Author Topic: Small blocks—Why the left-side rubber inserts in the rear wheel?  (Read 29676 times)
Offline SIR REAL ED
  • uh.... it's personal....
Re: Small blocks—Why the left-side rubber inserts in the rear wheel?
« Reply #30 on: May 06, 2026, 11:31:23 AM »
Oo, sorry. You didn’t phrase it in the form of a question.
(Alex loved saying that, I bet)
Story of my life, always close, never a cigar.....
Alex, If I am not disqualified, I would like to pick "Does installing a quickshifter alter the Laws of Physics in the vicinity of the rear wheel for $250" please....
« Last Edit: May 06, 2026, 11:35:50 AM by SIR REAL ED »
2002 MZ Skorpion
1994 DR Skorpion
« Reply #31 on: May 07, 2026, 01:59:44 PM »
My 2015 V7 had the blocks in the rear wheel.
Held them in place with a touch of spray grease when changing a rear tire.  Made it easier.
Offline DoubleGuzzi
« Reply #32 on: May 07, 2026, 04:14:25 PM »
Skim read? Wrong side of the wheel, to what was being discussed.
Nearly natural progression..
« Reply #33 on: May 08, 2026, 06:30:31 AM »
Guess so.
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #34 on: May 09, 2026, 08:20:15 AM »
I think kingoffleece deserves partial-credit. If for some reason the brake-side rubber blocks are removed/not installed, they can be a bit of a squeeze to pop in, dry on dry. Spraying with silicone lube or grease can help them ease in. But it should be obvious to not overdo it, or risk getting schmutz flinged onto the rotor.
Offline DoubleGuzzi
« Reply #35 on: May 09, 2026, 11:07:57 AM »
Having just reattached the disc rotor to the V7C wheel, I can categorically confirm that the rubbers are to prevent ringing/alter resonance.
As an additional 'feature' they spring load the retaining bolts, leaving very little/zero chance of them loosening.
All in my ever so humble opinion.  :wink:
