I've only ridden the 1 Guzzi, my LM2 and it handles fine especially given it's age.The only problem I ever had with it was when overtaking on a 'hatched' area (diagonally painted lines in a painted box), where it got into the mother of all tank slappers - I honestly thought I was going to be thrown off it but I managed to keep it going straight until it smoothed out after which the front brakes didn't work until I'd pumped the lever a few times. I don't know if that's 'normal' for the bike or maybe because something's not right but I can't find any faults and it actually has an uprated steering damper taken from a Ducati 916 as the original whilst looking the part didn't 'damp' anything.Otherwise the best handling bike I've ridden is my Ducati 916 which just does everything right and is far more capable than I am.
I recommend the OP try one of the original short-stem models to experience the once-renowned handling of the original Tonti frame. (V7 Sport, 750S, 850T, 850-T3, 750-S3, Convert, Lemans, 1000-G5.)
How does the Cali II differ from the T3 & Co in the chassis department? I think it must be the closest thing I have come to riding one of those on your list, moto.
…a balanced weight distribution that let me drift both tires around every corner and plenty of torque to hang out the rear wheel to unload the front when needed. The standard riding position encouraged me to use my weight to help.
I’m not allowed to say that’s BS, so I’ll leave it up to Isaac Newton and the Gods of fact versus fiction.How in heaven’s name do you identify whether or not you “drifted” your bike, you possibly allowed it to run wide or it just stood itself up a bit due to the increasing velocity, but….Jeeeeez…
I was able to purposely slide the rear tire on the LeMans at the track, never the front. More horsepower makes it a bit easier.Pete
Since the traction provided by tires is highest as the tires begin to slide
I had one tank slapper on my LM1 when crossing Railroad tracks in the rain in the middle of an S curve.The stock damper is a friction damper and totally useless. I removed mine. Friction dampers have maximum resistance when motionless. Hydraulic dampers increase resistance as motion increases.Pete
Your front tyre is not so much sliding, but steering off the centreline tangentially to the curve.
No, Isaac did not ride motorbikes, but he knew a LOT about forces, vectors and velocity.
If you tell yourself what you want to hear, you can actually “see” it after a while, a classic case of coming up with a reason after the fact, for something that you perceive to be the case.
Also, reducing the weight on the front wheel will not reduce it’s tendancy to slide, friction is a function of force, the harder the tyre is forced onto the road, the less likely it is to skid.
It doesn’t matter if you name drop Marc Marquez, some things are just inescapably true.
So.It takes MORE force to keep a tyre sliding than it did to begin it sliding ?This would have to be the case if the tyre had more grip while sliding than before it began.If that was true, then at the instant you provided enough force to break traction (limiting friction), the tyre would stop sliding because there was not enough force to keep it doing so.
I concede that a good enough rider could produce some amount of drift on both wheels under enough braking, but on acceleration with a ditch pump for an engine ?
You misspelled "tendency"; I know how you hate that.
I think the V85 is a wonderful handling motorcycle with neutral yet fairly light steering due to the widish bars. It also has nice suspension, something my V7II Stone did not. I hope you can take one for a test ride. I've not ridden the new V7 850 series but everything I've read talks of nice handling, at least on smooth roads.
Oh…?How would you spell it ?
I was sliding both tyres through the bends on the road when I was just a teenager. As I went into the bend, I felt both wheels sliding, there was no heroic save however and this is not a tale of biking god-ness as I ended up face down in the road. Best part was, my family were waiting for me at a restaurant where we were going for a meal as it was my 18th birthday and I arrived late due to the crash, covered in blood.
