »
It’s a weird set up. You can’t
access the screws going into it. You have to replace the whole assembly
73 sport
Gosling
Reply #4 on:
April 08, 2026, 06:03:00 PM »
Unscrew the broken piece, glue it back with acrylic glue. reinforce it with flat tooth picks on the sides. Gently screw it back together.
73 sport
Gosling
Reply #5 on:
April 08, 2026, 06:08:31 PM »
There should be nuts on the tire side of the fender, undo them , the unit should come off and you should have access to the lens holding screws.
slowmover
Reply #6 on:
April 08, 2026, 08:01:12 PM »
I think I’ll glue it. Kind of a cheaply made piece anyway. Thanks all
guzzisteve
"Just Ride It"
Reply #7 on:
April 08, 2026, 08:02:16 PM »
Ebay unit is same lite but longer away from fender, more depth. Same base.
MattP
Gosling
Reply #8 on:
April 09, 2026, 06:53:16 PM »
glue it on with silicone or hot glue and ride it
