Author Topic: 2026 V7 E5 Driveline fluid volume question...  (Read 6139 times)
Offline Michael_A
    • Penguin Video Productions
« on: April 16, 2026, 03:47:28 PM »
2026 V7 Special, not even 200 miles yet. Decided to "check" gearbox (transmission) and final drive fluid levels. But ya can't do a check! So I did a measured drain and refill. But I found a discrepancy that I hope I can at least receive some reassurance on.
Final Drive: (yeah, they call it the "transmission"). Noted on fill plug it is stamped 130cc max. Note in manual it also states 130cc max. Measured the drain and got almost exactly 130cc's out of it. NOTE: fluid was BLACK, with a surprising amount of fuzz on the magnetic drain. Hmmmm... Refilled with 130cc. I think this should all be OK....
Gearbox: (what the rest of the world calls the transmission). Now this thing has a TOP fill plug AND a side fill plug. Service manual does NOT reference the side fill plug. Noted prior to draining that fluid level was right at the lower threads of the side fill. BUT upon a measured drain I got around 650cc out! Manuals state to fill with 500cc's. 500cc's is around 3/16 below the side fill plug lower threads. So the question is... go with 500cc's as stated in the shop manuals OR has there been some upublished change or best practice to fill to the lower threads of the side plug (around 650cc's or so). Suspect delivering dealer "topped it off" resulting in a minor overfill? Put 500cc's back in (measured). Of course now I can hear the "chaka-chaka" at idle that I probably couldn't with my helmet on and the bike off the lift and am wondering "did I do this right"?
Thought I might add a few more observations on this 2026 E5... gearbox drain is 17mm; and it dumps over the exhaust (a big catalytic converter or resonance chamber). Make a "funnel" out of tinfoil to go over the chamber/cat and divert to drain pan. Very fiddly to get drain bolt back in. But you can at least get a open end wrench on it just in front of the rear master/frame rail (tight, but do-able). Small hands necessary. Yuk. Also, the manual references a filter screen to be removed and cleaned. None present and the drain orifice really seems too small to accommodate one as shown in the manual. Suspect they did away with it?
« Last Edit: April 16, 2026, 03:55:02 PM by Michael_A »
Offline Vagrant
Re: 2026 V7 E5 Driveline fluid volume question...
« Reply #1 on: April 16, 2026, 07:00:39 PM »
Where did the 500cc come from? Owners book, shop book? The 2017 v7III went to a 500cc of 90 weight and a nylon filter because they put an oil pump in it. The V85 went back to 700cc and no pump and no filter.
I'd go th AF1 and look at both books. I bet it's the 700. Let us know.
Offline Michael_A
« Reply #2 on: April 16, 2026, 07:14:05 PM »
Have the shop manual (2Q000601, V7 E5+ (2025-), owners manual (both from F1, correct for model and year, 2026), and the printed owners manual that came with the bike.
For a 2026, V7 E5 all of them are consistent in stating 500cc for gearbox fill.
I understand the earlier versions have a different amount, but it appears that something changed along the way.
The nylon filter is definitely not there, nor is it possible to fit one - so THAT is a different change, along with the questionable usefulness of of the side fill plug.
Offline Michael_A
« Reply #3 on: April 16, 2026, 07:18:36 PM »
Screenshot from the above referenced service manual.... Page 23....
Consistent with the amounts stated in both the printed and on-line owners manuals...
None of these reference the side fill plug....
« Last Edit: April 16, 2026, 07:20:21 PM by Michael_A »
Offline Michael_A
« Reply #4 on: April 16, 2026, 07:27:17 PM »
And this from Page 98 of the on-line downloaded (from F1) owners manual which corrisponds to the printed manual I got with the bike, which is consistent with the service manual posted above. And again, no mention of the side fill....
Offline Michael_A
« Reply #5 on: April 16, 2026, 08:03:00 PM »
I think my anxiety is precipitated by the presence of the new side fill plug.
Regardless of the filter screen being present or not (and obviously there was a change in it's status) all the documentation I have states 500cc. OK, if all I had to work with was that spec and a top fill hole that's what I would put in (and did). But the presence of the side fill hole without any factory documentation causes me to question this. To fill to it's bottom would be around 650cc. Still a bit short of the previous generations 700cc's. Yes, the V85, which is supposed to be basically the same drive-line has a different spec. So do the earlier V7's (like the II and III).
But there are obvious changes noted, like the seeming elimination of the filter screen and the now smaller drain plug (going from 24mm to 17mm). I find myself wondering who to trust, the manuals or the side fill hole. And I can't get solid confirmation (though I have a strong suspicion) the dealership likely "topped up" via the side fill, resulting in 650cc's being present rather than the spec'ed 500.
It's like that old saying, "when you have ONE watch, you know what the time is, but if you have TWO, you are never certain!"
Hoping someone "in the know" may have a TSB or SOMETHING to help clarify the confusion. If nothing else, I've got 500cc's in there now so if it blow up under warranty it is at least the spec they published in multiple places that I can document, but would certainly like to avoid that exercise!
Offline Kev m
« Reply #6 on: April 16, 2026, 08:15:15 PM »
Dude, get a grip.
Guzzi level plugs are often disregarded.
Hell Guzzi capacities are often questioned.
The V7I has nothing to do with this, it was a 5-spd.
I think the V7II and V7III were the same, the first 6-spd with the removable filter and an oil pump.
I can't say about the V85, or other V7850's as they can (and often do) change things
Is the exploded view available in the parts book yet? Is there still a pump?
Yeah I guess the case changed somewhat.
If you're really uncertain and don't trust the spec, then put some more in. I hardly think ~100cc is going to make or break it in either case, but if it makes you feel better, put a little more in.
If nothing comes out of the breather when it's hot, c then Bob's your uncle.
Online TN Mark
« Reply #7 on: April 16, 2026, 11:24:14 PM »
The side is a FILL hole, NOT a level hole.
Pour in 500cc and button it up, you’re done.
Ride more, worry less, much less.
Offline Michael_A
« Reply #8 on: April 17, 2026, 06:45:02 AM »
Thanks guys. I guess I was really overthinking it. Appreciate the reality check!
Offline faffi
« Reply #9 on: April 17, 2026, 07:51:46 AM »
I dislike not being able to properly control the accurate level, be that for brake fluid or fork oil or whatever that I deem critical for function and reliability. On the final drive of every shaft drive bike out of Japan I have encountered, the fill hole is also the level hole. A lot of bikes with separate gear oil have a screw that can be removed and visually tell me when the level is correct. And, not the least, I can check the level when needed/I want to. My V9 manual say I should change the gearbox oil every 60 kkm, which is 37 kmi. That is a very long time for some oil to find its way elsewhere.
At least the gearbox oil can be changed on Guzzis; the manual box on my Skoda has no provision for changing the oil, as it is "sealed for life". That is true, but there is no way I can extend that life by changing the oil. I had the shop manger check it, and there is no drain hole, nor a fill hole - the oil is filled during assembly, meaning the only way to change the oil is to remove the 'box from the car.
Current bikes:
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Offline Kev m
« Reply #10 on: April 17, 2026, 08:47:35 AM »
Regardless of capacities, I've used the "fill" holes like that as level check holes on all my Guzzis (exception the transmission top fill hole on the MkIII smallblock) and the small difference in actual added fluid has not meant jack dick as a problem on any of them ever.
Jackal, Breva 1100, V7 Stone, and V7 Carbon Dark.
On the final drives it's so close it's not an issue.
On the rest it was a glug or two at most.
I can be as anal retentive as the next guy, maybe moreso, but this one really isn't a big deal
It would be a big deal for me to mix up my MkI and MkIII transmissions and put a full liter in the MkIII or only 500cc in the MkI, but really that's about the biggest possible worry.
If OP drained 650cc and spec was 500cc I'm sure he's fine with 500-650cc in there.
And if he just puts 500cc in, then notes how it probably sits just below the full plug he can use it as a level check.
Not to mention, we're taking cold. I wonder if 500cc would be up to the threads when hot? Or again, real close.
« Last Edit: April 17, 2026, 08:49:34 AM by Kev m »
Offline faffi
« Reply #11 on: April 17, 2026, 03:21:37 PM »
IIRC, the V9 had a bulletin issued to fill less oil than originally specified. Since I have not had any issues with my final drive leaking or otherwise ill things, I will just replace exactly what I drain, regardless of amount.
Current bikes:
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
