Author Topic: One functional fork leg  (Read 1115 times)
Offline YellowDuck
« on: May 20, 2026, 08:26:54 PM »
As I continue to get acquainted with my new V85, I came across something I have not seen mentioned here (or anywhere).
I am familiar with having rebound and compression damping adjustments on different legs (I have two bikes, including a V7 850, with cartridge setups like that), but before the V85 had never seen spring preload on only one leg.
It turns out, that's the only leg with a spring in it!
Some forks have all damping action in one fork leg, and the only spring in the other ("separate function" forks).  The V85 is the first bike I have encountered with all of the damping AND the spring in the same leg.  The left fork leg just locates the axle!
All the reviews about this bike that I read and watched, and no one mentioned that.  It's pretty unique I think.
Offline Dukedesmo
Re: One functional fork leg
« Reply #1 on: May 21, 2026, 04:28:41 AM »
Never heard of such a thing, I have a couple of MTB, bicycle forks that have the (air) spring in one leg and damping in the other but the 'all in one leg' and on a motorbike is a new one to me.
I have to say, it sounds more like a cost-cutting exercise than a technical innovation.
Le Mans II
Ducati 916
Ducati M900
Offline Vagrant
« Reply #2 on: May 21, 2026, 07:04:38 AM »
No doubt it was the cheap way out. But way better than no adjustments. Plus it actually works well when set up as the book says.
Offline mechanicsavant
« Reply #3 on: May 21, 2026, 07:32:17 AM »
The bean counters strike again !
Offline YellowDuck
« Reply #4 on: May 21, 2026, 07:36:52 AM »
I agree that it is certainly cheaper, and also that it works just fine.  There is no reason at all with modern forks that the springing shouldn't be confined to a single leg.  I had racing suspension experts telling me that 20 years ago - they had tested it even back then.  And the rebound adjustment on the V85 seems to provide a lot of useful range.  Screw it all the way in, and the forks are *VERY* slow to return; all the way out and they are very bouncy.  It's not really rocket science.  Compression damping I don't know - it's a lot harder to test / evaluate.
« Reply #5 on: May 21, 2026, 06:22:00 PM »
Think of the $$$$ you'll save on the rebuilds/renew service(s).
